Question about Toshiba Tecra A8-S8414 Notebook
I forgot the password for My Toshiba Tecra A8-S8513
I forgot the password for My Tecra A8-S8513, I heard that I may need a master password reset in order to reset the password, I took the internal battery out for more than a week, but when I turn the notebook on, it still asks for a password.How may I reset this password so I could get in?
Thank you
  • 1 more comment
  • cmgumucio May 27, 2010
    I forgot the password for My Tecra A8-S8513, I heard that I may need a master password reset in order to reset the notebook, I took the internal battery out for more than a week, but when I turn the notebook on, it still asks for a password.How may I reset this password so I could get in? Thank you
  • cmgumucio May 28, 2010
    I stated my problem as follows:
    I forgot the password for My Tecra A8-S8513, I heard that I may need a master password reset in order to get into my notebook, I took the internal battery out for more than a week, but when I turn the notebook on, it still asks for a password.How may I reset this password so I could get in?
    Some expert helped me out, with no solution, so I rewrote the problem, as follows:
    Thank you, I think I was not clear enough describing my problem. My notebook has a system password enabled, that means when you turn the notebook on, it asks you for a password, before it gets in windows, it does not let you do anything, not even boot from a CD. Usually there is a master switch or jumper that clears this state, but I could not find it on the notebook. One more thing, as I wrote before, I took the cmos battery out, for more than a week, but still, I cannot do anything without the password .
    I hope this time I was clear enough with my problem,
    I forgot the boot password for My Tecra A8-S8513, I took the internal battery out for more than a week, but when I turn the notebook on, it still asks for a password.How may I reset this password so I could get in?
    Thank you, I think I was not clear enough describing my problem. My notebook has a system boot password enabled, that means when you turn the notebook on, it asks you for a password, before it gets in windows, it does not let you do anything, not even boot from a CD.
    Brigadier General:
  • 4,090 Answers
Go to this page and read to the bottom. \
If you don't succeed contact Toshiba who will help you in this matter FREE
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/outFrm.jsp?ofId=AskIris&searchString=bullrtin&x=9&y=11
Thanks for using Fixya
Posted on May 28, 2010
  • cmgumucio May 29, 2010
    No very much help, but thanks
  • dennis bullard May 29, 2010
    Well That was straight from Toshiba themselves, so sorry you think that it wasn't much help. Little we can do if a product is designed to be minimally dealt with by the user. But as i stated Toshiba WILL provide further assistance FREE if their published fixes don't work.
    If your Laptop has a 25 printer port there is another solution ( not from Toshiba) and it is here, so give that a try
    http://www.laptoprepair101.com/laptop/20...
  • Toshiba Master
  • 11,800 Answers
Most Toshiba laptops and some desktop systems will bypass the BIOS password if the left shift key is held down during boot. Otherwise you will have to take the laptop to an authorized Toshiba Service Agent to have the BIOS reflashed.
  • Azrael SRL May 28, 2010
    As i said, if the left shift key trick doesn't work on your model of laptop you will have to take it to a shop - the BIOS password on Toshibas cannot be removed by a customer, this is a theft deterrent measure.
  • Toshiba Master
  • 6,993 Answers
Its only a phone password that can be reset and not a laptop password. If you cannot remember the password for your laptop, the only solution you have is to re-run windows operating system (Win xp or vista).
If your laptop operating system is windows xp, you can still log into your password by follow the steps below:
  1. Turn on your laptop and allow it get to the stage where is will ask for password
  2. Press Ctrl + Alt + Del on your laptop key board, and it will ask for user name and password.
  3. User name, type in "administrator"
  4. Password, type in "administrator"
  5. Press enter and you should be able to long into your computer.
But if you are using windows windows vista, this will not work because windows vista has a very tight security, unlike windows xp.
But the best way to solve this problem is to re-run windows operating system. You will be needing a windows xp disc or a windows vista disc, depending on the windows your computer is operating on.
Good luck.
Posted on May 27, 2010
    Thank you, I think I was not clear enough describing my problem. My notebook has a system password enabled, that means when you turn the notebook on, it asks you for a password, before it gets in windows, it does not let you do any thing, not even boot from a CD. Usually there is a master switch or jumper that clears this state, but I could not find it on the notebook. One more thing, as I wrote before, I took the cmos battery out, for more than a week, but still, I cannot do any thing without the password .
    Thanks
If your user name is anything other than "Administrator" you have a chance to get in. When you boot the computer press F5 repeatedly and go to safe mode. In the safe mode you will see many logins depending on how many users are there, one of them would be the user name Administrator. Log into the Administrator account and then in the Control Panel->User Accounts delete the account for which you have forgotten the password and create a new one. Create a new one and after logging into the new one, copy all the documents from the old one to the new one in a my documents folder.
Posted on May 26, 2010
  • cmgumucio May 26, 2010
    Thank you, but it does not work. The notebook has been set up to ask for a password when turned on. I have not activated the fingerprint log in, therefore it keeps asking for a password when I turn the notebook on before any thing.
Keeps prompting to enter a password before attempting to boot up?
you need to reset your BIOS. see instructions below.
http://jevarax.wordpress.com/2008/08/08/how-to-clear-your-toshiba-bios-password/
Mar 07, 2012 | Toshiba Tecra A8-S8513 Notebook
Toshiba tecra a8 power on password regarding master password
plz open the ram mumery under rhe jumper j8 u short the jumber after on the laptop password is open
Sep 09, 2011 | Toshiba Tecra A8-S8414 Notebook
After replacing the CMOS battery date & time problem is same
go into your BIOS and at the very last tab click on settings and go down to were it says default or reset and click yes then restart your computer
Mar 03, 2011 | Toshiba Tecra A8-S8513 Notebook
Bios password
If you forgot you bios password you need to call the Toshiba support and they will give you a code to reset the password. only toshiba can unlock the bios password since they do have the tool specificall for that problem. thanks
Jan 03, 2011 | Toshiba Tecra A8-EZ8311 Notebook
The Toshiba Tecra A8 S8413 laptop cmos battery (or capacitor?) does not seem to be working. Symptoms: I set the date and time. As long as the laptop does not sleep or go into power save mode the clock...
The RTC (Real Time Clock) battery charges when the computer in on (operating). You can plug the electrical cord in and let the computer run for 24 hours by temporarily suspending any sleep mode or automatic power saving features. This should sufficiently charge the RTC battery.
Nov 30, 2009 | Toshiba Tecra A8-S8513 Notebook
Password problem
need to reinstall the OS
Jun 12, 2009 | Toshiba Tecra A8-S8314 Notebook
I forgot my password for the toshiba a8 s8514 every were i turn no one seems to hav a answer!
boot the sp-2 bootable cd. when it start ia ask u change the ad, password? then ucan fallow process. thanks
Jun 11, 2009 | Toshiba Tecra A8-S8514 Notebook
Cant get the password of Tecra A8
Clear it with the 'clear cmos jumper'.
Jul 06, 2008 | Toshiba Tecra A7-S712 Notebook
Toshiba Tecra A8-S8414 Notebook Logo
308 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
