Question about SanDisk Sansa e260 MP3 Player
Sansa E220 my sansa E220 will not format or let me put music on it and now all it says (load main image failed switch to recovery mode) if i could find the soft where to redo my sansa E220
  • 8,596 Answers
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Posted on May 23, 2008
It will not boot. It says that it cannot load.
better to unpartition all drives and again partition and then install....now it wont saw ......go to recovery....
Feb 10, 2009 | SanDisk Sansa e260 MP3 Player
Sandisk sansa e260r
if you still have the software that came with it (and installed) plug your sansa into your computer....the software should recognize it...then look for a button that says "repair" or "format" im not familiar with the exact program but i know your problem all too well...*shudder* what that will do is it will REMOVE all the songs from the sansa...but if their still on your computer you should be fine...then it reinstalls the firmware(the codes and software that make it work) then you just have to re-addall your music and your all set :) if this doesnt work feel free to repost here :P
Feb 05, 2009 | SanDisk Sansa e260 MP3 Player
Load main image failed switch to recovery mode
follow the above steps but turn on the power button if nothing is happening. It's the only way I got my e280 to recovery mode
Sep 23, 2008 | SanDisk Sansa E280 MP3 Player
Sansa e200 load main image failed
i'm thinking that it has too much info on it, so it ets stuck when you turn it on.
Jul 31, 2008 | SanDisk Sansa e260 MP3 Player
Load main image failed Switch to Recovery mode
Use the Sansa Recovery Tool on the Sandisk website
Jun 01, 2008 | SanDisk Sansa e250 MP3 Player
Loading image failed
Try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Please RATE my solution at the bottom.
Nov 27, 2007 | SanDisk Sansa e260 MP3 Player
My Sansa e280 forze
Try plugging the player into the computer and formatting it. This will erase the music from the player, but you have a copy of the music on your computer as well. I think this will solve your problem.
Good luck.
Nov 08, 2007 | SanDisk Sansa E280 MP3 Player
My sansa e280 rhapsody says switch to recovery mode
Recovery mode is used to recover from a fatal error.
Follow these steps and youll be back in business.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
Best of Luck.
Oct 22, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
176 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
