Question about NetGear MR814 Wireless Router
Wireless will not get to the internet
I have just hooked up to Qwest DSL and I can't get the wireless router to work. Can you help? I am currently online by hardwire through the Qwest router.
Thanks,
John
  • john2137
    is ur computer receives signal when u turn on the wireless router??
  • 42 Answers
Driver for ur wireless card is working?
on the router software the ap module is on? set on ad-hoc? or ap mode.
Posted on May 07, 2008
Wireless access using the dell true mobile 1300 pc
2 things...
1. test your internet connection by plugging back into the router bypassing the router.....
2. Have you set up the router?
Jan 14, 2010 | Dell Inspiron 1000 Notebook
My daughter works at home as a Customer Service Rep. for Generation Networks (Ancestor.com). She has a terminal from work and it is configured for her to work from home. She has done that for over a year...
This is only a problem with the firmware of your modem/router that you need to update it, because a network device like a modem and router that is working fine for severla years and suddenly stop working you just need to update the firmware of it and it should be working fine again, to update the firmware of the modem/router just need to call the manufacturer for that....
Hope that helps.........
Oct 05, 2008 | Computers & Internet
I am running qwest DSL through a Linksys wrt160N that is brand new. it will work next to the router, but not upstairs or in the basement which is less than 15 meters. The upstairs bedroom is directly above...
If you have concrete floor slabs the the wireless signal from the Linksys will have a difficult time penetrating the floor slabs.
The wireless card in the computers will show a low signal strength.
Try altering the Linksys aerial to a horizontal position and also positioning the Linksys to another location.
You could be getting interference form other wireless sources, check the wireless channels of other wireless router/access points in your area. If they are broadcasting on the same channel then configure your Linksys to broadcast on an unused channel or one that has the weakest signal strength.
If none of these methods work then I would suggest you run network cables from the Linksys to upstairs and downstairs and not use the wireless connection.
If network cabling option is not an option then consider extending the wireless range with wireless repeater access points.
Nov 07, 2009 | Linksys WRT160N Wireless Router
Attempting to connect WGT624 V4 as a wireless bridge to connect to my 2 wire qwest dsl modem to connect tv components to internet along with Xbox 360
To establish the bridge connection, make sure to write down the Wireless MAC Address of the 2wire first. Now login to your Netgear router's setup page and go to the wireless bridge settings. Manually type there the Wireless MAC Address of the two wire. Make sure to enter the same SSID, same Channel and same Wireless Security Key to successfully establish the wireless bridging. Save your settings after that and reboot the router.
Oct 22, 2009 | Computers & Internet
Ethernet works, Wireless doens't Page Can Not Be Displayed
check ip setting and DNS setting of router and your wireless card
Jul 21, 2009 | Computers & Internet
I need instructions for a Linksys Wireless G router to work
Call your internet provider they will walk you thru the process.
Jun 18, 2009 | Linksys Wireless-G WRT54GS Router...
Wireless Home network will not stay connected to internet
So you have a DSL modem connected to a router connected to a wireless router connected to both your computers? Sounds like you need to just get a wireless modem and throw all the routers away.
Jun 01, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Have SBCglobal with 2wire but want N wireless capability
Follow the dots -
2 wire DSL wire to back of DSL modem.
Ethernet cable out of DSL modem, to current router (if you have one).
Ethernet cable out of current router (if you have one) to new Wireless N router.
If you currently have a wireless G router, keep it, or, use the new Wireless G/N router alone. You will need to set up all security settings again if you remove your current router, and if the new router is N only, you will need to make sure all your wireless connecting computers have wireless N cards in them.
Jan 24, 2009 | 2wire 2700HG-B Router (2700HGB)
Can't get a wireless router to work with a speedstream 4200
This may actually be an issue with your ISP. There is a good possiblity that your ISP has bound your connection to the MAC address of the network card on your computer. This is a common occurance which is why router manufacturers give you the option of having your router clone your computer's MAC address. Go into your router's management an perform the clone, sorry I cannot give you more details but I don't know the specific model of your Belkin router.
Jan 05, 2009 | Siemens SpeedStream 4200 (13A4200001)...
Ip problem
It is common to have this as the default IP to connect to equipment.
I suggest you unplug your modem while you set up your router. You can also change the default IP for the router while in the settings. be sure to remember the new IP or you will have to do a factory reset to get it back to default
Jul 03, 2008 | D-Link 802.11g Wireless Router WBR-1310...
NetGear MR814 Wireless Router Logo
66 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
