Question about Remington 111409 - 01 6" Branch Wizard Electric Pruning Saw
How do u un bolt from pole - Remington 111409 - 01 6" Branch Wizard Electric Pruning Saw
Apparently, although the two halves are screwed together, the unit is riveted to the pole. Those rivets appear to hold the housing together. On mine, it stopped rotating and I think the commutater brushes are bad. I may drill out the rivets, repair the motor and bolt the unit back to the pole (in place of the rivets). horny385, you are a **** and not clever or helpful.
Posted on Jul 18, 2010
To Joe handy. How did you solution work out? I've got the same
problem. Did you drill out the rivets, repair the motor and bolt
it back together?? How did you get the chain sproket wheel off the
motor shaft?
JW
Posted on Aug 05, 2010
    Problem Solver:
  • 8 Answers
Lossen the bolt ******* with this invention called a wrench they sell these at sears near where you bought the saw
Posted on May 27, 2010
2010 ez go electric golf cart steering wheel turns but wheels don't turn
You might have to loosen the bolts holding the steering arms to get the pole to line up, but if no piece is missing , sure connect it and secure with the locking bolt in the spiral.
Jun 12, 2017 | Golf
Maxtra long pole hedge trimmer has bolt with stripped thread.
same thing happened to me, I had to make another one there made of some kind of puter
Apr 07, 2014 | Maxtra Trimmer 30cc 2-stroke Gas Pole Saw...
Como conectar los cables son 4
Mi espanol is not perfect: Use google translate
Copy following link:
Dimmer will be same as single pole timer:
http://waterheatertimer.org/How-to-wire-timers.html
Also en espanol:
http://waterheatertimer.org/Wire-dimmer-en-espanol.txt
Add a comment
May 18, 2013 | Cooper Wiring Devices ACE6001V-K "ACE"...
Tesco 6 Person Vis-a-Vis Tent Instructions
Whoever they employed to write the instructions should be shot or go back to kindergarten....how difficult can it be?
Anyway, this tent is relatively easy to put up IF you know how to do it...which the instructions are painfully inadequate. It (un)helpfully uses colour coding on black and white print out and not explaining which way around the longer/shorter poles should be. Actually, once the poles are in, the instructions are ok....but it is a major point and wastes a shtload of time.
There are 2 LONG (well, slightly longer) poles, with a yellow sticker on the end (which comes off after 1 use of the tent). Start on one side of the tent with 2 poles (one longer, one shorter). Slide the long pole into the inner rib (ie towards the middle of the tent), then put in the shorter pole on the outside rib (i.e.the furthest away from the middle). You do need some grunt to force these into place, but at least they go (they won't if you put the wrong pole in the wrong slot). Then do the other side of the tent, longer first (inside), shorter second (outside). Then just pin everything else together like the instructions show.
The tent is ok, just ok, not great, not terrible, although it is pretty terrible in the wind, but what do you expect for 60 quid.
Jun 24, 2012 | Sport & Outdoor - Others
Got the basketball poles stuck together and theyre not aligned
Dropping the stuck poles definitely WORKS! We had stuck basketball poles from a Spaulding 54 inch together wrongly. Dropped them on grass from shoulder height 4 times and they loosened enough to pull apart.
May 01, 2011 | Lifetime 3819 Impact 44" Basketball...
I have un-bolted starter motor, bellhousing,all conecting mounts and wires ect. axels out, motor supported. But the box doesn't seem to want to seperate for me. Is there something internal I need to...
did you un-bolt the flywheel bolts also don't forget that there are small round wedges that also hold the box together. this would have to be pryed apart.
Feb 01, 2011 | Mazda 626 Cars & Trucks
Loud banging noise when using the Kettler elliptical trainer, ctr
This is a common problem for the CTR1, it actually sounds a lot worse than it is. It's just one of the 4 bolts that hold the front "pole" of the CTR1 in place that is broken. You will need to unscrew the bolts at the base (just move the plastic piece that hides the bolts up on the "pole"). After removing the pole you will need to remove the broken bolt from the inside of the "pole" with plyers. Then just put the pole back in the base, replace the screws (be sure to tighten them good). All will be good :)
This is a weak point of the CTR1, be prepared to run into the same problem again down the road...
Nov 10, 2009 | Kettler Mondeo Elliptical Trainer
Remington electric pole saw stalls in vertical positon
check the bottom of the chain guard, look for a loose bolt just inside the housing.
Nov 02, 2009 | Remington Polesaw Wizard
I can't find the fuse or relay for the trailering harness battery charging circuit. Everything else works fine. The truck is a duramax and has 2 batteries.
In your fuse box under the hood... there are 2 fuses marked pole 1 and pole 2. One of these is the fuse to feed 12 volts to the trailer. The poles are located under a smaller cover just behind the main fuse box under the hood. The wiring may have to be connected to the bolt/post.
Jun 27, 2009 | 2005 Chevrolet Silverado
How do I replace the starter
disconnect the battery post....remove the bolts holding the starter and then disconnect the wires to the starter.. install in reverse order
Jun 04, 2009 | 1995 Geo Metro
Remington 111409 - 01 6" Branch Wizard Electric Pruning Saw Logo
201 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
