Question about HP Hewlett Packard LaserJet 1600 Printer
My printer stop in printing mode and does not any print
  • 186 Answers
Check if any paper jam inside the printer... and check the toner level as well..
Posted on May 25, 2010
My printer will print one page and stop printing in the middle of the second page.
I think you are seat only one print one time so plz check it. Go to printer option and setting. One time you check printer after your printer which mode show like active print mode, print error, hold print mode etc.
I suggest you Full uninstall printer driver and re-again install printer driver. If not solved then change printer cable.
If more help contact Dell printer Support Technician. and TechSupportPrinter expert team.
Thanks.
Jan 11, 2014 | Dell Photo 926 All-in-One Printer
Why does my HP M451dn go into cleaning mode so often?
If you go into the menu settings option and scroll through the options, under system setup I believe on this model, you will see the setting to adjust.
Feb 10, 2013 | HP LaserJet Pro 400 M451dn Workgroup Color...
How do i adjust the printer to the tear off position
Print a config label by holding the cancel button and powering on 15seconds. Check print mode = tear off. If it is in rewind mode the label stops under the print head and does not backfeed before printing. Tear off pushes the perf to the tear bar and backfeeds before printing.
Dec 19, 2012 | Zebra S4M Thermal Label Printer
I printed all the pages I wanted and stopped the printing. today I want to print something else and it wants to prin about 30 pages I don't want, help
Hi
HOW TO CHECK AND FIX PRINT SPOOLER SERVICE THAT CAUSES UNABLE TO PRINT FILE
Print spooler service is a computer service that loads the print jobs into the printer memory for later printing and it acts as intermediary between a computer and a printer. When the print spooler service is stopped or malfunction, printing is not possible.
Here are the possible reasons :
1. Virus or Malware infection.
2. Spooler service was stop by accident or turn off to manual/disable mode.
3.Faulty installed printer driver that contains error or incompatible with previous printer drivers installed in your computer or system.
4. Print jobs and drawing jobs were corrupted by accident which caused print que lock and resulting print spooler service to crash.
5. Your printer had printing problem issue with pdf files.
To fix this problem, you have to check if the print spooler service had stop.
Here's how to check and fix the print spooler service.
Go to START
Choose RUN
Type SERVICES.MSC
Click on PRINT SPOOLER and check if the STATUS IS STARTED
If not, on the upper left side, click on STOP to stop the spooler service
Then click on RESTART to restart the spooler
Restart your printer and your computer
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Apr 14, 2011 | Office Equipment & Supplies
How do you stop a print job with the cl-s700
Stop a print job
1) press Pause button ..if reqrd continue..its the left button
2) want to stop the print mode...switch of printer & switch on the data in the memory gets errased
Not an expert on this but have 4 printers doing constant print jobs for customers.
Nov 13, 2010 | Citizen CL-S700 Thermal Label Printer
Printing issue
If command was with computer and you print mode of the printer, do stop by way of the removing the task sent on printer, from panel printers nominated printer afterwards remove problem, but if in mode of copying, push all reset buttom unset or removing the mode of the printer and translation on copying
Sep 13, 2009 | Canon ImageRUNNER 330s Copier
Prints on two cards
You can modify the position in the menu.
The start position can be prgrammed in the personal settings.
Moving the paperwon't change anything because the printer will always check the top of feed
Sep 03, 2009 | Datamax I-4208 Thermal Label Printer
HP PSC 1315 Printer frozen in "deleting" mode
It seems a Problem with the Print spooler.
You can try a print spooler refresh>
Go To Start> Run> And type services.msc> Ok
In the services window locate for print spooler> And bouble click on the same> It will open the print spooler property window>
Now Bellow service status you should see the Stop Tab highlighted> Click on the same (you will see a small winow popped up and it will close)
Now you will see Start Tab Highlighted> Click on start ( And you will again see a small winow popped up and it will close)
Now stop should be highlighted.
You can try this steps a couple of times untill you see STOP highlighted.
Then click on Apply or Ok and close all the windows and try if it does any better..
IF NOT YOU CAN TRY THIS.
Go to printer and faxes and right click on the printer icon and left click on properties> Go to Advanced> And here you will see ckeck mark on: Spool print documents so program finishes printing later.
Now Select: Print Directly to te printer that will uncheck Spool print documents so program finishes printing later.
Now click on apply and ok and try printing.
If it is better than keep the same settings.
If not you may have to do a complete Print spooler cleanup.
Good Luck
Sep 28, 2008 | HP PSC 1315 All-In-One InkJet Printer
Printer in error mode
Click Start - Control panel - Printers & FAXES
Right click on the printer icon Officejet 5600 series -- Select properties - Click on ports tab - Change the port to USB virtual port.
Disconnect the usb cable from the computer.
1. Click Start
2. Click Run
3. Type Services.msc
4. Locate print spooler on the list, right-click and choose stop.
5. Again right-click the print spooler and choose start.
Reconnect the usb cable try printing.
Thanks.
Dec 21, 2007 | HP DeskJet 5650 InkJet Printer
Stupid printer
Mp150 Reset Counter
Service mode operation procedures -
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Sep 26, 2007 | Canon PIXMA MP150 All-In-One InkJet...
HP Hewlett Packard LaserJet 1600 Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
