I have an LG RH1888H HDD/DVD recorder with a dodgy hard drive, can I replace the hard drive, if so, with what and is it an economical repair?
  • Frangipani23 Apr 29, 2008
    I also own an LG RH1888H. I have had it since Feb 08. It's been working fine until today. It just says please wait and nothing else happens. Can this also be a HD problem?
  • pkbris Jun 10, 2008
    I have the exact same problem and I have only had it a short month...has anyone got a solution to this?
  • 4 Answers
Keep trying assorted hard drives made in the same time period as the set top box. You might have to use the jumper setttings on the drive. Although I got an old 4gb drive to work in it.
And be reassured. That 90% of the drives you try in it, will fit. But it will not allow you to put the front cover back on, unless you do some cutting work.
As for hard drives:
Better off using seagate drives like the one inside of it. I found this set top box one of the easiest set top's I have repaired as of yet. It was found thrown out! Manual, remote, the works!
I also use a lite-on DVD burner inside of it because it's more-fragile-than-fragile DVD burner faulted. (Would not read disks, but laser was active in original disk loader)
And PLEASE handle those ultra-thin IDE cables inside of that thing with EXTREME care! They are glued to the bottom of the HDD and DVD. So peel them off slowly and gently.
-Peace
Posted on Oct 30, 2008
Backup hdd to external hd
DVD recorders are usually not the first selection for backup of data files. you may be better off with a 1 Tbyte external drive, which is suited for that purpose. Even though the DVD drive has the capacity, there are usually formatting issues with data files being burned to a DVD recorder.
May 19, 2012 | LG Computers & Internet
Our LG RH397d/rh399d DVD / Hard drive recoreder will only turn on and display the Hallo message, and you can hear a clicking sound from in side. I have remove the power cord no change .
Your DVD drive is having a problem. When this recorder starts, it checks the DVD drive for correctness. If incase your DVD drive is has problem in the ejecting mechanism then this will prevent your HDD from working correctly. Take the player to service center and fix the drive
Dec 28, 2010 | LG RH177 DVD Recorder/HDD Recorder
LG RH1888H displays 'no disc' after inserting any type of disc.
Hi.
The problem is usually caused by dirty lens. Follow the indications in this link. I wrote the article to answer to the same common problem:My player does not read disks.
Cleaning lens is the most common fix for the problem. If that does not work, then the internal drive must be replaced.
Regards.
May 08, 2010 | LG RH1999H DVD Recorder/HDD Recorder
Can I copy vcr tapes with the LG RH 1999H dvd/hdd recorder?
I use the av2 input in the front of the recorder to copy my vcr tapes to the hard drive
Apr 27, 2009 | LG RH1999H DVD Recorder/HDD Recorder
NOW WON'T PLAY DVD'S THAT IT USE TO PLAY.
First try using a good quality cleaning disk in the unit to see if the lens is just dirty (common problem).
let me know the results and what the screen is displaying if the dvd is not able to play.
clarkco
Feb 26, 2009 | Televison & Video
I purchased a HDD/DVD Model RH1888H from myer approximatley 18 months ago,For $600 I have never been able to get it to record via my high definition set top box and gave up on using the recorder function i...
I have RH188 and I couldn't play DivX movies with it when the codec of it is Real Media codec (RMVB extension). Is there any way to update software or firmware of RH188 to solve the problem?
Sep 21, 2008 | LG Televison & Video
We bought the LG HDD/DVD RECORDER MODEL RH1F99MHS with the intent of recording directly onto the hard drive. How do we make that happen?! WCSU Film Class
I got a DVD+R & a DVD-R recordable discs and I used my LG HDD\ DVD recorder model RH1F99MHS and i recorded on the discs , the DVD can read them but my pc & laptop can't also other DVD players can't play them
Apr 30, 2008 | LG Televison & Video
LG HDD/DVD Recorder RH177
the original program must be unedited - see response to http://www.fixya.com/support/t384103-lg_hdd_dvd_recorder_rh177
Feb 09, 2008 | LG RH177 DVD Recorder/HDD Recorder
LG DVD/HDD recorder RH2T80 hard disc problem
I've got the new firmware. Email me @ damian.hocking@gmail.com
It'a 7MB file, just copy it and play & you should be ok.
Jan 12, 2008 | Televison & Video
Televison & Video Logo
488 people viewed this question
Top Televison & Video Experts
