I'm trying to eject VHS and DVd after recording the VHS to DVD. The screen tells me it complete and to plug it into PC. I don't know how to by pass the PC and have lost the instructions. Can you help me?
    President:
  • 1,950 Answers
Which model and brand is your DVD recorder?
Posted on Apr 07, 2008
    Genius:
  • 1,142 Answers
Can you give more details please
  • Anonymous Apr 07, 2008
    Please provide the details of which model of dvd and vhs recorder you are using i mean the hardware description.
  • Anonymous Apr 08, 2008
    Best solution will be to turn off the devices and turn it back on this way you will be able to eject the dvd and the vhs tape too.
SOURCE:
Could not finalize disc because of error detection
First try reinserting, but it's probably hit a bad spot.
Might be useable as a data disk. Do a complete format which will lock out the bad spots.
Jun 15, 2012 | Samsung DVD-VR330 VCR and DVD Recorder
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
I hadnt used my machine in a while. I went to transfer from a VHS to DVD Loaded both - no problem After finishing the transfer the I couldnt get the DVD to eject Help please
Did you follow directions on how to transfer VHS to DVD ? When the dvd is finished copying it MUST!! finalize the copy. If you attempt to eject DVD while in FINALIZING it gets stuck. Try and unplug the power for about 1/2 hour. plug in and eject. p.s. read the manual....the machine is complicated!!
Aug 11, 2011 | Panasonic DMR-EZ48 DVD Recorder
I DON'T KNOW HOW TO RECORD
Well it depends on what you're recording. If you're trying to record from the T.V. your going to have issues because of the recent switch to digital. If you're recording from homemade VHS to DVD however just put in your VHS, then your blank DVD and hit record. There should be some on screen instructions displayed.
Hope it Helps! -Joe
Also you'll probably also have issues trying to convert your old VHS movie collection to DVD because most of the movies would probably be copyright protected.
Jun 07, 2011 | LG XBR446 DVD Recorder/VCR
I am trying to copy a VHS to DVD from a VHS player. I have a Sony VRD-MC6 multi-function DVD Recorder. I am using the A/V cable and have verified that they are correctly placed. The Sony player will...
Is it possible the VHS you're trying to copy is copy-protected? Apparently, the MC6 displays "waiting for signal" when you're attempting to copy a copy-protected (commercial) video. I had success converting my own homemade VHS tapes. I just bought my MC6, and thought I'd pass along some tips I got from others: You know you're recording when a red ring around the large Record button lights up and it actually says "recording" on screen, and adjust HQ to SP to get 2-plus hours of video on the DVD.
Jan 24, 2011 | Sony VRDMC10 DVD Recorder
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
Pre-recorded dvd won't eject/entire system frozen
Try unplugging the machine so it will reset itself. Then plug it back in. That has worked for me in the past.
pjrsop
Mar 24, 2008 | Samsung DVD-VR357
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
Dvd to vcr?
Plug the DVD connections into the INPUT on the back of the VCR. This is sending the signal from the DVD player INTO the VCR.
If you are familiar with the VHS to VHS, then remove the VCR and replace it with the DVD player.
I hope this helps :)
If the question changes it will send me an automatic message. So if this was not enough info, just let me know! I'll actually hook mine up to record this way then I'll be able to tell you step by step if need be.
Jan 11, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Can't view DVD's burned from the tv on a DRC8335 RCA DVD recorder
If you do not finalize the disc then you can not play it back. Go back to your instruction manual and look under 'setting options'. There should be a choice to 'finalize disc before ejecting'. The recorder will not finalize a disc until it knows when you are done recording, so you have to tell it somehow.
Jan 02, 2008 | RCA DRC8335
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Ekse
