Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
Picture expands past frame
Aloha
my kids were playing with controler and now every channel we watch has peoples heads missing, etc. my view mode wont correct it. please help
  • Anonymous Aug 28, 2008
    i have the same problem, but i dont have those buttons on my remote.
    we tried pushing almost all the buttons but it didnt work
  • 124 Answers
Look for a "zoom", "format", or "aspect ratio" button on your remote. Pressing will scroll through the types of display.
Posted on Apr 09, 2008
Hi, my RCA CRC311 BT turns on my Sharp television, changes the channels, etc, but it won't switch to video mode, even when I hit input. It is an old TV, but I used it to watch videos, dvds and play games...
Unfortunately you will not be able to switch input.
I also have a Sharp, I have tried 5 different universal remotes. None will switch input. I guess that function is not provided properly.
Sep 18, 2010 | RCA RCR311B Remote Control
Expanded screen
If it only does it via the coax or cable fitting it may not be the set.
Does it do the same thing when playing a DVD etc?
If problem is on all inputs it is a deflection problem in the set which for whatever reason has over scanned the picture to tall---it suggests a problem in the Vertical deflection circuit of the set (top to bottom is vertical deflection).
SD TECH
May 02, 2010 | Hitachi 57F500 57" Rear Projection...
Picture is to big for screen
Menu go to setup,go to reset,well be back to factory setting.U will have function to view mode,not than ur video backlight board have problems.
Apr 30, 2009 | Sharp Aquos LC32D41U 32 in. LCD TV
TV is stuck in expanded picture mode & won't return to normal
seems to me as a Sony TV. The sony tv has this feature ready in the menu. you can do zoom out ,standard etc,
But the real problem comes when the tv is turn off and then you get back to turn on the tv (lets say next day)and you find the same big heads.
what you have to do is going to the menu same thing but this time look for an option is called picture size default. This option make learn the memory what size you want custom when tv is turn on.This function is in the same page as the picture size page (refer to the user's manual) but has to be the default mode where you want the change.
The problem with sizes now days is some shows fit perfect some others not. and besides that the cable box has those features too(change size of the screen)
What i do in this sony tv to start first is keeping it in the standard size in the tv menu and i defaulted too.
when some size adjustment is needed i do it in the cable box remote control .Once again this example i do it in SONY tv, Maybe you have to post the problem again if the tv is different brand.
Apr 15, 2009 | Hitachi 51F59 51" HDTV Projection...
I like a speed hack crossfire
First, learn to use google search. Second, skill>hack. Obviously you are a little kid, and little kids like hacks because they have no skill, but if you spend enough time playing a game, you learn the level, your gun, the routes the other team takes and how to make controlled bursts at someones head. Remember, one shot to the head out of three bullets that missed will still kill a person. Six bullets in the legs will not. There, take my little helpful advice and stop ruining games. Fortunately, no one has an invincible hack, so you'll still get killed by people like me. Enjoy.
Apr 13, 2009 | Computers & Internet
Flash animation
Most people use Flash MX to make flash animation, it is made by drawing pictures frame-by-frame and play it. It takes a lot of time to make a ten-second video. Check out my youtube channel to see it for yourself: http://www.youtube.com/linkevin1248\
for more information, contact me.
addition information: http://en.wikipedia.org/wiki/Flash_animation
Feb 16, 2009 | Avanquest In-A-Flash Animation Suite Full...
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
Driver
necesito descargar gratis driver para camara genius dc 2110
Jun 12, 2008 | D-Link VisualStream DSB-C310 Webcam
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
Aquos-52d62u picture cut off
Look for a format button on the remote or a zoom button. If you find it, press it. Most TVs have several options of format that you would scroll through with each push. If it is a Dish Network remote, use the format button "*" at the bottom left, if it is DirecTV the format button is top left, second button marked "Format".
Apr 07, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
114 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
