Question about Mitsubishi WS-55819 55" Rear Projection Television
Mitsubishi big screen
I looking for the front plate that has the power,channel and volume buttons.
  • Mitsubishi Master
  • 8,617 Answers
Are you looking for the circuit board control panel? Or the actual frame that houses the buttons/ I have access to tons of mitsubishi parts.. Let me know what it is that youre looking for, I should be able to help you.
Posted on Apr 07, 2008
SOURCE:
How do i scan for channels on my flat screen panasonic
you can use the remote control or at the menu button in the front panel. now to use the menu at the panel press the button with channel up/down button then look for the channel search. you can use the volume up/down button to search channel.
Jul 14, 2011 | Panasonic Televison & Video
My mitsubishi ws55511 remote does not work and
The front buttons need to be replaced. I would replace them all due to no being able to tell which ones are the bad ones. It should fix the problem.
The part # of these Tactile switches is 432P089010. Mitsubishi's parts department phone is 800-553-7278.
The two front grill covers pull off and the front plastic housing unscrews from the front.
Hope this helps,
Sky Assoc
Oct 21, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi 65807 won't power on
hello it's possible the glass fuse may blown inside the tv take the back off and check but make sure the power's off
shaun
Oct 12, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Need the manual for Mitsubishi CS13TX1... small counter-top model, perhaps 12-15 years old. Mitsubishi seems to have forgotten they ever made anything before huge screens, home theater, digital, etc., and...
use the menu button on the tv and look for the auto program mode. you will probably have to navigate the menu with the channel and or volume buttons.
Sep 13, 2009 | Mitsubishi Televison & Video
Mitsubishi TV Channel Tuning/Remote Problems
To restore full functionality to your set you must replace the remote that came with set. Universals only control the most basic of functions.
Apr 27, 2017 | Televison & Video
T. V. stuck on one channel showing the device option.
I had same problem and discovered one of the little buttons on the front of the TV was stuck down. Don't know why, unless the maid bumped it hard as we never use them. Anyway, I poked/wiggled a few times at each button and the problem stopped.
Mar 17, 2009 | Mitsubishi WS-65511 65" Rear Projection...
I'm looking for the manual for a Mitsubishi VCR HSU447 with the remote control RM75502 so I can program my TV to it. Thanks
1.- Turn off your TV
2.- On the remote control, set the VCR/TV slide switch to TV position.
3.- While holding in SP/EP button, press the code button listed below that corresponds to the brand of your TV
4.- Press TV POWER on the remote control. Once your TV has turned on, your remote is set up to operate your brand
TV.
Brand of TV Brand Code Button
Mitsubishi 1,2,3
Fisher 0
G.E. VOLUME UP
Goldstar 2,9
Hitachi 8
JVC MUTE
Magnavox 4
NEC 2,9
Panasonic CHANNEL UP, CHANNEL DOWN
Pioneer 6
Philips 4
Proscan VOLUME UP
Quasar CHANNEL DOWN
RCA VOLUME UP
Sanyo 0
Sharp 3,5
Sony VOLUME DOWN
Toshiba 7
Zenith INPUT
I finnaly found my VCR Manual, and I'm glad to share this info with you, because I was looking for the manual all
over the web and FOUND NOTHING!. Bye!
Mar 15, 2009 | Mitsubishi Televison & Video
Tv screen went blank
sound like the inverter circuit board problem. check & replace back same part# inverter circuit board. hopefully could help!!
Dec 29, 2008 | Vizio L32 32 in. LCD HDTV
P61960
I was tring to remove the concave off my screen and came across a setting where you can make the picture larger or smaller. On the TV, not the remote, press and hold the menu button, press and release the power button, press and release the volume up button and release the menu button. P0 and V0 will be displayed on the screen press the volume up button until the V0 is V76. Press the channel up button until P0 is P11 and press the volume up/down button to make the picture larger/smaller. If you need to center the picture press the channel down button until P11 is P10 and press the volume up/down button to center your picture. I hope this helps
Aug 18, 2008 | RCA P61960 61" Rear Projection Television
50" MITSUBISHI BIG SCREEN (MODEL#VS-5076,
INITIALIZE THE SYSTEM CONTROL. WITH THE REMOTE CONTROL PRESS "MENU 2, 3, 5, 8, " USE THE ADJUST BUTTON TO SELECT "INITIAL" AND PRESS "ENTER"
Mar 17, 2008 | Televison & Video
Mitsubishi WS-55819 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
