Question about Acer Aspire 4315 Notebook
ACER 4315 flickering screen (very bad)
Dear sir, my ACER 4315 notebook with Intel Celeron processor 540 has a really bad flickering screen. Its getting worst and its only 3 months old from new. I have not install any other software other than the internet modem.
  • wynana Jun 08, 2008
    I also have Acer Aspire 4315 notebook and anytime i am working the screen just turns white and then i cant save my works and have to restart. I am using Windows XP 2 and i have installed the XP drivers I really need your help to solve this problem.
    thank you
  • Anonymous Nov 25, 2008
    Our Aspire 4315 has a screen that flickers increasingly often. It use to only happen when the computer had been left alone for several minutes. Now it happens extremely often.
  • 77 Answers
  1. First since it is only 3 months old. Bring it back to where you purchase it so that you can avail of the warranty.
  2. If for any reason you cant do that then try the following
  • Turn off your laptop
  • remove the LCD bezel by removing the rubber and screws
  • try to reinsert the cable that attaches the monitor to the INVERTER. The inverter is the one lighting up the screen. Usually this is located at the bottom of the screen
  • if this doesnt work then try to remove the LCD panel and reinsert the flex cable located at the back and see what happens
NOTE: make sure when you remove cable and re inserting them in, your laptop should not be attached to ac or battery.
i hope i was able to help
Posted on Apr 07, 2008
SOURCE:
How many pins are in a intel celeron cpu 540 @ 1.86ghz
I would use a web site like memory store dot com, They have a small executable that will auto detect and point out what you need. Or you could use the manual search.
Jan 28, 2013 | Intel Celeron 540 1.86Ghz Processor Open...
Celeron 540 upgrade
Aspire 4315 Specifications Specifications
Part Number
Varies by specifications
Processor / Speed
Intel Celeron mobile processor 530/540/550 (1 MB L2 cache, 1.73/1.86/2 GHz, 533 MHz FSB), supporting Intel 64 architecture
if you have a 2 Ghz processor installed, you will have to replace the motherboard to go with a faster CPU.. which will be spendy..
Hope this helps
May 06, 2009 | Acer Aspire 4315 Notebook
Cpu upgrade
Your computer has one of these options:
spacer.gif level2_arrow.gif Intel® Celeron® Processor 560
(1MB L2 cache, 2.13GHz, 533MHz FSB)
or
Intel® Celeron® Processor 550
(1MB L2 cache, 2.0GHz, 533MHz FSB)
or
Intel® Celeron® Processor 540
(1MB L2 cache, 1.86GHz, 533MHz FS
or
Intel® Celeron® Dual-Core Processor E1400
(512KB shared L2 Cache, 2.0GHz, 800MHz FSB)
or
Intel® Celeron® Dual-Core Processor T1400
Check the features with Acer first and see if your motherboard model support that speed processor.
Contact tech support directly to the manufacturer right here:
http://acer.custhelp.com/cgi-bin/acer.cfg/php/enduser/ask.php?p_sid=8P57rbgj
Oct 13, 2008 | Acer Aspire 5315 Notebook
Upgrading my laptop's processor from celeron 540 to 560
there is no way you can upgrade the VGA on a laptop. You can upgrade everything else. But tis always better and cheaper to get a new one.
check with the cost of the celeron 560 and the 4gb + the 250 gb together.
but how much a new computer cost? so its your choice...
Aug 11, 2008 | Acer Aspire 5100 Notebook
Fan cooler for Celeron is usually the same for 540 and 560 Ghz, there should be no need to replace cooling system if you pass from 540 and 560
Whenever you operates on CPU and cooling system you need to monitor CPU temperature using Bios or a dedicated software. Here is a good software to check CPU temperature and Fan activity: SpeedFan Download.
Regarding the RAM, some seller like this one (UK seller).sells Trascends 2 GB modules, seller says they work on 4315, you can eventually ask them if there is any issue with bios version and if you need to upgrade bios.
Remember, CPU upgrade on a laptop is not a simple operation, be careful if you do it yourself, as it is easy to damage the laptop when taking it apart. Regarding RAM, main risk is incompatibility, If you live in UK the seller above guarantee compatibility with Acer 4315, double check by sending them an email before buying.
Upgrading my laptop's processor to a lower processor
No laptops graphics are integrated into the motherboard and cannot be change with any bit of ease
Aug 10, 2008 | Acer Aspire 5100 Notebook
Possible it is possible, but if I was in your shoes I wouldnt do this to my laptop. First is not worth, a Intel Core 2 Duo T5500 alone costs about £.100, the CPU replacement is not a simple operation and should be performed by an expert repairman, this will cost you about £ 80 plus VAT labour, replacing cooling system with a better one would also be good.
Then after you replace it you risk to overheat your new CPU and blow it, this is one of the reasons why Acer tells customers not to upgrade to core 2 duo. Additionally, if you want to DIY you risk to damage your laptop on a complex cpu replacement operation.
The guy on you tube wanted to show his skills, but I am sure any genuine computer repair engineer will suggest you not to proceed with this kind of operation.
With all money required, labor, and risk involved in operation you will better buy a new laptop, if you really need a powerful laptop buy Alienware, uk custom made supercomputers.
Regarding the memory I know that some customers successfully mounted 4 Gbs on 4315, while I also read on the Internet other 4315 did not support 4 Gb. I assume it depends on Bios version. I suggest to contact the memory seller posted in previous message and ask if 4Gb are supported, giving them exact model number from your laptop service tag, and also ask if you can eventually get refund if this does not work.
Cheers
Aug 09, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 4315 Notebook Logo
775 people viewed this question
Ekse
Alun Cox
