Question about Sony Playstation 3 (PS3) Console
I've just purchased a PS3 for my son. Did upgrades on-line etc. Established a voicemail through my ISP via my secured wireless LAN. He's able to get on-line ok. When he logs into our ISP to check his e-mail he is able to receive ok. He cannot reply, deleat, or send e-mail. When he scrolls up to either the deleat or send button then clicks on the ''X'' button on the controller nothing happens. The ''X'' button works fine on all other web applications etc. This is only PS3 specific. When I try logging onto to my account I get the same symptom. From my laptop or PCs it works fine. Checked with my ISP super tech. He feels this may be a code issue within the PS3. Any thoughts?
  • Sony Master
  • 6,487 Answers
Yes base from the description of your problem its really a problem with the software of the PS3 , since the button is working fine on other applications so what you can do here is to re flash.reload the PS3 software update on it to refresh the software inside the PS3 that should correct the problem.
Posted on May 25, 2010
  • 1 more comment
  • Lou Murkowski May 25, 2010
    When I get home tonight I'll go on the site and reload the latest update. Since I do not know if this problem was there prior to the initial update upload I can only assume that something may have been corrupted. Will advise if this works. Tks.
  • Mark Gil
    Mark Gil May 25, 2010
    Yes that is possible that something got corrupted so its really best to reload the software update.
  • Lou Murkowski May 26, 2010
    I'm getting a bit frustrated. Tried to upload current version (3.30) with the PS3. It says it is the latest version and wouldn't allow me to go further. So then I wenty on-line with my PC. Downloaded 3.3 on a memory stick. Tried to upload it to the PS3 and it wouldn't let it happen. Is there any kind of work around to force the updat again? Ideas?
Firmware upgrade
The ISP is correct in telling you not owner upgradeable. Only because the upgrade is their property. The firmware is coded for their cable lines to distribute the power levels through the cable. If you're having intermittent disconnects, you should call them and ask for a LEVEL3 tech to come to check the cable connections from the "TAP" (which is where the cable comes to home), it's possibly needed to rewire the cable and splitters in your home
Oct 31, 2017 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
How do i manually configure my router
Connect the router to a pc using Wlan or Wired lan.
Once the Lan connection is established, open your web browser and type 192.168.1.1
You may get a login screen
The username may be admin
the password differs depend on the model and make
try password or admin in the password field.
Once you logged in you can configure it
The config settings can be availed from your ISP (Ip address, default gateway etc)
Feb 20, 2012 | Trendware TEW-432BRP Wireless Router...
I have a Netgear DG834G v4. Wireless connection is fine, ISP is fine and Internet via wireless is perfect. Nothing via the LAn ports seems to work. Both XP and Win 7 machines see Lan as an undefined...
DHCP SERVER in Router and DHCP server in Wireless Conflicting - Set WI Fi DHCP router leases to say 192.168.0.10 to 192.168.0.100 and default gateway as 192.168.0.1 and on the router set the router's ip address to 192.168.0.1 make the Wi Fi router address 192,168.0.2 . Set in the router the DHCP address leases to 192.168.0.101 - 192.168.0.254 and default gateway 192.168.0.1 or deactivate one of the dhcp servers and rely on one dhcp server like the routers and then deactivate the wi fi's dhcp server.
Jul 28, 2017 | NetGear DG834G 54 Mbps 802.11g Wireless...
Cannot get wirelss connection through my WRT160N wireless router. Was working and now not. I can get internet connection through the LAN ports so I know that the router is working with a fixed cable
by default ip address of linksys is 192.168.1.1
to star config you need to be connected with ethernet cord rj-45
or conenct via wireless by conencting to linksys on wireless
admin user: blank
admin pws: admin
*choose a protocol on your linksys router on internect conenction type:
check isp protocol :
dhcp: needs serail number of mac address
it picks up automatic
pppoe: needs username and pws from isp
*the ip address has to be diferent from the isp modem:
isp modem 192.168.1.1 linksys 192.168.1.1 incorrect
isp modem 192.168.1.1 linksys 192.168.2.1 correct
change the ip on lan settings on your router
*wireless: ssid by default is linksys
ssid: linksys
wep : none
to setup wireless
access the wireless basic
change the ssid to any network name
enable the wireless password
choose wireless security
enable wep key 10 digit hex pws
make shure you saved settings on every setting
May 04, 2010 | Linksys WRT160N Wireless Router
I have a 120 gb silm line ps3 console but a dont no how to hook it up to the internet
If you have a router in place connect the ps3 to it via ethernet cable. If the router is wireless with a WEP or WPA encryption code access the routers login page and get this code. Once you have the cable connected or the code turn on the ps3.
