Question about HP Pavilion dv9420us PC Notebook
After turning on the laptop the screen does not turn on The screen is black and the lights are on
    Scholar:
  • 64 Answers
This is a somewhat common problem with hp notebooks that I see and work.
Some questions to consider:
Do the lights stay on, along with the fan?
If so, it is possible either the motherboard or the screen have issues.
Do the lights flash?
If so it is almost always the motherboard.
Does the computer beep when powered on?
If so, the ram is probably the issue.
Does the computer work with an external screen?
This can eliminate the possibility of a bad laptop lcd.
For the first two, I would have to recommend having the machine tested. If it works with an external screen testing can be done easily with UBC or some other bootable testing environment. If not, I would say take it to a repair shop.
If it beeps, try taking out the ram, blowing out the ram slots and replacing the sticks. This may help. If not try taking out one stick, and then if still not working, switching and taking out the other.
//halfs
Posted on May 25, 2010
  • mkapuscik Nov 11, 2010
    I have the same exact problem as well as many others who purchased dv9400 series laptops. The cause is due to a faulty NVIDIA graphics chipset. I've been trying to get HP to help me with this problem with no satisfaction. Thankfully, I ran into a post today where there is a class action lawsuit brought against NVIDIA (NVIDIA GPU Litigation, Case No. 08-cv-04312-JW) The final court date hearing is scheduled for December 20, 2010. If awarded, the Claims Period will not begin until after the Final Hearing. Please go to "NVIDIA GPU Litigation" website for more info. If awarded by the Judge, it looks like you will need to fill out a claim within 60-days of the final hearing date.http://www.nvidiasettlement.com/
    There are many different series of HP laptops that are included in the litigation along with a couple of Dell
  • 973 Answers
You could have a dead hard drive or graphics card.
2 Suggested Answers
bhagyavichar
  • 414 Answers
SOURCE: laptop turns on but screen stays black
probably itz either minor case of software corruption/improper ground/cpu fan..
or major case of faulty or defective main board/ram/addon/daughter cards..
..plz do check the following as in order:..
the Hardware part:..
1)a) in power-on mode, open/unplug the data/vga cable of the monitor from cabinet..see if raster or 'osd' is appearing on the monitor screen..if so monitor is ok..else replace the monitor and see..[not applicable in case of laptop]..
b) in case of laptop try to get output from external display unit/monitor using vga port..if there's proper display in there..the problem is probably with either the 'lcd' or 'ccfl' or 'inverter circuit'..
2) if u hv a graphics card, replace with a standby or onboard and see..[not applicable in case of laptop]..
3) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
4) see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
5) a) see if ur hdd is noisy or emitting any 'ticking' noise (like 'tuk tuk' or 'kirr kirr')..
b) or if the system is not supporting either the newly installed device or itz software/driver /firmware
if so, u need either a fresh os installation or ur hdd is likely to b replaced..
6) remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
7) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market)between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
8) on main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(espabove1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)..
9) [in case of desktop] the smps itself may b defective/faulty..check the outputs of smps viz. 0v (black~ground); +12v(yellow); +5v (red, green~ps-on, violet~pg& grey~sb); -12v (blue);-5v(white); +3.3v(orange)..the 'oscillator and error amplifier ic',or pwm switching regulator circuit..look for defective protector-transformer/resistance (esp 4.7k)/mosfet..
check the battery n adapter [main power], in case of laptops..
for any further assistance u may plz leave comment and or testimonials at any point of time, so that i/we can help or u think it to b helpful..
if u r not a professional, always better to seek advise from ur system admin/vendor....
Posted on Nov 23, 2009
Black Screen with 3 Beep Tones !
Return the laptop to the place of purchase because you still have warranty coverage, any tampering will void warranty.
Apr 08, 2012 | Sony VAIO Computers & Internet
When i turn it on it wont show desk top it stays on a black screen
Does your laptop have its lights on the keyboard even if your screen is black? If it is , try to remove the cables and battery of the laptop. Press and hold the power button for 8 seconds. Then reinsert the cables and battery on the laptop. Turn on the laptop, and if there is no light on screen & keyboard, it means that the power supply or the motherboard has trouble. That is the time to contact Dell support for possible repair or replacement. Otherwise if the keyboard has lights but the screen is still black, that would be a video card problem since the LCD screen is not a separate entity. Just make sure if it has the power button on the screen, it is turned on. That instance would need a video card replacement...
Jul 12, 2010 | Dell Inspiron 1000 Notebook
Hi my screen is black when I turn on my laptop.
ysounds like you either have to replace the backliught tubes and/or the circuit board that runs the backlight tubes.backlight tubes are available on ebay from a gentleman in oklahoma city oklahoma
Jun 23, 2010 | Dell Inspiron 710m Notebook
Laptop has a black screen no picture.
It sounds like the back-light in your laptop's LCD screen has died. If you turn the laptop on, and hold the screen up to the light, you may be able to see the operating system and windows, but since the screen isn't emitting any light, it appears to be off or all black. If this is the case, you'll need to either replace the back-light, have the laptop repaired, or replace the whole thing. There's no easy fix for a dead back-light.
Mar 04, 2010 | Dell Inspiron 1200 Notebook
Computer turns on but screen stays black
This is often caused by the screen lights or screen failing. Try looking at the screen from different angles in different light conditions, you might just be able to see the image.
Oct 02, 2009 | Dell InspironTM 1501 Notebook
My laptop screen is black
Try reseating the memory, if that doesn't work then take the battery out and only hook up the ac adaptor then turn on the laptop to see if you get video.
Feb 05, 2009 | Acer Aspire 5050-3242 Notebook
Black screen
When you say it turn black, could you try to see that ther are
still picture on it(maybe you've black light problme)...or just completely black .And do your laptop have any activity...say harddisk light still flashing,..etc..
Bye,takecare.
Apr 18, 2008 | HP Pavilion dv4000 Notebook
Acer laptop has black screen but power light is on
Does it appear to be doing anything. Is there a flashing "_" at the top left of your screen. If not try hooking a monitor up externally and turning the laptop on.
Dec 23, 2007 | Acer Aspire 3610 Notebook
HP Pavilion dv9420us  PC Notebook Logo
124 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
