Question about Vacuums
Beater bar belt too loose
My beater bar v-belt doesn't seem to get tight enough when engaged. The beater bar slows or stops when it contacts the carpet, and as a result the flat drive belt spins slower than the motor and friction causes it to overheat and smell like burning rubber. I cleaned out all obstructions so the bar spins freely when not engaged. It seems the belt should be about 1/8 " shorter than it already is. Any ideas ?
  • 2 more comments
  • jazdlz Apr 09, 2008
    I put on a new belt and it works fine now. Thank you ! The part that seems odd is that the original belt was the exact same size as the new one.Upon closer examination it appears that the inner part of the "V" on the new belt is more like a "U" which seems to indicate the old one just wore out. Bottom line-you were right. Thanks again !
  • rubyspider Jul 03, 2008
    My beater bar belt is loose and the bar doesn't turn. There is a black roller underneath the area where the belt goes onto the bar. Does the belt go underneath that little roller?
    Thanks,
    Larry
  • Anonymous Mar 18, 2014
    progressive model 1163693502
    beater bar will not spin
    President:
  • 1,673 Answers
You need a new belt, they stretch after awhile and will slip.
Posted on Apr 07, 2008
SOURCE:
Why does Beater Bar Fail to turn
Per owner's manual
1. Make sure the brush control is set on carpet mode.
2. The brush will only spin when the handle is reclined.
Others:
The belt has worn out and needs replaced. Although it appears okay, stretching is possible, which would result in too loose a grip to turn the bar.
If the belt was replaced, it may not have been pulled tight enough to turn the bar. To tighten on many vacuums, simply loosen the screws on each end of the brush, pull toward the front of the power head and hold while tightening the screws.
Jul 25, 2014 | Dyson DC14 All Floors Upright Vacuum...
Miele model SEB217-3 beater bar stooped working
Check the switch .It usually have a wiring diagram
Jan 25, 2018 | Miele Vacuums
How can I tell if I need to replace the beater bar? I replaced the belt but now it seems too tight and the bar doesn't want to spin.
The belt is supposed to be tight, but the beater bar bearings are probably full of string, hair, and thread. Remove the bar, remove, clean, and oil the bearings (3-1 or similar). Leave the belt off for a moment, and install just the bar. Spin it with your fingers--it should revolve freely--if not, redo the clean/lube process again making sure to clean the inside of the bearings with a Q-tip swab. Once the bar spins freely, remove it to slide on the belt and reinstall. Hope this helps!
Oct 16, 2010 | Bissell 6594 PowerForce Bagless Upright...
Handimate doesnt spin!
try ajusting the height if the beater bar also check the belt and motor
somtimes **** gets stuck in the end bearings and add resistance to the beater bar slowing it down remove beater bar abd check assemby for thread and **** build up
Aug 03, 2009 | Kenmore Progressive Bagless Upright with...
Beater Bar Belt loose and bar won't turn
Provided that the motor isn't loose, the belt should fit tightly. If you had reassembled the beater bar back in the vacuum improperly, the belt would be tighter, rather than looser. If you are sure that the motor isn't loose and the beater bar was reinstalled correctly, then either tha belt slipped back off the motor shaft, or they sold you the wrong replacement belt.
Jul 18, 2009 | Hoover U6630-900 WindTunnel Bagless...
Revolving brush stopped after I got a sock snagged in it.
If the Dyson model has a brush bar control roller at the left hand side of the top hood then it won't be able to be repaired unless its by a Dyson call out or someone who repairs Dyson models with brush control protection.
If the model doesn't have a brush control dial then you will have to change the drive belt:
Easy to do if you flip the machine over with the beater bar looking upwards. Locate the three/two screw heads and undo with a coin. When the roller section is revealed by taking off the floor head you should replace the belt with a new one and be careful putting the beater bar in the right way on both ends. The belt will be tight brand new so expect some tension in it.
If this works for you please rate Fixya! Thanks.
Mar 28, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Beater bar motor will not engage
Check your clutch to make sure it's engaged. There should be a knob on the foot of the vacuum that can be turned to stop the roller.
Mar 07, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson animal
sounds like you may have alot of hair or thread wrapped around the bar, this can stop it if there is enough, have a look at the beater bar (brush)
Jun 10, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Beater bar
on the bottom take out 2 screws they are closer to the back wheels pull off cover there is a plastic cover over the beater bar take off there is a belt if it broke or wore out change the belt that should fix your problem
Jan 07, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Vacuums Logo
240 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
