Question about Polaroid PhotoMax Fun Flash 820 Digital Camera
Interface I need to buy a new interface unit where can i buy a new complete kit?
  • K98K Apr 07, 2008
    No Comment
  • K98K Apr 07, 2008
    Serial cable....
  • 790 Answers
U mean the drivers ... ??? u can download it in polaroid website!!
Posted on Apr 07, 2008
  • Kanth raj
    Kanth raj Apr 08, 2008
    You can buy it in e-bay !!!
NEED WIN 7 DRIVER FOR GTCO CalComp Drawing Board III
Drivers for GTCO, GTCOCalcomp or Calcomp digitizers for Windows XP, 7 and 8 can be downloaded from this url:http://www.interworldna.com/GTCO/gtco-drivers.php
If you are trying to use your digitizer with AutoCad these drivers will not work and you will need to buy a driver from VTABLET.com (They provide a 30 day free trial/demo) only works with serial RS232 interface. If your digitizer uses USB then you will need an interface kit for your specific digitizer to convert it to RS232. Most new digitizers come with USB, some have serial but require you to buy an interface kit. Contact your Digitizer supplier.
If your digitizer is a GTCO, GTCOCalcomp, Calcomp or Summagraphics brand, try these guys: http://www.interworldna.com
They do not know about any other brands. Wacom contact Wacom, Numonics contact Numonics. If you have Mutoh or Science Accessories or any other brand you are on your own as those manufacturers have all gone out of business as far as I know.
Dec 06, 2013 | GTCO CalComp Drawing Board III 34180...
Forgot ip address and password
To re-enable the Console access requires the SW2900 series to be reset to its default settings via the WEB INTERFACE
- Web Interface
- Device >Configuration >Initialize To change the Default User "ADMIN" password it is necessary to use the Console connection
-Console Interface
-Once the unit has successfully booted and the prompt presented
-Enter "password" (without "")
-Enter "admin" when the system prompts for User
-Press the "Enter" key when the system prompts for "Old Password" (the ADMIN password was reset by the Web Interface commands)
-Enter "" when the system prompts for the New Password (where "" is the new product ADMIN password)
-Enter "" when the system prompts to confirm the New Password In order to complete the configuration it is necessary to save the configuration via the WEB INTERFACE
-Web Interface
-Device > Configuration > Save
Symptom:
SW2900 Baseline Switch - Default console access disabled following password change
From the web interface, the default user "admin" password is changed and console access is disabled
Cause:
When applying the new password, by default the service-type is set to "telnet". When applied, the default "terminal" setting is removed thus disabling console access.
Apr 20, 2013 | 3Com Baseline Switch 2924-SFP Plus
Teac diskette drive pinout for Technics kn1000
Sorry.
There was an interface included, inside the KN 1000 unit floppy disk drive. This interface change "the 34 pin out from the floppy disk)" to "the 24 pin out" that could be connect to the the KN 1000 "24 pin in" conector jack in the KN 1000 main board.
As we know, the common disk drive unit in the market have 34 pin out only. wa can't connect directly 34 pin out floppy disk drive to the 24 pin in jack connector inside the KN 100o main board.
We need such an interface. This is the problem coz no one sell this interface separately in the market.
If u have one KN 1000 floppy disk drive unit (SY-FD), u can pick out that interface from inside the unit, and use it as a gate/interface from your new floppy disk drive to the "24 pin in" connector inside KN 1000 main board.
U can search this 24 pin out diagram interface in the net, but the problem is no one sell it separately.
Jun 20, 2012 | Teac IBM USB Portable Diskette Floppy...
Trying to remove the deck of the mkz08 so i can install two 10 subs and my amp. need some advice. thanks
I would buy a amp kit with 4 gauge power/ground wire, as for speaker wire 12-14 gauge is good.
Sep 10, 2011 | Interface Lincoln Mkz 2008 08 Retain Nav...
Im gettina an f70 f71 code on my machine what does it means?
F70=CENTRAL CONTROL UNIT HEARTBEAT FAILURE
If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the Central Control Unit to the User Interface.
F71=USER INTERFACE HEARTBEAT FAILURE
If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the User Interface to the Central Control Unit.
Repair Sequence:
1. Check for continuity of the User Interface harness.
2. Check wire harness connections to the User Interface and the Central Control Unit.
3. Replace User Interface if drum is rotating.
4. Replace Central Control Unit if drum is not moving
user interface is about $195 New;CCU is about $200. Hope this helps!
May 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Teac external floppy disc drive will not format floppy disc
U need an interface, if u want to use the "34 pin out" from floppy disk unit, to the "24 pin in" connector jack, inside KN 1000 main board.
U can get this interface unit bboard from "the KN 1000 floppy disk drive unit".
Just open this unit SY-FD20, and pick out that interface board from this unit,
Then use it as interface to connect your new 34 pin out floppy disk drive to connecting to the 24 pin in connector jack inside the KN 1000 mainboard.
Feb 06, 2011 | Teac IBM USB Portable Diskette Floppy...
Son wants to buy CAD GXL2200sp studio microphone package and wants to plug into laptop.Will that work?
for purposes of recording quality, I would recomend getting and external sound card. M-audio make a good range. You would need to have a +48v phantom power supply for this unit to work. The sound card you buy should have this. A Pc or laptop won't
Jan 16, 2011 | CAD Microphones GXL2200 Professional...
Received Dell XPS 8100. No cd player so they sent me one. Dell hell it is. Anyway, I opened it and found MANY wires unconnected. Can you tell me what connects where? I took the cd burner out of my old one...
Your old computer had IDE interface, the new computer has SATA interface.. There is a thin connector power cord and interface cords with tge same width connectors.The existing hard drive has thes cables connected to it. Connect one power cord and one data interface cable to the cd drive. Connect the audio cable to the cd drive and the Audio IN connector on the motherboard.
Unless the motherboard has a ide connector. you can not use your old hard drive or cd. You can get a external drive encloser that can convert IDE to USB
Oct 14, 2010 | Dell Studio Xps 8100 Desktop Computer
Code says F70 and will not start
The control board is not communicating with the rest of the unit. This usually indicated a failed control board. Thios is what the tech sheet says
Possible Causes/Procedure
4. Replace Central Control Unit if drum is not moving.
You can buy a new control board in the below link http://www.appliancepartspros.com/part_details.aspx?part_id=4340070
Mar 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
INTERFACE QUESTION FOR C31C411A8460
The Interface is interchangeable. Specify a SERIAL Interface when ordering the unit.
http://pos.epson.com/bizPart/bizPartDIS.htm for more info
Nov 03, 2008 | Epson TM-H6000III Thermal Printer
Polaroid PhotoMax Fun Flash 820 Digital Camera Logo
43 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
