I have a HP M1270N Media Center PC. The CPU Fan is constantly running. I have put thermal resin between the CPU and fan and it still continues to run
Any suggestions?
The CPU fan is designed to run constantly to prevent the CPU from overheating. The speed depends on temperature condition of the room; slow in cold and fast in a hot room. However if you suspect that it runs too fast them try re-seating the CPU. WARNING: Re-seating should only be done if you are know how to do; don't experiment.
If it is running noisy, you can apply one or two drops of machine oil to the fan's spindle.
Other reasons include deposits of dust; use a blower to remove dust from the heat-sink.
To make sure you CPU is not in a critical state, log in the BIOS and in the hardware monitoring tab check the CPU temperature. It should be near 60 deg Celsius or 140 Fahrenheit.
One thing more, do not apply thermal grease in excess; its a conductive compound and can short the motherboard if it melts and deposits on the motherboard due to high CPU temperature.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
First clean your computer of dust you could use a fine air blower from a compressor or a can of compressed air whatever you use make absolutely sure there is no moisture in the airlines
if the fan in your computer is constantly running to cool down the cpu and it is normal for it to increase it's speed, your fan should run quietly even it increases the rpm.
But if you hear a loud noise in the fan, i think there's something wrong with it.
I suggest for you to check the fan if it's coming in contact with anything. If the fan is visible while your computer is operating, you can observe it to know what is really happening.
I don't know what type of fan hp uses on their computers, maybe something is loose already on the fan so better check it or bring it to an hp service center.
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
make sure your CPU has thermal paste
your CPU might be getting hot making you computers fan to run consistently
hope this helps
The fan should be constantly running. Just the speed is controlled by the mainboard. Can you clarify a bit more ? it it to noisy ? or running at top speed all the time ?
