Question about Aircat Tools & Hardware - Others
Where can i find parts for an air cat 1000-th
  • 1,675 Answers
Hi try
http://www.aircat.com/
ime sure they will have what you need...please vote thanks
Posted on May 25, 2010
Dash lith
Sounds like the Instrument cluster is shorted out.
here are the service manuals for all Arctic Cat ATVs
Parts House Lawn Mower Parts and Chain Saw Trimmer Parts
Mar 08, 2014 | Arctic Cat 2011 1000 H2 EFI LTD 4x4
Engine runs rough and misses at both idle and accerlation
Water in the fuel Timing out of synch ?
Here are the service manuals for all Arctic cat ATVs
Feb 16, 2014 | Arctic Cat 2014 Wildcat 1000
What are interactive cat toys?
Interactive cat toys are toys that both you and the cat can play together. Laser pointers and cat teasers are very popular interactive toys.
Aug 23, 2012 | Cats
How to replace throttle cable
CALL YOUR DEALER AND SEE IF YOU FALL IN THE RECALL SOME OF THERE YEAR SEDONAS HAD RECALL FOR THROTTLE CABLES . IF YOUR NOT IN TH CAT. THEN YOU POP THE CLIP AT THE TOP OF THE ACCEL. PEDAL AND REMOVE AIR INTAKE HOSE WHICH WILL GIVE YOU EASIER ACCESS POP THE CLIP LOOSE TH THROTTLE BODY BRACKET AND REMOVE CABLE AND PULL THROUGH THE FIREWALL GOOD LUCK
Jan 12, 2011 | 2002 Kia Sedona
My cbr 1000 has 150 psi on all 4 cylinder is firing but has no vacuum at th back of th carborators is leaking fuel from above the gear shifter it trys 2 ...
Hi Ewalker59, for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix or parts inquiry. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. Good luck and have a nice day.
2001 Kawasaki Motorcycle Service Repair Workshop Manuals
Dec 15, 2010 | 1993 Honda CBR 1000 F
I replaced the seals and the wet end leaks right into the motor without even any pressure. I put all the parts back in...did I miss something?
First make sure that you have the correct seal. Then when you install it make sure that th graphite and the ceramic face each other. If it is a 1000 seal when you set the graphite side use a 1" PVC coupling to press it in place. If you don't have even pressure you will crack the graphite. Good luck.
Sep 28, 2010 | Waterway Pump Part Seal Set Ps1000 Cd 319...
'88 Wrangler w/4.2 & Auto Trans. Cat Convert
The jeep has air injection and this is part of the air pump. The cat should have two ports.. These tubes should have check valves to prevent backfire.Usually their routed up on both sides of motor and attached at the air cleaner abouts
Nov 05, 2009 | 1988 Jeep Wrangler
To much oil was put in truck and now were told
To diagnos the catalytic converter, remove exhaust Y pipe from exhaust manifolds and start up. If engine runs goood and revs up, then suspect a restriction in your exhaust. Exhaust shop should be able to fix the problem. Cannot repair the cat converter. It is a honeycomb of metals inside that superheat the exhaust and burn off any unburnt fuel. When the honeycomb melts from contamination then it blocks exhaust air flow.
Mar 11, 2009 | 1998 Dodge Ram 1500 4WD
Tools & Hardware - Others Logo
147 people viewed this question
Top Aircat Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you an Aircat Tool and Hardware - Other Expert? Answer questions, earn points and help others
