Question about iLO 3200 32 in. LCD Television
Jumpy screen as a monitor
I bought a used ilo 32" lcd. i hooked up my ps3 through the hdmi and it looks great. i hooked up my computer through both the s-video and then the composite video. both hookups give me a jumpy screen . it just jitters and the icons and the text arent very clear. screen is jittering right now. i have an nvidia gforce video card.when i use my regular crt monitor the picture is great. any suggestions
    Genius:
  • iLO Master
  • 1,673 Answers
There are a number of things that can cause the problem:
The frame and scan rate from your computer is not matched to the specs of the monitor. The monitor may have a sync lock fault.
LCD monitors must be operated in their native mode for best results. Some models are very critical for the frame and scan rate especialy when using a composite video source.
If you take the monitor to the service rep for it, the should be equiped to diagnose it and tell you the exact answer.
Jerry G.
Posted on Apr 17, 2008
How do i fix when i hook up hdmi cord and the screen wont display and when i hook up vga it does but i want hdmi for my ps3?
You must have to make setting in your ps3 and Display device. Set the display device at auto option for input source. It may be set at VGA. that why you get output of VGA but it does not display output from ps3
Mar 30, 2015 | Hannspree HF199H 19 Flat Screen LCD...
Ilo won't work with ps3
The set receive no signal at all. It will be best get it repaired by any experienced service technician.
Apr 22, 2012 | iLO 3200 32 in. LCD Television
I bought a hdmi cord so my son can play ps3 we
Hi:
Check the video connector on the PS3 for a switch to switch from composit video to HD video.
Dec 26, 2009 | Vizio VW32L 32 in. LCD HDTV
HDMI audio lags behind video on iLo 32" LCD television
Check the tvs settings menu. There should be a HDMI sound option which will fix the delay.
Nov 30, 2017 | iLO 3200 32 in. LCD Television
Blank Screen using HDMI-DVI cable for PS3
Sounds like your LCD monitor isnt HD compatible.
Mar 17, 2009 | Hanns.G Corporation HW191D 19" LCD Monitor
Westinghouse 26" tv SK-26H730S HDMI screen blinks with Dell Comp.
try using the 27 pin monitor input instead the hdmi possibly has a frequency variance
Mar 01, 2009 | Westinghouse 26" LCD Flat-Panel HDTV
How do i hook up my ILO TV to direct TV satelite?
i have a ilo 32 in hdmi hdtv and i have mine hook up to direct tv .on the back of the receiver plug your red,white and yellow into the audio 1 of the direct receiver. on the back of your ilo tv plug the other end to the av1 and use S-VIDEO ALSO. plug the sat cord to the ant.in. on the tv set remote hit video and go down to s-video and hit ok. you need to plug all three plugs into their color ans the s-video too in the AUDIO section. mine works great !
Dec 30, 2008 | iLO 3200 32 in. LCD Television
PS3
bad cable or bad port on tv. Test it. Get another set of HDMI and test it to see if it works. If it doesn't then the port on your tv is bad.
Oct 24, 2008 | iLO 3200 32 in. LCD Television
Ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Jul 31, 2007 | iLO V27DMBX Television
iLO 3200 32 in. LCD Television Logo
725 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
