Question about Philips Magnavox 9P6034C 60" Rear Projection Television
60" Phillips HDTV Rear Projection
My 60" Philips HDTV Rear Projection TV gives a slight double image or ghost image to the items in the picture and any letters that appear on the screen give a severe double image and the scrolling words that appear on the bottom of the screen such as sports scores or news flash messages are really bad and as the words scroll across the screen they start to rise up and then go back down like they are traveling over a hill. Any suggestions?
  • Philips Master
  • 8,617 Answers
You need new convergence ICs two of them numbers STK392-110 they are available at the following link and they provide free installation instructions with pictures as well as free online tech support while you do the repair which takes about an hour. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Apr 07, 2008
6ya staff
SOURCE:
I have a Phillips rear projection tv model number 60PP9202/17F.....it 60
What is the problem of your
Phillips rear projection tv model number 60PP9202/17F?
Jan 10, 2012 | Philips 60PP9202 60" Rear Projection...
Double images-picture on tv is in unalligned red and green colors
You need the Phillips DPTV305 - DPTV345 Chassis convergence repair kit which is available at the following link. the kits contain the parts and detailed instructions on how to do the repair.Just click on the phillips repair kits page.
http://tvrepairkits.net/
Jun 23, 2009 | Philips 60PP9202 60" Rear Projection...
No picture
Replace BOTH of your STK ICs will have part number on them they are big black ICs.
Feb 18, 2009 | Philips 60PP9202 60" Rear Projection...
I have a phillips 60 inch projection tv double picture
Yes its the convergence ICs. You will need ywo STK392-120 ICs and about six of the 6.8 ohm 1watt metal resistors to repair the issue. You can get replacement ICs and resistors at the following link and they will provide free instalation instructions with pictures so you can easially do the repair yourself and save about 400.00. Here is the link.
Jul 10, 2008 | Philips 60PP9202 60" Rear Projection...
TV Color
You need to replace both convergence ICs they are both STK392-120 and you will also need four 6.8 ohm 1 watt metal film resistors. You can get the ICs and resistors at the following link and they will provide free instalation instructions with pictures so you can do the repair yourself. Here is the link.
Jul 04, 2008 | Philips 60PP9202 60" Rear Projection...
Green outline
dm21,
This particular unit has a common problem with coolant contamination. It is slightly possible - only slightly - that the focus block needs adjusting, but I'd first suspect coolant contamination... This is one job I would recommend that you attempt. On a scale of 1 to 10, and ten being the most difficult, this is a 10 even for a qualified shop with all the best of equipment.
My advice, take it in and have it repaired...
Bill
Nov 19, 2007 | Philips 60P8342 60" Rear Projection...
Getting a yellow to blue double image on the items in the picture and when you change chanels the chanel information displayed on the screen is doubled. Was working fine 24 hours ago.
Convergance ic are bad.
there are some resisters that should be checked
heres some diy sites.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hometheatershack.com/forums/manufacturers-service-support/5600-crt-based-rptv-convergence-repairs.html#post43725
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Nov 01, 2007 | Philips 60PP9202 60" Rear Projection...
Scrambled picture when cable box is hooked to hdtv plugs on philips 60 inch rear projection tv
My hdtv component jacks will give a clear pic then pop back and forth into double images. Can anyone help?
Oct 03, 2007 | Philips 60PP9202 60" Rear Projection...
Ghosts in Tv Projection TV
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Aug 02, 2007 | Philips 60PP9352 60" Rear Projection...
Ghost images
Sounds like a light engine issue to me. Is there anyway you can post a picture of the issue itself?
Mar 28, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
214 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
