Question about Bose Wave Radio
Top popped off.
Cover popped off of wave radio/cd player and the ribbon came undone, so none of the buttons work. I can't get the ribbon to fit back into slot.
model awrc-1p.
thanks if you can help
I just removed the cover from my wave radio. There are 3 screws that hold the top cover on. Two are exposed and in the rear of the unit and the other is under the CD player lid.
To replace the cover find the two tabs in the front on the bottom cover. Slide the top on and using a screwdriver carefully pry back the front of the top cover so that the two tabs slip by and move into place. Then open up the CD player cover and make sure the spindle fits through the hole in the top cover. Push down and replace the screws.
I didnt remove the ribbon cable so you will have to check on how to refit the connector.
Posted on Apr 09, 2008
My bose CD player is not working my cd are stuck I don,t why
Good luck this should do it.
If you have a cd or two stuck in your Bose wave radio, here's how to remove it and save yourself $99. This procedure is for the radio (model AWRCC1 or similar) with a single front loading cd slot.
PART I
1. First unplug the power, wait a minute, and then replug power, watching the front display.
2. The display will read "Ejecting". If the cd ejects, then you're done and can skip Part II. If it doesn't eject and/or it displays "Disk error" then you'll need to do the Part II steps.
PART II
1. Unplug the power cord.
2. Turn the radio upside down with the front facing you.
3. Remove the 5 screws from the bottom plate.
4. Hinge the front of the bottom plate up no more than 2". Don't overdo this or you'll damage various ribbon cables inside. Use extra hands or a prop to keep it open this amount.
5. Reach inside and tilt-up the front of cd player's metal housing just enough to access the rims of the cd(s) within the space created in step 4.
6. Pinch the rim(s) of the cd(s) and gently pull it/them out.
7. Reverse these steps to reassemble your radio.
Enjoy your cd player again!
Feb 08, 2015 | Bose Wave Radio
No sound Bose wave
I took mine back to the Bose store and they gave me credit on my Wave that was about ten years old toward a new CD wave radio. I would recommend taking it to the Bose store and see what they can do for you.
Sep 11, 2014 | Bose Wave Radio
After opening my bose radio it no longer responds to control buttons.Could the plastic ribbon have anything to do with the problem? One side of ribbon is unconnected to anything.
Yes, that ribbon cable is the data-link between the circuit board in the base of the unit, and the upper circuit board controlling the button panel. If the lower part is free, reseat it - correct direction - in the main circuit board. If the upper part is free, you'll need to disassemble the upper unit to get access to where it fits. Be careful when pushing the ribbon cable back in - it's easily deformed. BTW, why did you want to open the radio?
Jul 09, 2011 | Bose Wave Radio
I gave the Bose Wave Radio and 3-cd player to a friend for
Unplug and plug back in. It should go through a automatic process, ejecting any discs that are inside. If all you hear is a mechanical noise, try this again only with the disc trays facing the ceiling.
Dec 29, 2008 | Bose Wave Radio
Non-working CD in Bose wave radio
Try replacing the battery on the bottom of the system - alot of people miss it because you have it constantly plugged into the mains, but replacing this (somehow) re-sets the system, and 9 times out of 10 solves the issue.
Dec 26, 2008 | Bose Wave Radio
Sony cdx-m610 BIG PROBLEM
yal ever fix them? its the ribbon cable between the face and the circuit board inside the unit the ribbbon cable is very cheap on ebay just google for example cdx-m610 ribbon cable now for the repair close ur face before u take out ur radio assuming u guys still have ur remote to do so theres 3 screws on the bottom of the face when u go to carefully pop the front panel off after pullin them hold ur deck facing down (this will keep ur reset and open buttons from fallin out then theres 4 screws holding in the face's circuit board roll the board out of the face very very carefully pry open the little black lock holding the cable in the connector then open ur radio up pull out the cd player assy same thing with that connector then ull notice the cable goes thru a tension roller pull each end of the cable to unroll it hold it there while removing the cable and sliding in the new one then slowly let go of the roller reattach the cable ends and put everything back together with the face remember its easiest to hold the deck face down those 2 buttons will stay in place hook the top of the face's cover first then put the deck back in ur ride and enjoy these ol sonys r worth a $20 fix specially if they still work good hope this helps yal
Aug 30, 2008 | Sony CDX-M610 CD Player
CD Player does not eject CD
Just took one apart tonight. Same problem, put in cd-played fine-push eject then click click click.
