Question about Sony DVP-S550D DVD Player
Will not turn on
When I turn on the power, the red light at the power switch turns from red to green for just a few seconds before turning back to red. Nothing else happens.
  • 10,594 Answers
Is it Sony DVP-S550D player or any other model as I have to look into related schematics for possible cause of problem.
Thanks.
Posted on May 25, 2010
  • 7 more comments
  • keenekelley May 25, 2010
    Yes. Thank you. That is the model- DVP-S550D.
  • Shahid Electronics
    Shahid Electronics May 25, 2010
    Thanks for model info.
    Get back to you shortly after schematics study.
    Thank you very much.
    Give me bit time, its 1999 model dvd player and have a lot circuits inside.
    No rush. Thanks,
    Thanks.
    OK, thanks for giving me time.
    Please unplug unit from wall socket for minute to get it reset, replug back in and turn it On, if player does not remain power On then need to check output voltage of power supply board on 3 connectors that are mentioned in below images. You can take readings with digital volt meter if you already have little experience of electronic stuff repair.
    Thank you. I'll do that and get back with you tomorrow.
    OK, I will wait your update.
    Thanks.
Red light blinks six times. When I hit power button green light stays on for a few seconds, turns off the on for a few more. Then goes back to pattern of red light blinking six times.
the kill switch is open ensure the lamp cover presses firmly on the kill switch when u close the lamp chamber door the red light will stop blinking and u can now turn the tv on
Jul 06, 2013 | Televison & Video
Mitsubishi big screen HD 1080 series model WS-55809. it switched off one day. and when i turn it back on it switches right back off. red light in front. what part do i need to fix it/
That model does not have a red light---Green.
If set powers up for a few seconds (green power light) and goes out do the self check the model indicated has:
On front of set (not with remote) press and hold both the input and menu buttons for at least 5 seconds and release both.
Green power light will blink a two digit error code like 2 blinks, 2 blinks a pause and repeat it several times.
Let me know what error code you find (if you have unplugged the set that will clear all errors and you have to plug it in and try to turn set on again---when it fails do the self check)
Mar 31, 2012 | Mitsubishi WS-55809 55" Rear Projection...
My epson tx700 printer dispaly ink pad at end of life and printer not start
A fix from a forum:
Procedure 1 We found this procedure to work for the Stylus Photo 1270 type printer, and understand that it also works for the 870 range and even earlier models like the Stylus Color 740. The error is indicated on these printers by all four lights on the printer flashing. Even if you press the power switch on the printer, the lights continue to flash, and the printer does not turn off!
  1. Turn off your printer, ensuring that the print head is at it's home location and locked in place as normal;
  2. Power off the printer at the wall or by removing the power cable, for at least 20 seconds;
  3. When you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer's power switch was 'on' - switch it off and return to step 1;
  4. Hold down the paper-feed button and the button with the ink-drops next to it, and then turn on the printer, still holding the buttons down;
  5. When the paper-out LED flashes, release the buttons;
  6. Press and hold the Cleaning button, until several lights flash - this will take a few seconds (i.e. then release the button);
  7. The printer will now attempt to reset, including resetting the EEPROM memory and running a short (about 10 seconds) cleaning cycle.
Procedure 2
  2. Hold down the paper feed button only;
  3. Turn on the printer;
  4. As the paper feed light starts flashing, release the button;
  5. Immediately hold down the ink-drops button for some 10-20 seconds or until the printer springs into life;
  6. Allow printer to complete it's processing, then turn off for a few seconds, and back on again for a newly working printer!
Procedure 3 - for 1290 and possibly 890 printers 1290 printer with green (power / data) and red (ink / paper feed) lights flashing alternately:
  1. Switch off printer with panel switch;
  2. Switch off printer at mains switch - leave off for 20+ seconds;
  3. Hold down roll feed and sheet feed buttons;
  4. Switch on at mains;
  5. Switch on at printer panel;
  6. Continue to hold down roll and sheet feed buttons until both green and red lights flash together in synchronisation, not alternately;
  7. Switch printer off and then, after a few seconds, on again at mains switch;
  8. When red and green lights are both flashing in synchronisation, release the roll and sheet feed buttons;
  9. Press and hold down the ROLL FEED button (the one at the extreme left) and keep it down until the machine finishes whirring, cleaning etc and the green light comes on steady;
  10. Release the roll feed button and all should be well.
Apr 25, 2011 | Epson Printer
The ink pads are at the end if their service life.
Depending on what type of printer you have:
Procedure 2
Mar 13, 2011 | Epson Office Equipment & Supplies
When I put my printer on, both the red 'on' light and the 'green' problem light are flashing intermittetly . I have tried to reset the printer by pressing the 'green light' down for a few seconds..but...
when I put my printer on, both the red \'on\' light and the \'green\' problem light are flashing intermittetly . I have tried to reset the printer by pressing the \'green light\' down for a few seconds..but nothing now happens on this mode. I have also turned the printer off and back on again, and lastly took the power cable off and back on again..and still no joy..any ideas
Nov 02, 2010 | Epson Stylus C46 InkJet Printer
My Loewe Aconda TV will not turn on - buzzing noise.
My Loewe Aconda 81 HDR TV will not turn on. When I press the power button the green light comes on but the red light stays on with it and after a few seconds the green light goes out and the red light stays on. Any help please.
May 15, 2010 | Loewe Aconda ACO9383 38" TV
PS3 won't start
u have to wait for about 30 mins before turning it back on
coz when it does that it's tired
hope this helps
Sep 19, 2008 | Sony Playstation 3 (PS3) Console
PS2
Faulty button, fuse. Try a new power cable, if that doesnt work then it will need a new on/off switch.
May 16, 2008 | Sony PlayStation 2 (PS2) Console
Akai LCT3201TD
Most failures of this nature are with dying or defective power supplies.
I service these power supplies. If you need more info, my email is jah2mil@hotmail.com
Oct 14, 2007 | Akai LCT3201TD 32 in. LCD Television
Won't turn on now
ftry to unplug it and push the on/off switch...plug it back in and see if it will turn on
Sep 09, 2007 | Akai LCT3201AD 32 in. LCD Television
Sony DVP-S550D DVD Player Logo
55 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
