Question about Rockford Fosgate P3001 Car Audio Amplifier
Fosgate amp 3001
It turns on just fine but when music is on and turned up you can bairley hear it and when you turn up the gain the subs bounce up and down
  • 631 Answers
It sounds like you may have open shields on the head unit. The following page tells you how to check them.
Temporary Shield Ground Repair
Posted on Apr 07, 2008
Rockford Fosgate Power 1000 amplifier. (25 to life) When I turn it on there is almost no sound coming from speakers. I have to turn up the volume almost to max to hear something. But only very high...
turn or flip the LPF and sub sonic buttons to see if they will help.
there are other buttons called gain that you may have to turn to bring up the volume.
its very likely your eq buttons that you have to mess with to get it right. post up pics if you can.
Nov 02, 2013 | Rockford Fosgate Car Audio & Video
Fosgate 1500 amp settings
low pass of course set the crossover around 80Hz. Then turn the bass down to around 35% on headunit and the volume all the way up on your head unit just below distortion. slowly turn the amp gain up until you start to hear distortion, then turn it back down until it's completely gone. Then, lower the gain just a little more to make sure you keep out the distortion on all songs. From here you should be good. If the gain is still to high. The adjust to your taste. Just don't move the bass up on the headunit or the gain past your distortion point.
May 22, 2012 | Rockford Fosgate Car Audio & Video
Why do i need to open my gain up to 3/4 to full turn inoder to achieve a loud bass?Im using punch 2400 amp and 2 12" kicker.
the amp may not be powerful or your setting on the cd player is not right try adjusting the cd player. turning the gain all the way up will damage your subs even go above halfway
Sep 19, 2010 | Rockford Fosgate Punch 801S Car Audio...
I have a few problems. i have 2 amps and 4 subs. first problem is when i connect one amp to my speakers it just hisses and crackles. this never happened before. when i turn up the gain to try and get...
The first amp, sounds like there is straight power going through the gain instead of it being limited. The second amp...hook the other subs up to it and see if it sounds ok. If so, then the subs are messed up. If it sounds the same, make sure the subs are connected correctly.
Oct 21, 2009 | Car Audio & Video
Subs not working.
blown sub if it sounds liek a cracking, with sub off, gently press the sub in, if you hear noise, its dead
Sep 23, 2009 | Car Audio & Video
I have a rockford fosgate 501bd amp the protect light comes on when my deck turns on even with no speakers connected
un hook the subs and let the amp sit there on if the protect light shuts off you wired your subs wrong if it doesnt go off tun it off then back on with no sub music all the way down then slowly turn the music up if the light is off then comes on you need new rcas
May 03, 2009 | Rockford Fosgate Power 501BD Car Audio...
Rockfordfosgate P6002 amp protect light goes on
are u sure u have them running at the right ohms, for not only the subs but the amp too...if you go lower than your amp is rated you can fry stuff...via protect mode......hopefully this helps
Mar 17, 2009 | Rockford Fosgate p-450.4 Car Audio...
SPL 1920 watt amp
for 1 never turn the gain all the way up. it is not there to control volume it is there to match gain impedance between other amps and components. 2 i dont know what amp you have so i cant say much about that. 3 test the rca inputs by using a dif set and test the speaker wires as well
Jan 10, 2009 | Car Audio & Video
P3001
Tighten very good the ground wire to your amp, then clean the metal where the ground attaches to the car chassis. Then tighten the ever lovin' bejesus out of the chassis ground. Yeah, I'm from the South :)
Good Luck!
barneyluc
Sep 28, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
Subwoofer Trouble
Turn the bass gain all the way down., Turn up your your volume on bass test song. Crank up the little box next to the steering wheel wide open . Now go gradually turn up the bass gain on the RF amp until you get distortion. Turn the gain down slightly. Now you can enjoy playing the bass from one end of the little boxes setting to the other without ovrloading your amp and subs. Open a can of whoopass on anyone who tries to crank up on your gain.
Nov 09, 2007 | Car Audio & Video
Rockford Fosgate P3001 Car Audio Amplifier Logo
49 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
