Question about RCA D61W20 61" Rear Projection Television
RCA D61W20, Rodent Urine, STain in the middle
Thank you so much for your help, its been very helpfull, like i say i clean with alcohol the chip and worked fine for a while, but the image went off again. Would this problem be related to with the flyback?
The picture comes on and off, and the image colapse to red whit diagonal white stripes, im think it could be a voltage problem, maybe a flyback problem, would you think this could be?, remember the sound its on at all times.
Thanks so much for your help
  • rodmorf Apr 07, 2008
    Did not had a chance to unplug the red CRT, but the image is no longer collapsing to red with stripes, it just sort of fades to black gradually and then comes on again.
  • RCA Master
  • 8,617 Answers
A red screen with thin white lines are retrace lines which is often a sign of CRT failure. Try unplugging the red crt PCboard and making certain its not touching anything then power on your et if it doesnt shut down you will know the trouble is in the red CRT and will need to be replaced.
Posted on Apr 07, 2008
  • Sonny Berry
    Sonny Berry Apr 07, 2008
    Its probably related to a solder issue in the red drive circuits if it keeps coming back on its own.
Trouble turning on RCA D61W20
the green light blinks three times but does not come on
Aug 16, 2009 | RCA D61W20 61" Rear Projection Television
RCA HDTV #D61W20, CHASSIS ITC222, PUSH & TWIST CAP ON HV CABLE
do you have the part number for the flyback ? I need it if you would please. send it to
swampbiker@hotmail.com
thank you
Apr 01, 2009 | RCA D61W20 61" Rear Projection Television
D61W20 RCA 55in
most probable solution is to replace the flyback 259296 you can get one at the fllowing link with free instructions
http://servicemanuals.vstore.ca/
Feb 26, 2009 | RCA D61W20 61" Rear Projection Television
RCA TV RCA D61W20, Light Blinks 3 Times
Usually when the crt leaks onto the chassis it can be cleaned and the affected components only have to be replaced I am not sure what "chip" you are refering too, but most ICs can be purchased as a replacement part. usually the entire board wont need replacing unless the traces are destroyed or replacement parts are unavailable.
Apr 11, 2008 | Televison & Video
RCA D61W20 61, power on and off, Rodent Urine.
it may just be where the blue and green CRTs were over driven when the red flared. This may go away in a few days on its own .
Apr 07, 2008 | RCA D61W20 61" Rear Projection Television
RCA D61W20 Image Turns on and Off, Rat Droppings
im sure that the rodent contamination is the root cause of your problem. but the blueish stain does it look like a smear? if you that is most likely a phosphur burn in the face if the CRT. it cannot be fixed without replacing the CRT. i suggest living with it or putting tv on the side of the curb.
Apr 06, 2008 | RCA D61W20 61" Rear Projection Television
Detergent stains on the finish of the washer and dryer
Try one or all of the cleaners listed below to remove the stain. Hope this helps you.
  • Oxygen bleach
  • Rubbing alcohol
  • White vinegar
  • Baking soda
  • Hydrogen peroxide
  • Acetone
  • Paint thinner
Steps to Remove the Stain:
  1. Laundry soap dyes are usually more difficult to remove than other colors.² However, oxygen bleach, such as Oxi-Clean, can sometimes clean away even the red stains. Sprinkle the powder on a damp sponge and scrub away the stain.
  2. Soak a cotton ball with rubbing alcohol and wipe away the detergent stain. If the stain is not immediately lifted, allow the alcohol to soak for several minutes.
  3. Vinegar is effective on many kinds of stains. Make a solution of one part vinegar in two parts water and sponge the vinegar onto the stain.
  4. Baking soda can be effective for removing detergents from appliance surfaces. Sprinkle baking soda on a damp sponge and clean the stain until removed.
  5. Combine equal parts of 3% hydrogen peroxide with water and sponge the stain with the solution.
  6. Soak a cloth with acetone nail polish remover and use it to wipe off the stain. If the stain does not wipe off right away, it may help to lay the cloth over the stain to soak for a few minutes.
  7. As a last resort, wipe paint thinner on the stain. Paint thinner can remove most dye stains. However, you may want to test this on a small, hidden area first to be sure the paint thinner won't damage the lacquer on the appliance or cause any other adverse effects.
  8. Once you have removed the stain, wash the area with soapy water to remove any residue from the cleaning solution.
Jan 06, 2018 | Washing Machines
Removing urine stains from mattress
Go to your local Pet Store! They have a remover called "Simple Solution." I have used it a lot!! It works for about every stain there is!! It's about $8 for a 32 oz. bottle. Worth every penny! I use it on my carpet...just pour some on like you were pouring a glass of water on it...let it set for a little bit..viola! Hope it works! It does for me!!
Nov 08, 2007 | Baby Trend Expedition LX 9134 Jogger
RCA D61W20 61" Rear Projection Television Logo
37 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
