Question about Blanco 157-074R-ST Classic Kitchen Faucet w/ Pull-Out Spray Satin Nickel
Replacement of cartridge on single-levered Blanco faucet
I need to replace the cartridge on my Blanco kitchen faucet. I've removed the handle and a decorative ring. While I see the cartridge that needs replacing, there is a ring that looks like it needs to be removed before I can get to the cartirdge. It is a low rise ring. What kind of tool do I need to remove the ring? Also, once the ring is removed, will the cartridge easily lift up and out or is it held in place by some screw or clip?
jgwhomeequip
  • 1902 Answers
SOURCE: Leaky Blanco Single Lever Kitchen Faucet with separate sprayer
You only need one small o-ring. If you put two of them it will not work properly and will mostlikely leak like crazy. If this helped please rate.
Posted on Feb 12, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: price pfister faucet handle drops and turns off.
There is a price pfister little emblem under neath the handle. Use a but knife and pop that off. Once that is off there is a allen bolt in there. Tighten it up, put the emblem back and away you go
Posted on Feb 14, 2009
dragonsthatk
  • 547 Answers
SOURCE: kohler single lever kitchen faucet,no hot water
no its somthing in water filter rust or dirt in line.take apart and drain line. thank you for useing fixya please rate me
Posted on Feb 26, 2009
gary1121
  • 332 Answers
you can call or e-mail the company, if the faucet is the one in the picture it is a single cartdridge, turn of bith hot and cold water, take an allen wrench into the little plastic cover to remove the handle , unscrew the top cover or it might pop off, that there is either a large lock not or 3 screws holding down the cartdridge, take it out replace it put some faucet frease around all rubber gaskets then install it in the smae way it came out
Posted on May 30, 2009
SOURCE: need to fix a broken moen kitchen faucet
I had the same problem with my Aberdeen single lever with a pull-out sprayer a few months back. If you are the original owner of the faucet, it's under warranty; you shouldn't have to pay for any parts. Call: 1-800-BUY-MOEN (1-800-289-6636) and tell Customer Service what the problem is. They will send you the Handle Mechanism Kit at no charge. (Mine was part #93980 for my Aberdeen faucet, but yours may be a different part number.) It's tricky to take apart and get back together but my husband and I have zero plumbing experience and got it all fixed in about 20 minutes. The Moen.com website also has exploded parts diagrams of all their faucets so you can identify exactly what part you need, and they have some little videos and slideshows to show how to replace parts. If you can't reach Customer Service on the phone, you can go to "Contact Us" on their website and email them a description of your problem.
Posted on Jun 18, 2009
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Cartridge replacement
    Should be able to order new one at any plumbing supply. Remove handle, then with pliers pull out old cartridge, and push in new one till it seats, place handle back on.
    Oct 25, 2013 | Blanco 157-013-CR Harvest Kitchen Faucet...
    I have a Blanco 157-081-ST Single handle, satin finish faucet that leaks. I'm trying to get to the cartridge but don't know how to take off the handle. I've removed a single screw on the handle body but...
    If the screw you have removed is a set screw then you shuold be able to remove the handle. If it has been on there awhile you may need to pry on it with the handle in the full open state. Use something that will not mar the handle.
    Feb 12, 2011 | Blanco 157-081-ST Modera Kitchen Faucet...
    I have a single handle blanco classic that is leaking around the base I have removed the handle and cartridge but cant figure out how to remove the sprayer to replace the seal
    You need to turn the water off under the sink. Disconnect the sprayer hose from the threaded shank under the center of the faucet body. Pull the spray head out of the faucet. Contact Blanco to receive your faucet parts free.
    Nov 06, 2010 | Blanco Classic Single Handle Faucet with...
    Re: Moen single-lever kitchen faucet like the 7100. When I replace the lever, it only goes up. I can't get it to go down. I'm pretty sure the cartridge is in right, with the U-clip and the other screw-on...
    The water supply should have no bearing on the working motion of the faucet cartridge or handle. On both models of Moen faucet, the handle needs to be hooked under the cartridge's top cam bearing. It is a bit tricky sometimes. Here's the parts view for 7300 and 7310 Moen Kitchen faucet. Parts view for 7100 Moen.
    If you need further assistance please let us know.
    Sep 16, 2010 | Moen 7310 Legend Single-Handle Kitchen...
    Water leaks from around the stem when I lift the water handle. What to do? It doesn't drip from the tap, but from around the stem part - sometimes quite a lot of water. Can I repair this myself? It's a...
    ur cartridge needs service or replacement u can turn off water supply remove lever and retaining nuts pull up cartridge and inspect the o rings for debris and or damage if good inspect cartridge for damage if looks check gaskets/o-rings in stem for same add a little vasline around o-rings and reinstall test for leak if leaking still replace all o-rings or if cartridge order and replace
    Nov 03, 2009 | Moen 87530 Touch Control Single Handle...
    May 30, 2009 | Blanco Classic Single Handle Faucet with...
    Blanco 157-074R-ST Classic Kitchen Faucet w/ Pull-Out Spray Satin Nickel Logo
    137 people viewed this question
    Top Blanco Plumbing Experts
    Mack Baxter
    Andrew Bugbee
    Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
