Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
Hp 1522 printing scanned doc too light
Hp 1522 will scan papers in to medical charts clearly but when you print the documents they are too light to read however when you print computer created documents from the same program they are fine. please help!
  • mehul Nov 18, 2011
    hp 1522 will scan papers in to medical charts clearly but when you print the documents they are too light to read however when you print computer created documents from the same program they are fine. please help!
    Sergeant:
  • 284 Answers
Try to change the COPY density.
Posted on May 26, 2010
Issue with scanning documents to PDF however no issues with printing documents
from the sounds of this you have dirt or something on the scanning lenses. you need to check where the document you are scanning is loading it is carried across a lens that creates the image, if this is dirty you will get your symptoms coming out. if you lift the cover where the document is feed in you can clean this lens with some glass cleaner and a soft cloth. if all is printing ok you will waste ink by carrying out cleaning and alignment programs so save your ink and check the lenses for scanned doc. Hope this helps.Andy
Mar 11, 2015 | Office Equipment & Supplies
How do i get my hp officejet j6480 all in one scan both sides and print
To automatically scan and print, you need to use the automatic document feeder (for letter-sized documents) and have the HP Automatic Two-sided Printing Accessory installed.
Then to use the duplex printing feature, you need to set the printer properties to use the duplex feature. In Windows, open a document to print then click on File Print. Choose Setup and then Properties or Preferences (depending on your OS). Then click on the Features tab and set Two-sided Printing to Automatic. (This is a drop-down menu on the Features tab.)
You also need to set the scan settings for two-sided in the HP Solution Center. (If you just want to copy the document, you can set this from the Control Panel on the J4680.)
If you want to do this manually, you can scan each side of the pages. Then print them one page at a time. Then when the ink is dry, put the page back into the paper tray. (Note: this could result in paper jams.) The printer prints on the underside of each page put into the paper tray with the top of the page printing on the forward part of the page.
I hope this helps.
Jun 19, 2012 | HP J4680 Office Jet All-In-One Printer
My HP 6280 will not print the full picture after it has been scanned. I put it in the right hand corner, chose the correct paper size and it still won't print correctly. Can you please help
Check corner marking for placing the document, place the document & scan through system, verify whether you got full scanned image? if not adjust the placement in correct position, once its OK, go for print there select correct image size(could be 100%) & paper size..I hope it will solve the issue..Best of luck
Sep 25, 2011 | HP Photosmart C6280 Printer
HP LJ 3030 w/ USB connection to a computer with Windows Vista Home Premium Svc Pack 2. 64-bit Operating System. Problem: When I feed legal size docs through the doc feeder, the scan is letter size. I...
Hello Steve !
The only way scanning Legal documents on this HP LJ 3030 willbe using the ADF ( Automatic Document Feeder) since the size of the flatbed its only for letter.
So, after placing the document on the automatic document feeder theres a few setting you will need to change on the printer.
Number 1 : Go to Main Menu on the printer and look for System Setup, under system set up look for Paper setup,hit ok and now look for "Def. Paper Size" and set it to "Legal"
Number 2 : you should have a button on the printer control panel (Physical printer) that says " Reduce / Enlarge" , hit it and make sure the one selected is "original=100%"
Now just hit "Start Copy" and it print LEGAL ! it worked for me
Hope this help !
You can contact me at:
eliteprintersolutions@gmail.com
Bryan
Jul 16, 2010 | HP LaserJet 3030 All-In-One Printer
Hp j4680 says "paper jam"
Try this. Sometimes you get that message because a previous jam was never fully fixed.
Sep 29, 2009 | HP J4680 Office Jet All-In-One Printer
When faxing does paper face uup or down
You load the originals print side uo on the document feeder tray or print side down on the glass.
To send a single page fax you can either load the original on document feeder tray or on the glass; to send a multi-page fax you must use the document feeder tray.
The position of the paper is the same either you copy, fax or scan.
All this is clearly explained in the user's manual, that you should read and you can download from HP support pages for you printer:
Aug 09, 2009 | HP Officejet 6310 All-In-One InkJet...
Scanned legal doc to email comes out landscape and prints on lett
select scan mode, then select legal on paper select. If you select paper before loading document into the ADF it should go with the size you enter.
Jan 07, 2009 | Sharp AR-M550N Copier
Won't Print, copy or scan
Take the cartridge back out and reinstall it just to be on the safe side. If that does not clear up the problem, there is a very strong possibility that you have a faulty cartridge that needs to be replaced (it can be faulty even if it is a new cartridge). - Graye
Nov 02, 2008 | HP PSC 1410 All-In-One InkJet Printer
Document feeder works for printing but not for scanning
Hi, When you had the doucment feed jam were you able to clean or remove any paper that might be blocking the paper to be scanned? It sounds like there is paper still in the document feeder , I would open the DF and check very closely to make sure no paper is in the way!Good Luck!
Dec 02, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
735 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
