Hansol H950 19" LCD Monitor
Hi :)
I have a problem, i purchased the Hansol H950 19" LCD Monitor and it doesnt work. the screen go's black and if i press the source button it flashes on and off and sometimes i can see my desktop. It does this on other computers i plug it into aswell.. how can i fix this?
If you can help me that would be amazing :) I really appreciate this
Sincerley,
Alex
Thank you
  • Anonymous Apr 18, 2008
    I have the same problem
    Guru:
  • 1,342 Answers
Posted on Apr 09, 2008
  • 4 Answers
Hi, the hansol H950 uses a power supply combination inverter board. No. FSP048-3PI01 The electrolytic capacitors go bad quite regulary.The most common ones that go bad are 1000uf-10v and 470uf 25v. There are a total of 5 of these on the board. If you can solder it shouldn't cost over $10. The next thing to check would be fuse F1 4A 125v microfuse. if it is open (ie blown) you probably have a short in the inverter section of the board (4 ic's underneath the board) Solution....replace the board.
A new board can be had for around $100
Posted on Jun 04, 2008
6ya staff
SOURCE:
Hi, My Hansol H550 used to come on when my PC tower was booting up, but now I have to press the green on/off button. BUt unfortunately, after pressing the on off button the screen only comes on for a split...
Sounds like there is no input to the monitor. Check the video cable(the one with the screws). Even if it looks plugged in, unplug it and replug it at both ends.
Feb 27, 2011 | Hansol H550 15" LCD Monitor
Brightness
open the monitor you will look big black part called EHT you will see the movable shaft on it rotate it by screw driver in active supply monitor see on screen suficient brightness and stop you will be satisfied
Nov 21, 2008 | Hansol 500 A Monitor
H950
The backlight power supply in the H950 series suffers from a manufacturing defect. Hansol might replace the unit even if it's not covered by warranty anymore. Contact them.
Otherwise (and if you have electronics skills), replace the electrolytic caps in the monitor's power supply. Take proper high voltage precautions!
  • Disconnect mains
  • Wait at least one day for caps to discharge a bit
  • Remove monitor stand (four screws)
  • Put the monitor face-down on the table, plugs facing to you
  • Remove back cover (snap-in, difficult to open without minor damage) - be cautious: front buttons are connected using a rather short cable, do NOT try to remove front cover
  • Remove EMV casing screws (four screws) and ground wire
  • Disconnect CCFL tubes (four connectors), noting connector orientation
  • Disconnect front buttons pcb
  • Lift EMV casing side facing to you
  • Disconnect power supply board (left) from signal board
  • Unscrew/remove power supply board - caution: C12 is likely to store mains voltage even after days!
  • Replace caps (C34 and C66 are likely failure candidates for IPHS19-S rev1.2 boards; you might also replace C31, C32, and C35 while you are at it) - higher voltage and temperature rating are okay, capacity has to match
  • Assemble everything again
Nov 10, 2008 | Hansol H950 19" LCD Monitor
Hansol H950
  • Disconnect mains
Jun 26, 2008 | Hansol H950 19" LCD Monitor
Spare parts
The best bet is to try ebay.
What do you mean by control panel? the part that does all the power or stuff?
May 31, 2008 | Spa Parts Plus PANEL, TOPSIDE, DUPLEX...
Some of those monitors have had a problem where the large HDMI cable attaches to the back of the monitor. Try inserting the HDMI cable then instead of tightening the screw supports power up the monitor and wiggle it slightly if the monitor works then the problem is in the connector and may need to be resolderd on the inside. have you tried using another HDMI cable to rule out that the cable itself isnt defective?
Apr 07, 2008 | Hansol H950 19" LCD Monitor
Hansol H950 19
Most likely the power supply, or the back-plane lamps, or the back-plane supply, or a defect on one of the processor boards is loading the supply too much, or any combinations of these are defective. You will have to have a source to try the boards to fix the monitor. I would suggest to find the authorized service rep for your monitor. They will have to service it for you. If the monitor is out of warranty, the fix will not be cheap!
Jerry G.
Hansol Mazellan 500A is it not compatible with 128MB Video Card?
your monitor does not support the screen resolution that your windows install is set to. hook your pc back up to your computer guys monitor, and reduce the screen resolution, then hook it back up to your monitor.
