Question about Coby TFTV2003 20 in. LCD Television
Tf-tv2003 is locked
Tv is locked and i do not have remote to unlock.howcan i unlocked with out original remote control?
  • Anonymous Apr 02, 2009
    me too.
2 Suggested Answers
tray06606
  • 59 Answers
SOURCE: My coby tv, TF-TV 2003 is locked and I do not have a remote.
hi you might have to call the place where you bought it and let them know this prolem and see what they say if they can not help then i would call coby and they should be able to walk you through your problem
Posted on Jan 10, 2009
Will a universal remote work to unlock my Sinotec tv cause it shows key-lock and my original remote is broken.
Sorry
to unlock this TV, it's original remote control needed. Just buy one. Contact the authorized service center for Sinotek. No universal remote control will go. http://electronicshelponline.blogspot.com/
Jan 11, 2017 | Universal Televison & Video
How will i have this resolved? my sanyo k50 tv showing "locked" whenever turned on??
The TV is locked by someway. If you're using a universal remote control, this might have happen. If you wish to unlock it, you must have its original remote control. For more information go to http://electronicshelponline.blogspot.com/ Unlock procedure to many brand TVs are given. Pull up older posts.
Nov 28, 2013 | Sanyo Televison & Video
Awa lcd ltw32ds
You need the original remote control to unlock the TV.
Jan 01, 2018 | Televison & Video
HOW DO I GET FPA LOCK OFF W/OUT NO REMOTE
You must have its original remote control to unlock this Tv. It wont work with universal remote control.
If you have't the original remote control, just buy a new one, borrow it from any of your friends or relatives, who own the same model RCA tv; just to unlock it. For details about the proceedings to unlock it, get into this blog site. Details are given there.
electronicshelponline(.)blogspot(.)com in name Electro-Help
Apr 11, 2012 | RCA 27F650T 27" TV
Is RCA 24V511T digital or analog? Also can I use a universal remote or do I need the replacement for the original remote that came with it? I
Hello
This CRT based tV is an anlogue one. You can use a universal remote control, except to unlock the FPA lock to this TV. By anyway, this TV has been locked with FPA lock, you must have its original remote control to unlock the lock. You can use most of the RCA universal remote controls with this TV.
RCA RCR 311W will be better. The setup codes are:
1000, 1002, 1004, 1005, 1014, 1025, 1078, 1081, 1095, 1096, 1097, 1098, 1099, 1100, 1101, 1111, 1128, 1130, 1132, 1134, 1144, 1146, 1149, 1171, 1205
OK.
Sep 22, 2011 | RCA 24V511T 24" TV
I accidentaly turned the FPA lock on my TruFlat RCA tv and the original remote broke. i just bought a RCA universal remote from best buy. now how do i get rid of the lock?
Hello
It will be very difficult to unlock RCA TVs without its orginal remote control handset. Anyway just try this, This is the actual proceedings to unlock the RCA TV with its original remote. If you fail to do this with your present universal remote control, just buy an new original one from RCA Authorised Service Center at tyour town, or just borrow it from any of your friends or relatives; just to unlock your set. After unlock, you can use the universal remote control. Just follow the proceedings given below. One amoung them must unlock your RCA TV.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Aug 24, 2011 | RCA TruFlat 27F520T 27" TV
Parental control code had been changed, don't know what it is now
Hello
Try the following to unlock your Jensen TV.
1. Turn on the TV using the remote control. In most cases, you will need the original Jensen remote to unlock the TV if you aren't sure of the unlock code. You can purchase an original replacement online if necessary.
2. Look at the screen. If you see a red key on the bottom of the screen, press "Function" and "Mute" on the remote at the same time. This will unlock the channel. Do this if you want to bypass the lock to watch a certain show or channel while leaving the TV locked. All other channels will remain locked and the TV will lock again when it is turned off.
3. Unlock all of the channels on the TV by entering 0711 or 3308. These are the Jensen factory reset codes that will reset the TV to the original factory settings. By doing this, you will loose any information that you have stored in the TV, such as channel labels and schedules. You will have to program the TV again by going through the entire initial set up.
4. Call the technical support service number in your owner's manual if neither of those codes work. A technician can help you troubleshoot the television as the problem may not be the parental lock feature. Have the model number and serial number of the TV available when you call.
5. Take your television to a TV repair shop if neither of the codes work and the TV locked by itself while it was turned on. In this case, the TV may need to be rewired.
OK.
Mar 14, 2011 | Jensen 143307 Remote Control
My tv is locked how do i unlock it
Turn the TV on, hold the display button on the remote until the screen goes black. Turn off the TV and back on and it should work. Hope this helps! =]
Mar 03, 2011 | Jensen Q2749J 27" TV
Child lock
you will need your original remote control and go through the menu to unlock it. find your original remote control by typing in your TV model number in the search on www.replacementremotes.com and your original remote will pop right up. very easy to use.
May 31, 2008 | Philips Magnavox Learning Universal Remote
Coby TFTV2003 20 in. LCD Television Logo
79 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
