Question about Maytag MGR5750 Gas Kitchen Range
Oven will not keep temp.
I have a Maytag gas oven MGR 5720, 30 or 50. It is about 10 years old. The oven heats to temp but then does not retain the temp. It will not re-ignite to keep at temp. The only way to get it to work is to shut it off and cool down and start over.
SOURCE: Maytag MER6772 - Oven bake element not working even after replacing it.
To find service information for your Maytag Model go tothis link
http://www.servicematters.com/
When on this site, click on Maytag Historical Service Library.
Then click on Maytag Service Library.
Click on term and conditions
Click on Literatur by Model
Enter Modle number MER 6772
Clck go
You will be able to print or download the service manual for your model
Your problem may be the bake relay on the clock or wiring.
Posted on Feb 09, 2008
SOURCE: Oven will not maintain temprature
This is a parts problem, I think called the burner ignitor. It is a pn oven part. We have had it in the past and are experiencing it again. We have had our stove for about 15 years, so I guess it is not too bad a problem, but not inexpensive. The oven is letting the gas be off too long between reignitions, so it does not maintain temperature. The first time we realized the probelem was with the Thanksgiving turkey (pink in the joints.)
We had to have the part replaced about 7 years ago and the part was about a $200 part plus service call. I am sure it more costly now. Hopefully you can get yours under warranty.
Posted on Dec 14, 2008
  • 71 Answers
SOURCE: Oven will not bake, but broil works
the bake ignitor is most likley bad
Posted on Dec 24, 2008
shinn8
  • 85 Answers
SOURCE: We have a Maytag Gas Range, Precision Touch
Likely your oven igniter is bad. Part number 74007498
Posted on May 18, 2009
  • 10865 Answers
SOURCE: oven takes a long time to heat up.
Hello. To go 12 years without issues is excellent. Now however you will have to make a decision to repair or replace. Be sure to get a firm estimate before you repair and compare that to the cost of replacement.
here is what may be causing your problem:
Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
Other causes Other reasons that your oven may not bake are:
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
Posted on Aug 15, 2009
Strong gas smell when oven is on
Bad heating element. Needs to be replaced. Depending on what you plan on replacing it with...call appliance repair shop with you model info and ask for quote to replace heating element.
Feb 10, 2013 | Kitchen Ranges
Have Maytag MER5755QAW range, the oven will not heat up, the display was working isn't now, i check both elements and temp sensor, all ok
The display control will need to be replaced. It may be cheaper to replace the unit since the control is so expensive. Here is a link to the part you need.
Keep me posted!
Jan 21, 2013 | Maytag MGR5880BDS Gas Kitchen Range
My Maytag stove. I know it's normal to feel heat from the vent on the stove top when the oven is on. But the temp of the heat escaping is sooo much hotter than it used to be. Do I need a fix ? Model...
The heat from your vent should be a little lower than what the oven is set at. So I doubt if you have a problem but you might want to take some temperature measurements to see.
Sep 07, 2011 | Ovens
We are having problems with our GE xl44 gas oven holding tempture and not pre heating very fast. The oven heats sometimes and then won't re-light to keep it up to needed temp. We have looked on some sites...
if that glow plug didnt work the oven wouldnt heat at all. i had one of those for about 10 years and replaced 4 of them. the oven on the thing never held the temp right and the control panel died after about 6 years... tossed it out and got an lg now. lets see how that goes. sorry i dont know much else to help you...good luck
Jul 22, 2017 | GE Profile Spectra JGB910 Gas Kitchen...
Oven takes forever to pre-heat and then doesn't keep the temp constant. turning on stove burner helps sometimes, and sometimes it works fine. do we need new thermostat or...? not sure if i have right...
Very common problem, I would replace the oven ignitor first as they get weak with time and cause intermittent burner lighting. Good Luck, Appliance Specialists
Dec 31, 2009 | Maytag MGR5750 Gas Kitchen Range
Kenmore oven doesn't keep heat
im going to assume it is gas.. you may have a bad ignitor.. it is not gettin hot enough all the time to ignite the gas.. eventually it will not lite it at all..
Feb 15, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Maytag oven won't stay at temp.
new ignitor is you problem part number 1240035, wont reignite after reaching temp, common issue with all gas stoves
Nov 10, 2008 | Kitchen Ranges
Maytag MGR5750 Gas Kitchen Range Logo
149 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