Jan 08, 2008 | Hansol 500 A Monitor
Open Questions:
how to reset BELLSOUTH password #{18OO~8O31O69} phone number There are two circumstances that can cause someone to want to change his/her BELLSOUTH password: 1 forgetting the BELLSOUTH password and needing to recover it and 2 to change the BELLSOUTH password. The latter can be because the BELLSOUTH password has leaked to someone or the user wants to adhere to the good practice of changing his/her password periodically. It is a good practice to change one's BELLSOUTH password at least once in a month. Contact BELLSOUTH Mail Password Reset 1-8OO-8O3-IO69 . For your convenience to contact BELLSOUTH Mail Password Reset We have provided all possible information of BELLSOUTH Mail Password Reset. You can contact BELLSOUTH Mail Password Reset on the given phone number 1-8OO-8O3-IO69. Changing an BELLSOUTH Password The following steps show in detail how to change an BELLSOUTH password when the current password is known: Sign into the BELLSOUTH Mail Account from BELLSOUTH Do you want to recover/reset your BELLSOUTH email password? So you'll be do the some steps to recover your BELLSOUTH password. We'll help you to fix your problem and we'll guiding the some steps to recover your BELLSOUTH password. Follow and do the below steps to recover your BELLSOUTH email password- Go to the BELLSOUTH - login page. Enter your Username or Email address and click next. Click Forgot Password below the Password field. Enter your Email address and click Next. Verify your Email address or Phone Number and click on the Next. Open your Email account and check your BELLSOUTH mail message on your Gmail account. BELLSOUTH is an abbreviation for America Online, one of the country's earliest providers of internet and email services. While BELLSOUTH's dial-up internet is not as widely used as it once was, many people still use the company's email service. It's a great email service that lets you stay connected with your family and friends -- that is if you remember your password. Forgetting your password on any internet service is an annoying and sometimes painful process; thankfully, BELLSOUTH has made it easy to recover or reset your account's password. *Please Read* If you don't remember or didn't sign up with one your alternate email address, or you didn't use a mobile phone to register, you will not be able to reset your BELLSOUTH password. If you find yourself in this situation, create a new account. If you do have access to your alternate email or mobile number, follow the steps below to reset your BELLSOUTH password.
Oct 23, 2019 | Internet Computers & Internet
how to reset CHARTER password #{18OO~8O31O69} phone number There are two circumstances that can cause someone to want to change his/her CHARTER password: 1 forgetting the CHARTER password and needing to recover it and 2 to change the CHARTER password. The latter can be because the CHARTER password has leaked to someone or the user wants to adhere to the good practice of changing his/her password periodically. It is a good practice to change one's CHARTER password at least once in a month. Contact CHARTER Mail Password Reset 1-8OO-8O3-IO69 . For your convenience to contact CHARTER Mail Password Reset We have provided all possible information of CHARTER Mail Password Reset. You can contact CHARTER Mail Password Reset on the given phone number 1-8OO-8O3-IO69. Changing an CHARTER Password The following steps show in detail how to change an CHARTER password when the current password is known: Sign into the CHARTER Mail Account from CHARTER Do you want to recover/reset your CHARTER email password? So you'll be do the some steps to recover your CHARTER password. We'll help you to fix your problem and we'll guiding the some steps to recover your CHARTER password. Follow and do the below steps to recover your CHARTER email password- Go to the CHARTER - login page. Enter your Username or Email address and click next. Click Forgot Password below the Password field. Enter your Email address and click Next. Verify your Email address or Phone Number and click on the Next. Open your Email account and check your CHARTER mail message on your Gmail account. CHARTER is an abbreviation for America Online, one of the country's earliest providers of internet and email services. While CHARTER's dial-up internet is not as widely used as it once was, many people still use the company's email service. It's a great email service that lets you stay connected with your family and friends -- that is if you remember your password. Forgetting your password on any internet service is an annoying and sometimes painful process; thankfully, CHARTER has made it easy to recover or reset your account's password. *Please Read* If you don't remember or didn't sign up with one your alternate email address, or you didn't use a mobile phone to register, you will not be able to reset your CHARTER password. If you find yourself in this situation, create a new account. If you do have access to your alternate email or mobile number, follow the steps below to reset your CHARTER password.
Computers & Internet Logo
878 people viewed this question
Ekse
Marvin
Marvin
