Question about Konica Minolta bizhub 350 All-In-One Laser Printer
How install or conect to computer bizhub c350
  • 108 Answers
Http://kmbs.konicaminolta.us/content/products/attachments/manuals/opsC350PrintController.pdf
all other manuals can be downloaded as a PDF at kmbs.konicaminolta.us
Posted on May 25, 2010
SOURCE:
Steps to install c350 and the drivers
Your Konica Minolta Bizhub C350 Digital Copier, Printer and Scanner should come with a CD/DVD which includes the drivers for different operating systems AND a PDF fie with user's manual. Even is possible that yo may fine several PDF files, in different languages.
So open your PDF file and find the section where it describes with enough detail the steps you should follow . Probably there are different procedures depending the version of Windows, MAC or Linux you are using.
http://kseroimpuls.pl/broszury/en-bizhub-c350.pdf
If you don't hat user's manual, get it from here:
Konica Minolta C350 User Manual
Jul 08, 2015 | Konica Minolta Bizhub C350 Digital Copier,...
Konica Minolta c350 printer driver install
You need a Ethernet cross over cable. plug that into computer the other in to copier
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 06, 2014 | Minolta Office Equipment & Supplies
Konica minolta bizhub c350 installer for mac
You have to have a fiery unit (external controler) to use the C350 With a Mac because the c350 dosnt come with appletalk in the software. IC-401 Is the model number of the controller you will need to connect the c350 to any kind of mac for printing / scanning.
Mar 14, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Printer not receiving information from computer
I guess you mean the c350 is not printing while Windows said the job has been sent? If so, it may have changed IP Address from the time you first install the Printer on Windows. Check the Ports setting of the c350 printer! e.g. d53b002.jpg
Network Pritners should have Static IP address or at least a reserved DHCP IP Address. Logon to your Router, check the MAC Address of the c350 and reserve/assign it a IP Address near the end of the DHCP range. Save the Router configuration and power cycle the c350. Confirm IP Address changed to the reserved IP.
Then you have to change all the PC's Printer Configuration of the c350's Port to update the reserved/assigned IP. Or remove the c350 from Printers and Faxes, then run the printer setup software again.
May 23, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub c350 will not scan to hdd
Easiest way is to change to SMB scanning which will give you direct scanning to PC or server. Create a new address in the machines address tab in the browser add the (must be a fixed) ip address of the machine it is going to with the folder name, user name and password and it will work a treat.
Mar 30, 2009 | Konica Minolta bizhub C351 All-In-One...
Erroe code
You post a wrong printer nr, you must have bizhub C350 not bizhub 350, beacause 350 doesnt have that kind of code.
In Bizhub C350 that code means:
C12C0: Hard disk recognition error
You have the following options:
- reinstall the hard disk
- change hard disk
or as a last chance change PWB-MFP
good luck
Feb 06, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
1,083 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
