Question about Ovens
I have a Frigidaire ove model # GLGFM98GPBC S#VF80923871. Originally the problem was that the oven was beeping, with out any codes. I thought it would be the ERC, and changed it, although that wasn't the problem. The noise was coming from the lower oven's warming drawer board, thats located behind the knob. I changed that board, and the next day the buzzing returned. What can be my problem?
  • All Make Appliance May 26, 2010
    Im an appliance repair man for 25 years, I don't need the manuals I need to know whats causing the lower oven board to beep?
    Genius:
  • 1,417 Answers
Hello.
what you need to do to fix up oven back again
is that you will have to locate the element of your oven it has develop a lick-age from it some air get escape from it and
the element is the heat provider for your oven that allow it to carry out it function has an oven it is always in silver colour and it is connected to the maize (the wire or the hose from the gas ) which supply power to it
unscrew the oven from the back and trace the wire or the hose that connect to the element
please do this with care to avoided more damage on it
Good luck and thanks for using fixya.
Posted on May 26, 2010
    Genius:
  • 1,040 Answers
Dear Meirhindy,
visit to the given link and download the manual. It will help you to get cause of your problem.
http://www.frigidaire.com/manuals
Posted on May 25, 2010
  • Ovens Master
  • 17,970 Answers
No fault codes, no ERC (even replaced), and no board? I suggest visit the dealer, with this type devices cannot play, remember that keep high voltage when working.
Good luck.
Frigidaire oven fpcf3091lf code eo90 comes on and beeps goes away but comes back.happened after power was out for a while
Frigidaire FPCF3091LF Complete Owner Guide English Page 30
click on the link above and check on page 30 on Setting Oven Controls
https://www.manualowl.com/m/Frigidaire/FPCF3091LF/Manual/173714?page=30
To restore all user settings to factory default:
step
1. press and hold 7 until first beep sounds
2. press start
May 30, 2015 | Frigidaire Ovens
Constant beep beep beeb from Maytag
forum.appliancepartspros.com/oven...ranges-cooktops/5209-maytag-ove...
https://www.maytag.com/product-help
Jun 30, 2014 | Maytag 30" Built-In Single Electric Wall...
What does the code f2 and f3 mean?
my ove is in selfcleaning mode and is beeping f2
Feb 16, 2012 | Kenmore 47712 / 47714 / 47719 Electric...
I want to repair wall ove 911 3128812 kenmore
first thing to do is to look it up, do you have the booklet that comes with it can look it up that way. If not you can go on the mfr website and punch up the model # it will tell you what the code refers to. When we know what the problem is we can fix it
Nov 15, 2011 | Ovens
Oven door locked
ah, you lucky guy. You can try a hard reset by unplugging the range for a good 1/2 hour, then plug back in. Unfortunutely this probably won't work, as these clock/timers are notorious for only lasting a few years. You have to blow $150+ and replace the clock/timer. Note: A hair dryer will help you get the face off the old one to put onto the new one.
Nov 10, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire Wall Oven
It is telling you that your oven has an issue. Check your owners manual for the fault code definitions. If you have a model number I may be able to find it for you.
Jan 26, 2009 | Frigidaire 27 in. Electric Double...
Fault Code F1
Frigidaire oven fault code F1 means the electronic clock control is bad and should be replaced. That is the electronic control board that shows your clock display and is also called clock or eoc, depending on your model.
Mar 25, 2008 | Frigidaire (FEB30S7D) Oven
Fridgidaire stove/ove
I have a Frigidaire electric oven model # PLES389ECE. It is two years old. It has maybe 50hrs of use. I had the oven blower motor go out. Then I had a circuit board malfunction.  The repairman discovered that one of the main terminal connections was loose and caused the terminal block to short. Could this have been the problem all along? Also, we are having a problem with the oven coming up to temp. According to the operating manual, set oven temp. lets say for example  350 degrees. Once the oven is preheated to 350 a beep sounds. With my oven the oven is about 60 degrees to low. You have to wait about 10 more minutes. Is this normal with this model? Has anyone else had problems with this model? I also heard that Frigidaire made a bad batch of ranges. Could this be one of them?
Thanks, Vincent
Oct 27, 2007 | Frigidaire FGB24S5A Gas Single Oven
Ovens Logo
26 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
