Question about Tag Heuer WAF2110.BA0806 Aquaracer Automatic watch
My Aquaracer Automatic doesn't keep exact time
Over a period of 1 month i noticed that my watch is showing +5 minutes time. Because it is a new watch (bought at authorised dealership) i thought i mad a mistake when setting it so i reset the time. After another month it is again ahead. Is this a common problem with Automatic watches? thx A.
You bought a automatic watch, they are a quality time piece, not an acurate time piece. if you want acuacy buy a cheap quartz watch.
Posted on Jul 04, 2008
Hi, I've got a automatic tag aquaracer watch that loses about 4 mins every month (about 4 yrs old). Common problem? Can this be fixed ? Or is it a lemon of a watch? Any advice welcome. Cheers.
If it's automatic and 4 years old, it's probably time for a watch overhaul. Auotmatic watches need overhauled about once every 4-5 years. It's normal for it to lose time, but 4 minutes per month may be a little extreme. So, get the watch overhauled. I would recommend Tag Heuer to overhaul it.
Sep 09, 2011 | Tag Heuer WAF2110.BA0806 Aquaracer...
How to set led watch
What make and model of watch is this?
Sep 08, 2011 | Watches
I have a brand new watch: Tag Heuer aquaracer automatic calibere 5 model WAN2110 and the date is not advancing (as it should every 24 hours). Any reason why?
You are actually supposed to be using a special case opener for this type of watch, however, if you want to open it, always remember, righty tighty, lefty loosy!
I am pretty sure those watches are water proof up to 3 ATM, so once you open that watch, just know, if you don't get the back put on tight, it's going to leak.
Good luck, i know you can do it. Oh, and if you have ever had the watch in for service before, there are ALYWAYS **** watchmakers who like to over tighten the watch cases. My husband is a watchmaker, and we have seen this hundreds of times. :)
Jul 18, 2011 | Tag Heuer WAF2110.BA0806 Aquaracer...
I have an aquaracer automatic and it gains up to 6 - 10 minutes in a day. I have had it fixed before and it was fine for 12 months and now it has started again. Is this normal?
All of the watches I have owned have run for many years without attention and when you buy one as expensive as yours, I would expect similar reliability.
I suggest that you speak to the maker (or contact them via their web site "Tag Heuer.com") and discuss your problem with them.
May 29, 2010 | Tag Heuer WAF2110.BA0806 Aquaracer...
Battery Charge Life 10 years ago, not being able to afford a real TAG, I purchased a 'replica' Aquaracer Automatic in Bali. I am happy to say that I am now the proud owner of a real Aquaracer Automatic....
If you go to http://ww2.tagheuer.com/_documents/manuals/EI2246_en.pdf
you should arrive at the user manual for a Tag automatic watch which is similar to yours (an Aquaracer).
You will see that they claim 38 hour running when fully wound.
In view of the very small forces involved and the variations that occur in the manufacturing of the mechanism, I don't think that you should be surprised if there is a variation in running time.
If your genuine watch runs for a significantly less time thean they claim, you may have a reason to complain.
Date change on my Tag Aquaracer Calibre S
Do as follows:1) At any time of the day pull the crown out and advance watch hands forward for EXACTLY 12 hours ( for example: if it's 6.35 on your watch, then after advancing hands it will be 6.35 again, just minute hand will be forwarded clockwise 12 full circles, while hour hand will be forwarded 1 full circle). Push the crown back in.
2) Pull the crown out to the date setting position and change to the desired date. Pull the crown back in.
Now your watch will be changing dates at midnight continuosly.
Rate me, please.
Apr 06, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
My TAG Aquaracer bezel moves counterclockwise
Yes, there are solution for that, but you will not be able to solve it yourself as the new part is needed.
That new part is called BEZEL SPRING and it is fitted underneath the bezel.
Bezel spring has special hooks pressed into it and allows to turn the bezel one way only (anticlockwise), at the same time stopping the bezel to turn clockwise.
Another cause can be that the dirt and grime are collected between the bezel and the watch case (this is where the bezel spring is located) and is stopping functionality of the bezel spring by leting the bezel slide over the hooks. This can be fixed by cleaning the watch case in ultrasonic cleaner.
Anyway- if the bezel is rotating on its own, I suggest that the bezel spring is broke and you will need to replace it.
Do not forget to rate, please.
Feb 09, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
I have a question for tag heuer 2000 exclusive automatic
The battery power supply will last for two years and if you don't used nothing its happen to your watch..
Regards,
VOTIT
DON'T FORGET TO RATE
Aug 10, 2008 | Tag Heuer WAF2110.BA0806 Aquaracer...
My Aquaracer second hand problem
This is most likely the "battery change indicated" feature of your watch.  Change the battery, and see if the problem goes away.  If it does not, then it could be a problem with the stepper motor, which will require a watchmaker.  Of course all of this is dependent on the assumption that your watch has a quartz movement.  If it is an automatic, or mechanical you have bigger problems.
Oct 19, 2007 | Tag Heuer WAF2110.BA0806 Aquaracer...
Tag Heuer WAF2110.BA0806 Aquaracer Automatic watch Logo
678 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
