Question about Holmes Products HM5250-UC Humidifier
Humidifier does not reset
My holmes HM5250 is giving me trouble :( I was very happy after getting it recently.It was working fine for 1 month. However, recently the unit is not able to reset. I have tried filling the water in the tank couple of times. But, the reset bulb still keeps glowing.
  • rberg460 Sep 17, 2008
    The humidifier ran fine just out of the box. But the very first time I had to refill it, I couldn't get it to run, although I followed the reset instructions repeatedly over a period of *hours.*
  • Anonymous Mar 16, 2009
    same
  • 123 Answers
According to Holmes, one of the causes of the Reset light staying on is scale buildup on the heating element.
Remove Scale: Allow to cool before maintenance.
1. Repeat steps 1-5 in the Daily Maintenance section.
2. Clean the base by partially filling the base with one
8-oz cup of undiluted white vinegar. Let solution stand
20 minutes, cleaning all interior surfaces with a soft
brush. Dampen a cloth with undiluted white vinegar
and wipe out entire base to remove scale.
3. Rinse with clean warm water to remove scale and the
white vinegar solution before beginning to disinfect
the tank.
4. Wipe the heating element clean with a soft cloth after
it has had chance to cool.
If the scale has really built up it might take longer than 20 mins for the vinegar to get rid of it and you might need to refresh with new vinegar.
Your Manual can be found at this link:
http://www.holmesproducts.com/Manuals/Holmes/HM5250-UC_English.pdf
Good Luck.
Posted on Apr 18, 2008
SOURCE:
Need manual for Holmes humidifier model HM-220. Don’t see replacement filter numbers on Amazon. Is there another that will work
For a manual, try Googling (holmes)(HM-220)(manual) without parens.
Fixya is unable to advise regarding filter interchangeability.
May 12, 2018 | Humidifiers
What happens if the humidifier runs out of water? Humidifier is new and working fine. I Does the humidifier shut off automatically when it runs out of water?
The humidifier has a float valve in it much like a toilet tank does. If the water gets to low, the float valve should allow more water to enter the tank automatically. When it reaches the proper level, the float valve stops the water. The water line (either copper or plastic) coming into the humidifier should have a shutoff valve on it. Make sure that it is turned on.
Feb 02, 2011 | Holmes Products HM4600-U 11 Gallon...
Need new rubber tank gasket for Holmes humidifier Model HM4600
after scouring the INTERNET AND FINDING PLENTY OF SITES THAT WOULD SELL ME THE WHOLE CAP FOR 24.00. I MAD MINE USING SOMETHING FROM ace hardware THAT COST 2.50 Small suction cups with the hook [CDBL-7500S11] PART NUMBER 7500 .CAN BE MODIFIED INTO MAKING YOUR OWN GASKET. IT WORKED FOR ME ..REMOVE HOOK FROM SMALL SUCTION CUP. cut off nib with sharp pair of scissors. THEN DRILL HOLE THROUGH CENTER OF CUP WITH 7/64 DRILL BIT. re insert plunger part of cap through cap with spring and re- attach suction cup instead of gasket. MINE WORKS FINE ON A HOLMES 3700
woodinvirginia
Jan 23, 2011 | Holmes Products HM4600-U 11 Gallon...
How many watts is Holmes HM5250-UC 2.5 Gallon Warm Mist Humidifier?
volts x amps= watts
the amps is on the rating plate of the unit next to the model and your volts may vary 115-120
Dec 02, 2009 | Vicks V150 Humidifier
Reset light on holmes product hls5000 humidifier
turn knob to reset....leave 15 minutes and then turn on
Jan 03, 2009 | Holmes Products Halls HLS5000-U Humidifier
Wondering if damage to Holmes HM500 humidifier is fixable...?
unfortunately running the unit for too long will permanently ruin the unit. there isn't really a way to fix it. i do deeply apologize for that. so unfortunately you might have to replace the unit.
Nov 22, 2008 | Holmes Products HM500-UC 1 Gallon...
Holmes HM4600HD humidifier tank
Mine dried out too. I could not find where to get the rubber valve seal for the tanks. Holmes does not list the part and when I called the rep told me they didid not stock the part. I solved my problem by purchasing thin rubber washers from Lowe's. They are 3/16 X 1 1/4 X 1/16 thick. The 3/16 hole in the center "snaps" on over the end of the plastic plunger just like the original. I had to trim the outside diameter with scissors to about 1" or using the old ones as a guide. Cost me $0.67
Nov 09, 2008 | Holmes Products HM4600-U 11 Gallon...
Will not reset
Per the operators manual you have to reset it. 1. Unplug the unit
2. Remove and refill the water tank, being sure to follow the Daily
Maintenance Instructions. Replace the tank onto the base.
3. Wait 5 minutes for the Automatic Shut-Off to reset.
4. After the 5 minutes, plug in the unit and turn the unit on to HIGH
(HI). The RESET light should now be off (if not repeat steps 1 through
3). In about 2-3 minutes, the humidifier will begin to produce
moisture.
Jan 03, 2008 | Holmes Products (048894556579) 4 Gallon...
HM5081TG Reset Light won't turn off
Reset the unit once it is refilled by pushing the power button and holding it down for 5 seconds before releasing. This should reset your unit to factory settings.
Oct 21, 2007 | Holmes Products HM5080-U2 Humidifier
Holmes Products HM5250-UC Humidifier Logo
1,335 people viewed this question
Top Holmes Products Humidifiers Experts
Ekse
ray gallant
ray gallant
Katherine Guy
Level 1 Expert
Are you a Holmes Products Humidifier Expert? Answer questions, earn points and help others
