Nokia 3110 Cellular Phone Logo
Posted on May 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My nokia 3110c phone getting out of service frequently. Its like getting flash every time it gets out of service.
Anonymous
Level 2:
New Friend:
  • Expert 56 Answers
  • Posted on May 25, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
56
Questions
0
Helped
8737
Points
164
If you are not a cellphone technician, may try to repair it to a cellphone shop/technician... it maybe the IC problem...
1helpful
My nokia 3110c phone restarts 2 to 3 times....n then it gets switch off
Hi!
There are many solutions for this issue, please check and try the one that applies. Make sure you back up any data before proceeding.
- Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
- Don't get your phone loaded with too many themes downloaded from the internet or atleast, don't switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
- Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
- Don't try updating of music library frequently or don't often transfer data in/out of your Nokia 3110c phone.
GoodLuck!
eBookBoy
3helpful
My mobile handset model is nokia 3110c.Its getting restarted frequently.I kept the mobile switched off and removed the battery too for some minutes.then switched on the mobile after a while without memory...
Firstly try to download this http://www.driversdown.com/drivers/Nokia-Phoenix-Service-Software_92760.shtml
Secondly download
3110c files And install it in your PC..Disconnect all usb devices.
Now connect the phone with usb data cable without power on the phone to PC.Open Nokia pheonix...Click to "FILE" and select "open product" Choose 3110c rm237.Next Click to "Flashing" and then open "FPS-8C FLASH " after opening this just click to "Close" button and again click to "Flashing" select "FIRMWARE UPDATE" NOW you can select the firmware version as well as the product code at the top right whch is showing a small browse window.Remember if the product code of the particular is not there just select the highest one.
After loading ..Click to "Dead phone" and again press to "REFURBISH"
Wait until a message shows that "PRESS POWER BUTTON" Press it and wait until the phone automatically switch on.
Good luck.......
1helpful
2answers
Can u help me to format my nokia 3110c phone???
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Possible Causes and Solutions Cause 1 - Phone Memory Full - Nokia 3110c mobile phone has got 9MB of internal memory.
Solution - Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 - Changing Themes - Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution - Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 - Memory Cards - Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution - Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 - Transferring data via Blueooth / USB data cable (or) Updating Music Library - A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution - Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 - MP3 files
Solution - This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
2helpful
My nokia 3110c won't start it just show the nokia screen then it flashes white screens 3 times the it will go off
hey frnd your mobile software is corrupted you have to format you mobile by using flashing softwares here is the simple tutorial to formate the mobile <a href="http://www.meramobi.info/2010/08/how-to-format-nokia-mobile-phones-3110c.html">click here</a> <div><br /></div> <div><a href="http://www.meramobi.info/2010/08/how-to-format-nokia-mobile-phones-3110c.htm">http://www.meramobi.info/2010/08/how-to-format-nokia-mobile-phones-3110c.htm</a><br /> <div><br /></div> <div>or if you dont have knowledge of this you can take your mobile to nokia service center they will format the mobile and will charge 250-300 rs.</div> <div><br /></div> <div>hit thanks if you like</div></div>
28helpful
2answers
14helpful
3answers
Nokia 3110c start up problem
there is possibility that some progammes on the phone are not working well so you need to flash the phone.solved
1helpful
3110c
got this from the net, maybe it helps:
The Problem with Nokia 3110c – Switching off and automatically restartingThis is what happens. Nokia 3110 hangs, gets switched off andrestarts randomly. More often, it restarts around 3 times or so andthen gets switched off.
Possible Causes and SolutionsCause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500KB, so as to keep things running smoothly on your phone and preventNokia 3110c from restarting.
Cause 2 – Changing Themes – Some people havereported that the phone restarts automatically when they try changingdisplay themes on the phone.
Solution – Don’t get your phone loaded with toomany themes downloaded from the internet or atleast, don’t switchthemes frequently. These themes, mind you, also load up things intoyour already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB datacable (or) Updating Music Library – A few people have reported thattheir Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but considerconverting all your MP3 music files to WMA and then store them on thememory card. Some users suggested this.
Disclaimer – Follow the suggested solutions at your own risk. The author is not responsible for any damage caused to your phone.
UPDATE:IT LOOKS LIKE A FIRMWARE UPDATE COULD FIX SUCH NOKIA 3110CRESTARTING PROBLEMS – RESOLVE YOUR ISSUES RIGHT NOW BY UPDATING YOURNOKIA 3110C FIRMWARE – CLICK HERE TO KNOW HOW YOU CAN UPDATE YOUR NOKIA PHONE FIRMWARE
Jul 23, 2009 • Nokia 7610
6helpful
2answers
Automatic restarting problem with Nokia 3110c mobile phone
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Cause 5 - MP3 files
12helpful
4answers
Formatting internal memory of nokia 3110c
Cause 5 - MP3 files
5helpful
3answers
Restart my nokia 3110c automatically
hi,restart my nokia 3110c automaticly 3 times and then swich off.what is the rision send me solution.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
