Question about Alera Technologies Cruiser (270118) DVD±RW Dual Layer Burner
1997 Holden Vectra engine failure
The engine warning light came on so I had the system electronically diagnosed. The result was the timing sensor was failing. I replaced the timing sensor checked the plugs and ignition spark all OK but the engine fails to fire.
What is the likely cause of the engine failing to fire?
  • mikira Apr 07, 2008
    Further testing suggests I have a fuel problem and it may be the pump!
    Is the fuel pump electronic or mechanical?
    I have checked all the visible fuses and all are good.
    What do you suggest?
  • annette-d Oct 15, 2008
    I have a problem where the engine light comes on every now and then. Sometimes you can be driving a long and the whole engine cuts out and steering locks up. Then you just start it up again and drive off. It is starting to do it more regularly now and would like to know if this is a simple problem. Suggestions please
Had a similar kind of problem. Changed temperature sensor and works fine now
Youcee
Posted on Aug 05, 2008
Try the fuel pump relay
Posted on Apr 17, 2008
Where in New Zealand can i buy a holden vectra octopus hose
2001 Holden Vectra Reviews - Carsurvey.org
www.carsurvey.org > Holden > Vectra
  1. Cached
  2. Similar
Aug 4, 2016 - 2001 Holden Vectra GL 2.2 from Australia and New Zealand ... 'Octopus' coolant hose blew. This is stupidly designed by some idiotic engineer ...
PartsWorld : Holden Vectra Parts - Right Parts, Right Service, Right Price
https://partsworld.co.nz/parts/holden/vectra
  1. Cached
  2. Similar
Not logged in ( login ' register ). PartsWorld is New Zealand's Largest Auto Parts Recycling Chain ... Holden Vectra Parts - Select a Series. help. Don't know your ... Missing: octopus
Search Results for radiator hose js vectra - Telstra Media Search
search.media.telstra.com.au/?location=&searchIndex=australia...hose...vectra
  1. Cached
  2. Similar
Products 1 - 20 of 103 - TBAP Radiator HOLDEN Vectra JR/JS 2.5L/2.6L 6Cyl Auto . ... /catalogues/hose-application-catalogue-aus-nz-october-2012.pdf.
Holden Vectra Heater Hoses ' Sparesbox
https://www.sparesbox.com.au/vehicles/holden/vectra/heater-hoses-category
  1. Cached
Shop Holden Vectra Heater Hoses online at Sparesbox Australia. FREE Shipping on orders over $50. Missing: zealand ‎octopus
Too expensive to repair - what next? - Servicing - Automotive ...
forums.whirlpool.net.au > Automotive > Servicing
  1. Cached
  2. Similar
Jan 5, 2011 - Rather than scrapping, get the bottom hose fixed (Should be like ... If you do end up buying a new car, always buy japanese or commodore/falcon. ..... Holden vectra, If it is V6 vectra i can tell you right now it wont be the head gasket. .... broadband · Regional · Last century; International: New Zealand ISPs.
Holden ' Car parts & accessories ' Trade Me
www.trademe.co.nz > Trade Me Motors > Car parts & accessories > Holden
  1. Cached
  2. Similar
Holden for sale in New Zealand. Buy and sell ... Holden Commodore VL, Manual steering Rack & Inter shaft .... Holden VT-VZ Front Electric Window Regulator.
New Zealand can buy holden vectra octopus hose Google Search
Nov 11, 2016 | Holden Cars & Trucks
Spanner showing on dash when engine running vauxhall vectra c
VECTRA CAR WITH SPANNER WARNING LIGHT This Vauxhall Vectra car with spanner warning light illuminates or flashes yellow. Light will illuminate for around 3 seconds when the ignition is switched on. If the fault light illuminates whilst the engine is running, this signifies a fault within the engine or gearbox electronics system. The system will switch to emergency mode where fuel consumption may increase and the vehicles drivability reduced. A Vauxhall workshop must be consulted. If the light flashes whilst the engine is running, this signifies a fault within the electronic immobiliser system and the engine will not be able to be restarted.
