How can i obtain the driver for the pci communications controller as i/m did not see it on the website this drive as it is the only question mark in my device manager
It's there but you did not vote.........
Thank You
Update windows & pick custom & not express update. This will allow windows to scan for missing drivers/hardware. Update software for you're hardware. Once all hard ware is updated re-start the PC. Did you run the 4-in-one software? You might have missed installing the device or installed a device software that is not turned on in your bios but you are not using it.
Check you're device manager for missing/needed controllers/drivers. ( After Windows updates are completed).
Chances are the PCI communication device is the CNR slot on you're board also known as a PCI simple controller. Everything integrated into your board will be called a PCI device & if it's called a PCI communication controller (controller / driver, same thing), it will have to do with communication. The CNR built in to you're board is a PCI communication device. The modem driver. If you're not going to use this than disable it in the bios. Go through pages 27-30 & check you're bios settings. Or it can be the Power Management/APM is turned on in bios. Once you update windows this will show up with-out the yellow !/? point.
http://www.ecsusa.com/ECSWebSite/Product...
It all seem tougher than it is. You can narrow it down by checking the bios & what is turned on & matching this to you're device manager. It will take some time. (I know all too well) but it's worth the time.
Luck.....
Mike & thank you too!
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
7+9
please assist pci simple communications controller need device driver
i´ve try toinstall windows xp and appears pci simple bla bla bla and ihave odenconecction no adsl soi can´t do any
pci communication controller not working
can u gv me the pci driver installer to me
I can not find the pci coummacation driver it has a code 28
pci simple communications controller is yellow with exlamation point, how can i solve this problem. my mother board is intel desktop board D845EBG2 PLEASE HELP ME IF SOMEONE KNOWS HOW TO SOLVE IT. THANKS
