Computers & Internet Logo
Posted on May 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need sound drive for my toshiba satellite p205-s6277
Anonymous
Level 3:
  • Master 1,138 Answers
  • Posted on May 25, 2010
Anonymous
Master
Level 3:
Answers
1138
Questions
Helped
432519
Points
3620
Here are the drivers for your sound card. select the best that suits your operating system
1. Driver Audio Realtek for Win 7
2. Driver Audio Realtek for Vista
3. Driver Audio for Win XP
Select and click download.
I hope you find the right sound drivers for your laptop.
Much appreciated if you rate this help..thanks..
My toshiba satellite p205-s6277 wont restore or configure also it freezes an error that the registry log has nop room
Click Start/My Computer then Right Click on the C drive and select Properties. If it shows zero bytes or that the drive is full and has no free space then that's why it is freezing and locking up. The system has no room to do anything.
1helpful
Hi I have a Toshiba Satellite p205-S6277 Laptop. When I turn it on it will not boot. The power lights are on, the fan turns on for a minute and the hard drive light flashes for a second. but nothing...
That could be a cpu problem or a man board error. You should be seeing some kind of error code either flashing leds or a beep. If it shows no code then if the memory is good, it can be the ram connector or the controller. Basically to generate any code the ram has to be good and the board has to see at least the first 64k of it. It will generate the code even with a bad cpu as long as it can use that first small bit of ram.
Swap the ram locations and you should try just one single module at a time. Sometimes heat cycles or vibrations will work the ram loose. So just taking them out and carefully reseating them can fix this problem.
The two normal causes for this on a laptop are a bad cpu that usually has overheated and the first suspect is always ram.
Either of those can be replaced fairly cheap. Past that you are looking at a main board replacement.
From your description the cpu sounds like the probable cause.
4helpful
3answers
Need to unlock phoenix bios password for toshiba satellite a135-s4527
remove the keyboard the mobo battery is there you need to unsolder one end of it, lift the leg, and turn it on that way for it to clear.. you will have to resolder once done.. have the skills or find someone that does... and you're set..
17helpful
2answers
Toshiba saltellite with internal harman kardon speakers, no sound
To solve your problem, please download and install this free software: driverupdate us. It wont take more than 5 min from you to update all needed drivers.
Wish you best of luck
1helpful
All for Toshiba Satellite P205-S6287 notebook
I am thinking that he just provided a set of drivers for this Laptop...
He simply put it there and said nothing...
Grand Canyon Tech
Grand Canyon Tech
