Question about Oster 76076-010 Hair Trimmer
Oster classic clipper smoke after a few use not electrical smoke
My Clippers smoke afer a few uses ,I am going to open the clipper and use a electrical cleaning solvent and oil them again and see if this help.
  • 1 more comment
  • willfixit1 Apr 10, 2008
    I clean the clipper housing with a non flamable electric cleaner remove old oil and hair working fine now.
    Remove the switch cover and brushes and spay with an non flammable electrical solvent .and cleaner to remove old oil and hair and reassembly the switch cover and check the brushes and reinstall them..........
  • willfixit1 Jun 22, 2008
    Remove the switch cover and brushes and spay with an non flammable electrical solvent .and cleaner to remove old oil and hair and reassembly the switch cover and check the brushes and reinstall them..........and keep them oil and lubricate.
How do I do maintanience on my clipper to keep them running good
Posted on Jun 22, 2008
Classic oster outlaw clipper manual how do u clean grease the gears and oil the blades? how do I properly maintenance my clippers because they are getting real hot way to fast.
normal for clippers if the hair is long or thick
oiling is done with the clipper running
Change over from steel clipper blades to ceramic blades as they run cooler and stay sharper for longer
just place a small drop on the blades and let it work down
AS for others
make sure that the filter in the handle is clear of hair and the same for the vent under the hand
Other than that you can take out the 4 screws and put a small amout of oster grease around the wheel and drive pinion as it can get out and run dry
go to the manufacturing web page and download the pdf version manual
Mar 13, 2018 | Oster Health & Beauty
Want to use plastic attachment. What blade do I need to use with theses?
Oster 76 clippers can be used with a variety of blade sizes and combs. shaveroutlet.com has many in stock. When using comb attachments, you should use one of the following size blades; 000, 0000, 1, 10, 15, 30
ShaverOutlet com Search results for oster 76
Feb 25, 2016 | Oster Classic 76 Clipper w/ Detachable...
Instructions oster power pro cordless clipper
go google and see if there is a workshop or user manual for the clippers
Jun 26, 2017 | Health & Beauty
I was shaving my dog using oster ultra cordless clipper, and suddenly the clipper is not cutting hair instead it grabs hair. I opened it and clean out hair under blade, but unfortunately, i did not help.
With most clippers, after an amount of use they need to be cleaned then oiled. Most sets come with some amount of oil for your clippers. Otherwise you can purchase it separately. This should fix the problem.
Aug 25, 2011 | Oster Health & Beauty
Oster Blade 918-306 Size Texturing Fits Oster Classic 76 Clipper, Power Pro, Power-teq And Star-te: Oster class 76 clippers....had them for a week and...
70ca16d.jpg Hope this helps, this is a tongue guide, you hopefully recognise it on your blade. If they are not paralell, then adjust them with pliers, both need to be perfectly vertical. When you put it on the clippers push the latch in as you close the hinge.
If it still wobbles then the next fe wthings need checking
1. The hinge screws on the clipper are tight, located either side of the hinge on the clipper.
2. The drive lever may be worn, thats the maroon peice of plastic sticking up at the top of the clippers, it moves from side to side when clippers are running.
3. If all seems fine up to now, your clipper should be fixed under warranty as it will involve changing parts covered by the warranty.
www.sheareaseltd.com
May 17, 2010 | Sunbeam Oster Blade 918-306 Size Texturing...
Oster Golden A5 Clippers will not cut
If the clippers are new, it is not likely that the problem is internal. Sometimes, when the blade is put on the clipper, it needs an extra little push to clip firmly behind the blade catch (you can hear a little click). Try that.
Aug 23, 2009 | Oster Golden A5 1-Speed Universal Motor...
My electric dog clippers don't cut well
if the problem arrears to be with one blade on several clippers it sounds like you need to send the clipper blades for sharpening.
Aug 15, 2009 | Oster Health & Beauty
Clippers jam and won't cut when trying to use attachments
OIL THE CLIPPERS AND CLEAN THE HAIR OUT REALLY GOOD.
Jan 11, 2009 | Oster 76076-010 Hair Trimmer
Oster 76 clippers
Here is schematic and instructions for service and repair. The model in the picture is the A5 however it is the animal version of the classic 76.
http://www.peasridge.co.uk/clipper-advice/clippers-products-oster-a5.shtml
Oct 10, 2008 | Oster 76076-010 Hair Trimmer
OSter Titan hair clippers
Oster titan blades. I have had mine for 5 years.
Oil one is a little ball on the side of clippers push in with oil tip. Make sure your clippers are running for this. You also have to grease them once in awhile with clipper grease. You should have a front panel that has screws. open and grease put case back on. for cord you can try an oscar fix place or try and see if the company will replace if you have not had them long. hope this helps.
Apr 08, 2008 | Oster 76076-040 Hair Trimmer
Oster 76076-010 Hair Trimmer Logo
294 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Chuck
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
