Question about E-Machines eMachines Desktop PC
Monitor my computer powers up but monitor won't click on...
  • jessybear Apr 18, 2008
    my tower turns on and so does my screen but i only get a blue screen and an arrow no start up menu or anything ive tried unplugging everything and restarting ive tried to reboot it i tried to recover it and still i get the same thing what do i do
  • Mark Kessler May 11, 2010
    Can you manually turn the monitor on?
    Problem Solver:
  • 11 Answers
If your monitor switched on, and still wont poers up, check for the power souce/cable of the monitor.
Posted on Apr 13, 2008
Monitor won,t wake up from sleep mode
Open monitor and look at power supply board for capacitors which are "balooning" or deformed in any way. These look like cylindars on the board. These tend to dry out and make what you are describing occur. Replacing them usually fixes about 80% of the problem you are describing. Those parts run about $0.25 to $0.75 each.. well worth trying, right?
Jan 20, 2014 | HP 2009M Monitor
Computer monitor HP Pavillion keeps clicking and flashing but won't turn on the screen
you need to bring your PC to a technician... Its the best solution for that. It will save you time and money.
Mar 08, 2013 | Computers & Internet
Monitor won't turn on after a few hours of being shut off
If it EVER works, then the problem is not a failed part, but a weak part. The most likely component type to give you such problems are capacitors. But very few repair techs know how to find such problems, and even fewer have the equipment needed to find the bad one(s) in-circuit. The failure mode is high ESR (ESR means Equivalent Series Resistance). The lower the ESR, the better. Capacitors with high ESR cannot stabilize circuits which demand high pulse currents, such as in switch mode power supplies.
Apr 24, 2017 | Generic Computers & Internet
Won't go into sleep mode
Which operating system ?
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work.
This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation.
Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money!
Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow.
The Shut Down menu appears.
Point at "Sleep" and click on this option.
Your Windows 7 computer goes into sleep mode.
Wake your computer from sleep mode by jiggling the mouse.
There may be a delay of a few seconds before your hardware powers on.
All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode.
Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time.
Click "Start" and select "Control Panel." Click "System and Security."
Click "Power Options."
A menu opens.
Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode.
If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity
Your Computer in sleep mode
First, save all of your work. Information in computer memory is not saved while your computer is on standby.
From the Start menu, select Settings, then Control Panel, then Power Management.
Click Standby Beside When I Push the Power Button.
Push the Power button.
Automatically Putting Your Computer on Standby
Save all work before leaving your computer.
From the Start menu, select Settings, then Control Panel.
Double-click Power Management.
Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks.
Click OK. Your computer will go on standby according to the schedule you have entered.
Putting Your Computer in Hibernation
Double-click Power Settings.
Click on the Advanced tab.
At the When I Push the Power Button On My Computer screen, click Hibernate.
Click the Power button.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
Envision en-7500 won't power on
The problem is in the power supply board, at least one capacitor is open, sometimes will bulge at the top making it easier to spot.
Jun 10, 2012 | MPC Computers Envision EN 7500 17" Flat...
Monitor won't go on
What to you mean by Monitor won't go on? Are you saying the power on the monitor will not turn on? Are you saying the Monitor is on, but there is nothing showing on the screen? Also it would help if we know what kind of computer and what operating system.
Mar 22, 2012 | HP G60-235DX Notebook
Monitor won't go on
Mar 22, 2012 | HP Pavilion G60-235DX notebook
Monitor says to check signal cable
get a new power cable for tower/computer. u can call i wat u want. new power cable for computer not moniter. or connection is incorrect. hope it helped.
Dec 05, 2011 | Samsung Computers & Internet
How can I "Keep Alive" the video out put to an
If you have Windows 7, click the start button and select Control Panel, then select "power options". In the left margin select "change when the computer sleeps". In the next box select "change advanced power settings". In the advanced power options box look for "power button and lid" and click the plus box next to it and change your settings. Make sure to click "apply" after changing the settings or it won't take.
Xp and Vista will be similar. In all cases you want to go into Control Panel and select power options.
Jun 06, 2011 | Dell Inspiron Mini 10 Notebook
COMPUTER WON,T YURN ON
first of all,is your power cable properly connected to your system unit.if it is not,connect it properly and turn the system unit on again
secondly,make sure your signal cable from the monitor to the system unit is properly connected
after following these instructions,reboot your computer again.
thank you for consulting fixya with your problems
Feb 14, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
