Samsung LCD TV Model LA40S71B Has Horizontal Interference on Picture with Programe visable beneath them
  • twowings Apr 07, 2008
    Thank you for the prompt reply Maanita,sadly no better but have more info. The set also goes on and off 10 or 20 seconds per cycle but does vary, this further info came after my original post. Regards
  • twowings Apr 10, 2008
    History of fault it started as few lines at bottom of picture and gradually increased until it coverd all the picture, taking 2 or 3 evenings veiwing then it started going off and on as though you turned off cycling 2 to 5sec but varies.
    Genius:
  • 1,226 Answers
On the first post , show a fault in vertical and horizontal projection of the TV, That is need of severe series of testing the Hor/vertical PCB of the TV. Test it and resoldered all loss connection and replace the busted parts in it.
melnavz
Posted on Apr 10, 2008
  • Emelio Navaja
    Emelio Navaja Apr 10, 2008
    lastly this need and expert hand on troubleshooting to shoot the problems. may this help.
    Genius:
  • 1,142 Answers
Have u tried a hard reset of the tv
Posted on Apr 07, 2008
  • Maanita Chadha
    Maanita Chadha Apr 07, 2008
    u need to unplug the power cable from wall socket..keep the on\off switch for ur tv pressed for 20 seconds...then plug in the power cord back in and try working..lemme know wat happens..so that i can suggest further
  • Maanita Chadha
    Maanita Chadha Apr 10, 2008
    Magnetic interference from unshield equipment OR Hi-fi speakers placed too near the TV set. Turn the TV set off for about 30 minutes and turn it on again. But you have to move away the speakers from the tvset, and in any window airconditioner is close by then you need to change the direction of the tvset.
    ***open the menu of the tv and reset the setting back to factory settings. this will definately work***
Samsung un60d6000 tv no picture only sound?
the voltage is ok doo you have constantly 150 v if not led blocks is bad
Feb 28, 2017 | Samsung UN60D6000 60 Inch 1080p Smart TV...
I have a 40inch Samsung le40r88bd that keeps flickering and is getting worse is there an easy fix?
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture EASY most common way MODEL ...
Flickering picture
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 13, 2013 - A flickering picture on your TV can be caused by the following conditions: Television settings; Incoming signal issues; Electronic interference ...
How to fix Samsung LN46C630 screen flickering issue
Jan 16, 2016 | Samsung Televison & Video
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
I have Horizontal lines showing on the lower portion of my TV. Below is my TV Model and SN information along with a picture. Samsung LCD Model: LN - T4665F I can see the line when the TV is off.
if you can able to see the line when the TV is off the its means there is problem with the LCD panel. It would be very difficult to get the lcd panel. Try to get the help of authorize servicing center.
www.electro-medical.blogspot.com
Sep 08, 2015 | Samsung Televison & Video
Right half of LCD screen goes dark. Like the brightness and colour are bleeding away. The image is still slightly visible beneath the dark. Some horizontal lines also appear across the entire screen, about...
I have the exact think happening on my Samsung LN46A530 and it has just been 2 years since I bought it. There better be a cheap fix for this because a $2,000 product has to last a lot longer than 2 years.
Aug 21, 2010 | Samsung LN46A530 46 in. LCD HDTV
My Samsung 47 has a black film covering 1/2 the screen for about
Samsung only makes TVs that last 2 years, mine also has the same problem. Throw it away and buy a cheaper disposable TV, despite all the hype Samsung is just another cheap and nasty manufacturer who uses its customers as product testers. Why do you think they keep changing model numbers every week ?
Jan 13, 2010 | Televison & Video
Need an activation code for my sky+ remote to operate the volume on my samsung lcd tv le40s8.
switch to sky on tv and press interactive on sky remote then move down to sky customer service (select) once screen has loaded move down to programe your remote you will need model number and make of tv press select and then enter the make of tv by moving down list once found select and repeat for model then follow on screen instructions
Dec 11, 2009 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
LCD TV Model LNS3238DX/XAA, S/N AFQ3CRL800704D, Version AM01
Unfortunately this indicates that the LCD panel itself is cracked. This can not be repaired, only replaced. Call around to get a cost of the replacement panel. It would not surprise me to find that the replacement panel cost exceeds the cost of an entire replacement TV.
Dan
Oct 31, 2008 | Samsung Televison & Video
SAMSUNG LCD TV horizontal lines
causing of horizontal lines is leaky or defective capacitors. check big value capacitors around the board at Horizontal area. check the filter capacitor as well. good luck
Mar 21, 2008 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
No picture
try chicking the horizontal section or vedio section...
Jan 28, 2008 | Samsung LN-S4051D 40 in. LCD Television
Televison & Video Logo
205 people viewed this question
Top Televison & Video Experts