1:>On the ps3 dashboard go to (settings) then scroll down to and select (internet connection) select enable.
2:>Then go back to (settings), then scroll down to the bottom and select (network settings).
3:>Select (internet connection settings). This will bring up your internet setup page.
4:>Now select (easy) method.
5:>Choose wether wired or wireless. If wired skip to 8.
6:>Wireless will prompt you to select a wireless router (make sure you select your router) cause you may find others besides yours.
7:>After your router is selected it will prompt you to select either WEP or WPA select the one that the router uses and then enter the code.
8:>This will bring up your settings list most everything will be labled automatic. Press enter (X).
9:>Then select (test connection)
10:>After it is done back out.
11:>Now use your computer to go to plsystation.com and make yourself a PSN account with a username and password. After this is done.
12:>On the ps3 dashboard goto playstation network and select sign in, then enter your new PSN account name and password.
If you need anymore info do not hesitate to ask.
Dec 28, 2009 | Sony Playstation 3 (PS3) Console
PS3 NAT type 3 issue
HI, Upgrade the firmware on the router and then forward ports on the router for the IP Address of your PS3.
Let me know if you need any further help.
Sep 06, 2009 | NetGear RangeMax WPN824 Router
Lan card toshiba wireless no working
Check this Tip for an overview
  1. Connect your PC to your router using LAN Cable: be sure you can browse internet
  2. If you cannot browse check router config with your ISP
  3. Connect to your router using IP address you find for gateway in Network status
  4. Configure your router wireless section to match with your PC card
  5. Start removing security, broadcast radio signal, create a simple SSID as network name
  6. Check if router network is seen by your PC card (when you disconnect the LAN cable and activate the wireless card)
  7. If connection is established ( near the router) try different location
  8. Reconnect cable and reconfig adding security protocol (WPA-PSK recommended) use parameters compatible with your lan card
Jan 15, 2009 | Toshiba Satellite 5105-S501 Notebook
Will sync but online LED won't work
4 Select the connection type from the Connect Type drop-down menu. ? Always Connected means that Internet connection to your ISP is always on. ? Auto - Triggered by Traffic means your Router will automatically connect to your ISP every time a PC needs to access the Internet. ? Manual - Start in Disconnected means that after re-booting the Router, the Internet connection will need to be re-established manually by the user. ? Manual - Start in Connected means that after re-booting the Router, it will automatically establish a connection to your ISP.
(from http://h20628.www2.hp.com/km-ext/kmcsdirect/emr_na-c02582095-1.pdf )
this sounds like Manual - Start in connected mode will get the ip address and dns settings automatically from the ISP
using adsl on phone line then use pppoe for the protocol
DCHP server has to be set up also and on
The DCHP server ip address range is 192.168.1.20 to 192.168.1.254 with subnet mask 255.255.255.0 and default gateway is 192.168.1.1
pppoe protocol allows the ADSL to connect many computers on the one isp global ip address allocated to your line via using different port numbers to translate the computers internal ip address on the dhcp server through the router.
Jul 01, 2017 | 3Com OfficeConnect Router
Ps3
Are you trying to connect via Wifi or via a LAN (a cord).
If Wifi, are you sure there is a network? Do you have the network key? A network key is basically a 10+ character gibberish password that you get when you set up a secure wireless network... It is easier to connect to a non-secure network, but no one recommends keeping a non-secure network... because its not secure ;)
If LAN, try plugging the cord into a computer, and seeing if the computer can connect to the LAN. If a computer can connect, I see no reason the PS3 wouldn't be able to. If the computer can't connect, verify the other end of the cord is plugged into your router/wall, and that it is securely seated. If a router, unplug the power for 10 seconds, then plug it back in and try again.
May 06, 2008 | Sony Playstation 3 (PS3) Console
Can not connect to router via a wireless connection.
You could try to manually set your IP address in the TCP/IP, the gateway and your ISP DNS
Jan 23, 2008 | D-Link DI-624 Air Plus XtremeG Wireless...
Sony Playstation 3 (PS3) Console Logo
21 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
