Question about RCA P46921 46" Rear Projection Television
Strange Picture Issue
The other day we were watching a movie and the screen "split" into R G B and the bottom half of the picture was curved. Left it off for a couple of hours and it was fine, then it did it again tonight. Any suggestions on where to start looking?
Thanks
Chris
  • Chris Pettican Apr 08, 2008
    Wow, thanks very much, I've sent them a note already :)
  • Chris Pettican Apr 13, 2008
    Do you have any idea where to find the convergence IC on this model?
  • RCA Master
  • 8,617 Answers
Your convergence ICs are getting weak and will need replacing soon. You can get replacement ICs with free installation instructions and free online tech support during the repair which takes about an hour. If you dont know what IC numbers you have in your set . hit the contact link on the lower left section of the front page and give them your model numver and they will email you back with your correct IC numbers.
http://servicemanuals.vstore.ca/
Posted on Apr 07, 2008
SOURCE:
I cant get it to work on full screen
I am having this same problem as this one above (62HM95). The issue I'm having is that it will also not work full screen. I selected the 'Split' option on the remote and the picture on the left is fine... absolutely clean and perfect, with audio. The picture on the right is completely distorted in very strange colors (mostly constant variations of purple), with audio as well. You should note, that the same video information was feed into different imputes to select for the split. In other words, I feed the cable stream into the TV using the component video (Y B R) as well as the coaxial cable and selected both options for the purposes of displaying the same information side-by-side. On screen I selected video option four (4 for color stream HD) and option (0 for cable/antenna). If I highlight either side and select one of them (4 or 0) the screen goes full screen and I see nothing but one solid color of purple. I've researched the purple and they call it 'Electric Purple'. That is all I see... just the solid purple, with the audio. What I have also noticed is that, If toggle between imputes while in the full screen option and come back to either option (4 or 0) the image plays/appears OK for about 2 seconds then goes back to solid purple. I just can't understand why this is happening especially when the on-screen menu displays perfectly fine. I cannot enjoy this TV by only watching half of it in split mode. Besides the multiple replacement bulbs I've had to buy I've completely had it with this TV
May 29, 2012 | Toshiba 62HM95 62" HDTV
Sharp 46" 6 months old see rainbow colors from left to right
Did he change the big video board?The main backlight video baord that the prob.
Oct 23, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
RCA model R61WH76 Chasis itc222 has 3 color curved band lines on
Your model doesnt have convergence ICs. You can get the replacement parts and free instructions on how to do the repair at the following link, just click on the contact us link on the lower left hand side of the website and tell them the model number and chassis they respond quickly.
Apr 11, 2009 | RCA R61WH76 61" HDTV
RCA Projection TV model #p61926
The convergence circuit is your problem and most times with this model the convergence power supply bd. is the problem.
Feb 11, 2008 | RCA P46921 46" Rear Projection Television
Sony Trinitron Top Half picture blacked out
You could have a bad capacitor 35v 100uf ,1uf 50v ,VERTICAL ICs have 7-11pins depends on which one you need LA7830-or 7833,7835,7836,7837 7838 make sure you get correct part.
ThankYou for using FixYa. Have a Nice Day
Feb 07, 2008 | Samsung HCM4216W 42" Rear Projection...
Mitsubishi
you need to do self test first look in threads and also ctechnicians.com to get error codes.
Dec 30, 2007 | Mitsubishi VS-50611 50" Rear Projection...
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Screen just split in half
Is the tv still in warranty? The problem is the upper buffer board, it's a small board that controls the upper portion of the screen. You will have to consult a service center to get it, it's very easy to install
Apr 15, 2007 | Panasonic TH-37PD25U/P 37 in. EDTV-Ready...
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
RCA P46921 46" Rear Projection Television Logo
53 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