Oct 25, 2015 | Vauxhall Cars & Trucks
Tensioning timing belt
Timing belts usually have an automatic (spring Loaded) adjuster. Usual replacement is done at 100,000 k or 60,000 miles. If you do not replace it you run the risk of it breaking which could do damage to the engine. refer to your owners manual.
Aug 30, 2014 | 1999 Holden Vectra
Radiator sensor holden vectra
For temp. gauge check the theremostat housing near the top hose enters the engine.
May 28, 2014 | Air Intake Hose Holden Vectra 2 Gts Hump...
Holden Vectra B 1997
Yes you must reset the code as the computer only knows that the last time it ran self test on that system it failed.
Jan 16, 2014 | Cars & Trucks
Meaning of warning lights
Manufacturers spend billions of dollars a year refining their cars' on-board diagnostics systems. However, all of the sophisticated diagnostics in the world will do little good if you don't know what the warning lights mean.
Purpose
Modern automobiles have dozens of sensors to monitor engine, braking and chassis performance. Any deviation from the car's established limits will trigger a dashboard warning light.
Check Engine Light
Check engine lights can indicate failure of the emissions system, fuel injection system, faulty sensor feedback, overheating or lack of voltage, transmission failure, and engine knock ignition system failure.
Brake Lights
Almost all cars have two separate lights for the braking system: a red "ABS" (anti-lock braking system) light and "Brake Warning" light. The former indicates failure of the electronic anti-lock system, the latter a loss of fluid pressure in the brake system itself.
Dynamic Warnings
Many modern cars have traction or stability control systems that prevent and notify the driver of tire slippage. These lights can come in the form of amber "SLIP," "TC," or "TRACTION" lights (for spinning tires), or "ESC" (electronic stability control) lights for a sliding vehicle.
Safety Lights
Most cars have a diagrammatic warning that indicates a door that isn't all the way closed, a seat-belt warning light, and an "airbag disabled/enabled" light. Any or all of these will be red or amber.
Read more: Car OBD2 diagnostic tool
Jul 25, 2012 | Cars & Trucks
Sometimes the engine check light comes on and the engine stalls, when switched off and started again, it is fine. it is a holden vectra 1996 auto.
Here is a website that a free manual can be down loaded for your vehicle
http://ezinearticles.com/?Find-the-Free-Auto-Repair-Manual-You-Need-Online&id=92717
May 01, 2010 | 1997 Acura CL
Emissions warning light stays illuminated while driving vehicle is a holden vectra 2001 and not oldsmobile as below. could not find a listing for holden.
The warning light has two states. A blinking light indicates a critical problem with gaseous emissions from the engine that is likely to cause permenant damage to the engine, exhaust sytem or catalytic converter. A blinking light must be remedied immediately, and the car should not be driven in this state, at the risk of causing serious and permenant damage to the engine, exhaust and/or catalytic converter. Repairing or replacing these parts can be extremely expensive. A reputable garage or a Vauxall/Opel garage should be able to diagnose and repair the problem.
A solid (unblinking) light indicates a non-critical fault in the emmisions exhaust system. Many faults are covered by this light including failures in emssions sensors, temperature sensors and a variety of other parts. This usually results in a higher than average amount of environmentally harmful pollutants being expelled from the car, loss of power and/or gradual damage to the engine, exhaust and catalytic converter. While the car can still be driven with a non-critical emmisions problem, it is highly recommended that the fault is diagnosed and repaired at a reputable garage or Vauxhall/Opel garage.
Jul 16, 2009 | 1995 Oldsmobile Cutlass Supreme
HOLDEN VECTRA 1999 MODEL
Its the engine management light, its telling you there is a fault somewhere, you need to plug into a diagnostics machine to find where
Jun 06, 2008 | Graco Spree 511 Holden Travel System...
Alera Technologies Cruiser (270118) DVD±RW Dual Layer Burner Logo
1,051 people viewed this question
Top Alera Technologies Computers & Internet Experts
solver2010
Tom Chichester
Bill Boyd
Are you an Alera Technologies Computer and Internet Expert? Answer questions, earn points and help others