2004 nissan sentra 140 watt single cd player/radio.
This dash comes apart by pulling the top of dash (with the tray) straight out the clips should release. the bottom part had to be pried a little, then remove four screws and slide out the radio still attached to the mount and dash etc. One screw holds on the top of the stereo. After removing the screw you must pry the top off. Now it gets a little tricky, you must remove the cd player portion, however there are 5 tiny springs holding it down to some pads. The two springs in the rear are under a piece of the stereos frame held on by two screws, I had to use various sizes of tweezers to get the springs off. Lift the player out of the radio about an inch, you will see one 1/2" ribbon in a connector, the top of the connector slides out along the ribbon to release. The other ribbon about the same size plugs into a small daughter board in the radio, it just pulls out and pushes in (you can feel it is reinforced). once out turn it over and you will see what would be considered a gearbox, (small white gears in a see through case) one of the corners of this case has a screw through it. This corner has broken away from the board letting the gears come apart when trying to eject (this is the clicking). I took a soldering iron and melted the plastic back together and put a small amount of 5-min epoxy on for good measure. When putting back into case you can hook up the ribbon cables before all the spring grief and test it out. Mine worked perfectly again. Be care full when putting back together, there are a lot of little micro switches that must be in the correct position) Example, if the cd is ejected the white arm on the right side must be in the correct position. the read head (laser) must be away from the center of the cd. I believe it was easier to put together with it in the cd-in position (without a cd in it) so the laser must be toward the center of the cd. Don't force the laser, use the worm gear to move it in or out. I couldn't put one of the springs back on but it still works fine Good luck, it's not as hard as it sounds
Jul 30, 2008 | 2003 Nissan Sentra
Bose wave radio/cd often cd spins but does not play, sometines will correct if I turn unit off and on. HELP tHANKS
I've repaired about 10 type Bose AWRC3x (the radio/cd model with lift up lid and top controls). If the cd won't play or skips, try cleaning the lens VERY carefully with a cotton bud with some isopropyl alcohol. Let it dry then try again. This will help in about 1/3 of cases.
After that, a new laser unit is needed. They cost around 15 pounds,30 dollars, (Type SFP100s with 13 pin connector made by Sanyo). You need to have some electronics experience to take the case to bits to get the laser deck out, change the cd laser and reassemble. Basically, DISCONNECT THE POWER! Remove the 3 screws on top, turn over and carefully prise the front of the base away from the top cover with a table knife or similar. Lift off the top cover - be careful with the lid ribbon! The deck can be disconnected from its ribbon cable and wired connector very carefully. Take the deck to bits and fit the new laser head (take photos if you think it will help). Remember to unsolder the shorting 'blob' of solder which protects the new laser from static till its fitted.
On the bright side, there is no tracking etc to set up, that's all automatic so usually they work like new with a new laser fitted. I have to say this is the weakest feature on the Bose CD radio, the actual electronics rarely gives trouble.
Hope this helps Steve O'Donnell
Nov 27, 2007 | Bose & Wave& Music System
CD player not working
CD Player on my Bose Wave radio/cd just blinks CD and it appears to me that the disc is not spinning. This is the same problem that many others have already identified. I unplugged the unit and removed the battery but this did not solve the problem. I notice that there is a "platter" (part of the lid) that sandwiches the cd onto the spindle. the platter seems tight but does turn. Also, does anyone know if there is a drive belt that may have broken?
Nov 03, 2007 | Bose Wave Radio
Bose Wave Radio Logo
361 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
