Question about Insignia IS-LCDTV32 32 in. Television
Visco LCD TV VSC-32V3 32
I get no signal from the cable connection, but I get signal through the antenna connection using rabbit ears. I also get dvd signal and computer signal! I tried the antenna connection with the cable but still no signal! The unit is brand new never used and it was built in 2006! Not sure if it’s under warranty yet; but I’d like to know why it doesn’t get signal and if repair is simple?
Thanks!
  • 1 more comment
  • Anonymous Jan 26, 2009
    • picture is snowy in all cable channels
  • Anonymous Mar 09, 2009
    my tv is on the light at bottom of the tv turns to blue but the screen in blank black
  • chabadoherty Mar 21, 2009
    Please scan Channels! prompt would not leave the screen after I finished searching for channels. In other words, I could not get any picture or sound from the TV? Could I have selected channel 3 or 4 before scanning or searching for channels?
  • 124 Answers
After connecting the cable to the TV, you should scan for channels. With the built-in cable QAM tuner, you should be fine with a scan for channels.
Try another TV to make sure that cable broadcasting is coming in...is there a set-top cable box involved?
Posted on Apr 08, 2008
  • Kieran Oct 11, 2012
    Hi Jef thanks for reply.their is no satalite box involved ,just a dish via aerial cable,its a samsung smart flat screen,box built in.
Can I use an antenna on my sharp tv catv? If so, what kind works for this tv
Hook up your rabbit ears and auto tune the TV and see what happens.
Jul 24, 2012 | Sharp Televison & Video
Did you check the cabling correctly
May 20, 2008 | Televison & Video
Can a Panasonic DVD recorder be used alone with a
There shouldn't be a problem. The digital switch over only affects the people who are still receiving tv signal using rabbit ear or other antenna based signal, not through a cable subscriber. So the connection between your recorder and tv is not affected at all by the digital switch over. Hope that answers you ?
Aug 10, 2009 | Televison & Video
Philips Model ID 20pf5120/28
Recently, cable has gone digital. You might not be able to get a signal anymore with rabbit ears. They suggest buying a converter box. You can always try restoring factory settings...
Jun 15, 2009 | Televison & Video
Digital Converter connection with old Rabbit Ears TV
First, make sure your connections are right. The rabbit ears need to be disconnected from the TV and reconnected to the converter box. Then the output cable from the converter box connects to the TV. Then try turning the rabbit ears or re-locating them near a window if the wire is long enough. You should be able to get some signal. A newer indoor antenna may help you pull in some of the weaker stations.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
We have a new HDLCDVD220 Sansui television. The rabbit ears antennae we were using on our old tv worked ok, but on this one. its awful. There is almost no color and terrible reception. We were told to get...
You mentioned rabbit ears for old tv, how old are the rabbit ears? Time and humidity will make rabbit ears lose connections internally. Also, if your old rabbit ears have the flat cable going to the tv you probably had to add a converter to go to the new tv. The flat cable will lose signal strength were ever the cable touches metal. Also the adapter will cause signal lose. The best bet is to buy an amplified indoor antenna. You also may try a paper clip and about 3to4' of small gauge wire put the paper clip (bend out to fit) into the center of the antenna in on the tv have the wire connected and let it hang or lift it to see how the picture improves. The problem with rabbit ears is that you have to use war time tactics. Crawl on your stomach and adjust to best picture, if you stand and adjust the signal is usually reflected off your body and will be nice until you walk away.
Jan 28, 2009 | Sansui HDLCDVD220 22 in. LCD TV TV/DVD...
I have a digital TV with an outside antenna and rotor.I rcv analog channels w/o any problem.I can rcv channel 19.1 on my TV and on my old TV with a converter box. I have gone to antennaweb.com to get the...
the frequency catcher of the antenna may be weaker then required.to receive the digital channels u can attach a network booster which will solve the problem.
Dec 04, 2008 | Televison & Video
TV does receive broadcast signal
get some rabbit ears..... or a little dish reciever that sits ontop of ur tv til FEB 17th...then u have to have the new converter, which u can get government coupons online ....or ull just get fuzz after that... i use the old cheap rabbit ears antennae and i get 6 channels ....
Oct 25, 2008 | Sansui Televison & Video
Insignia IS-LCDTV32 32 in. Television Logo
645 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
