Question about Saeco Incanto Classic Espresso Machine
I have the saeco incanto sbs rapid stream and the red light stating that the door is open will not turn off
The light will not turn off until the dregs drawer has been removed, with the door open, for a minimum of 5 seconds.
Posted on Jan 29, 2009
  • 487 Answers
That can mean that the brew group is not in the right place, the dreg drawer or door.
Please check all three of them
Posted on Apr 16, 2008
SOURCE:
How to change brew group rubber orange gasket on saeco Incanto Sirius
google for USA-Incanto Rondo SBS-RS, E74088 Rev. 03.pdf
it has an exploded view of the brew unit. partsguru has the part.
Jan 30, 2013 | Saeco Vienna SuperAutomatica Coffee...
My Saeco Incanto Sirius grinds the beans but does not pump out the coffee into the cup
If you already tried the previous suggestion (grind at the most coarse setting) and you still get no water, it may be the SBS brew valve.
As a test, run a blank shot by telling the machine you are going to add preground coffee but don't add any coffee. When you start your shot you should get plain water (probably tea colored as it flushes out some old coffee left behind from previous brews).
If you still get no water, then it is either your brew filter screen is plugged or the SBS brew valve is plugged.
Remove the filter screen and hold it to the light, can you see through all or most of the tiny holes? If not, soak it in a good coffee detergent and scrub it with a toothbrush until the holes are clean (DO NOT USE A NEEDLE TO CLEAN THE HOLES).
If it is the SBS brew valve, you can open it fairly easily to clean it but there are a couple of tiny parts and a spring so be careful.
And final thoughts - the SBS brew valve can be defective - I've had some that were too tight and simply wouldn't allow any water to flow at all. But since yours was working before, it probably just needs cleaning.
Jun 12, 2010 | Saeco 00034 Incanto Sirius Super Automatic...
Machine won't prime
Try lifting the water tank, then setting it back in place, and then priming the machine.
Jan 15, 2010 | Saeco Incanto Classic Espresso Machine
Saeco incanto rapid steam leaking from under
The leak is most likely from the steam valve, you will have to either buy and replace the o-rings and the pistons in the valve or just buy a new valve assembly and replace it. Easiest solution get the new valve assembly.
Jun 25, 2009 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Rondo RS SBS
if you open the steam knob, will there comes some water?
Aug 05, 2008 | Saeco Incanto Classic Espresso Machine
SAECO Incanto Rondo espresso machine
I think you have to take it to a Saeco service center, they have to upgrade your power board in the machine.
Jul 22, 2008 | Saeco Incanto Rondo RS SBS Espresso...
Coffee too weak
What kind of saeco incanto do you have?
Jun 23, 2008 | Saeco Incanto Classic Espresso Machine
Incanto deluxe is leaking
sometimes the spout in the door is kinda clogged. Take this out ) need phillips head) and clean it . Make sure to turn the knob on it to left and right while cleaning.
There is no gasket but the little plastic pipe goes in there.
Should help.
Check this for parts SAECO
Jun 01, 2008 | Saeco Incanto Classic Espresso Machine
Coffee machine
I had the same problem. It had to go back to the service department and a replacement part was needed.
May 17, 2007 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
191 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
espressofixr
Level 1 Expert
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
