I hace a x3470 lexmark printer, but i put in a new x3400 series ink cartridge, when i closed the printer top it says cover open, and won't go away
  • 1,113 Answers
Cover switch is broken.
see my solution on
http://www.fixya.com/support/t235147-lexmark_x_3470
Posted on Apr 08, 2008
SOURCE:
I cannot get my printer open to change cartridge for x4270
Here's a comprehensive guide on How to Install Ink Cartridges in Lexmark X4200 Series All-In-One's.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
I hope this information has been helpful.
Aug 16, 2011 | Lexmark X4270 All-In-One InkJet Printer
How to change the ink
Please refer to this article - How to Set Up the Lexmark X3600 or X4600 Series All-In-One.
Jul 12, 2011 | Lexmark X4650 InkJet Printer
Our lexmark 5400 series printer fell on the floor. We put it back together but now it says cover open even when it's not. Not sure how to fix this problem.
Try to remove the sheets of paper from the feeder. Open the cover and remove the cartridges. Close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert the cartridges and make sure they are properly seated and secured. Close the cover. Load some paper. Try to print again. If problem continues, please contact Lexmark technical support for additional assistance.
May 03, 2011 | Lexmark X3470 All-In-One InkJet Printer
Please help me find the spot to re place the ink cartige to an x 3470 printer
Perhaps the Lexmark X3400 Series User's Guide will give you a better picture. You can download it using this link: http://bit.ly/cSUqq8. Scroll to page 52 for the instructions on how to change the print cartridge.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source. Thank you for choosing Lexmark.
Oct 15, 2010 | Lexmark X3470 All-In-One InkJet Printer
How do i remove an ink cartridge from lexmark x3470 printer
Power on your printer and lift the cartridge door on the top of your printer. The ink cartridges will move automatically to the center. When they stop, pull the ink cartridge towards you and up to remove it. Then, take the new ink cartridge, remove all the plastic covers and place it in the printer. Then close the cartridge door and you are ready to print again.
Feb 26, 2010 | Lexmark X3470 All-In-One InkJet Printer
How can I scan without problems on a lexmark x3470 all in one
Hi..
To scan a document using the Lexmark Imaging Studio on ur Lexmark X3470, follow the steps given below:
1. Go to "Start," "All Programs," Lexmark X3400 series, "Lexmark Imaging Studio."
2. Click on "Scan," "Save edit or share."
3. Under "What are you scanning" choose the option as "photo," "several photo" or "documents."
4. Select the location to save as my pictures or other folder on your computer.
5. Click on "start" to scan.
To make a standalone copy:
1. Load the paper.
2. Select the "Copy quality" you want.
3. Open the top cover of the All-In-One.
4. Place the item you want to copy face down on the scanner glass. Make sure the upper left corner of the front of the item aligns with the arrow on the right of the All-In-One.
5. Close the top cover.
6. Change copy settings as needed.
Press "Black Copy" or "Color Copy."
hope this was helpful...
Apr 24, 2009 | Lexmark X3470 All-In-One InkJet Printer
Says cover open but its not
Open the cover, remove the ink cartridges, reinstert them, close the cover, and power it back on.
Apr 21, 2009 | Lexmark X3470 All-In-One InkJet Printer
Cover open is on display
put your finger on the second hole on the top from the right and press the switch (it's small, gotta try a little...), when the display changes, press copy and close the door... it just worked for me!!
good luck
Apr 02, 2009 | Lexmark X3470 All-In-One InkJet Printer
Cover open message error
HI this will help you, I have located the link and this is going to give you all the info that you need.
Please do not forget to rate our chat session ok
www.fixyourownprinter.com/forums/printer/46998
Thank You
Jayson
Sep 21, 2008 | Lexmark X3470 All-In-One InkJet Printer
 Grubhead
Grubhead
Marvin
Marvin
