Model 60PL9200D/37 no sound - Televison & Video
  • 8,596 Answers
What device is connected to TV: cable, sat box, dvd player? What type of cable are you using to connect to the accessory device?
For a red, white, and yellow cable:
I cannot hear sound from the television when connecting to the AV1 input. What do I need to do?
Answer When you connect the accessory device to the AV1 input of the TV using either component video cables (YPbPr) or composite video cable (Yellow), you must connect the audio output from the accessory device to the 'INPUT AV1 AUDIO L R' of the TV using the RCA audio cables (Red and White).
If the connection is good,
Check to ensure that the AV1 audio source from the TV on-screen menu is selected to AV1.
  1. Press the 'MENU' button on the remote control.
  2. Press the cursor up/down to select SETUP and press the cursor right.
  3. Press the cursor up/down to select SOURCE and press the cursor right.
  4. Press the cursor up/down to select ANALOG AUDIO IN and press the cursor right.
  5. Press the cursor up/down to select AV1 and press the 'OK' button.
  6. Press the 'MENU' button to exit the menu.
Make sure that the volume on the TV and on the device is set at an audible level and also that the sound hasn't been muted.
For HDMI,
The picture quality is good but the TV does not produce any sound when connected to an accessory device with an HDMI to HDMI cable.
Answer
  • The TV's behavior is considered to be normal as some accessory devices have an HDMI audio output setting that requires to be turned on when using an HDMI to HDMI connection.
  • Check the on-screen menu of the accessory device to ensure that the HDMI audio output is set to ON.
  • In some cases, you may need to set the digital out audio stream of the accessory device to PCM.
  • For detailed information, please refer to the user manual of the accessory device.
Posted on Apr 07, 2008
SOURCE:
Philips model number 60pl9200d/37 screen dark
Hi Donabel:
Likely your lamp in your TV is beginning to fail. Please feel free to contact us at 866-764-5822 or [email protected] and we would be happy to help you troubleshoot your problem.
Best Regards
Dan
www.dlplampsource.com
May 31, 2014 | JVC HD-52G886 52" Rear Projection HDTV
Which fan do I need to buy to replace in my 60pl9200d/37
Lamp fans fail most often from the heat---good luck getting one with no idea of which you want---Philips not known for being real helpful to consumers.
What is set doing or not?
Nov 05, 2012 | Philips 60PL9200D Projection Televisions
My phillips 60 inch tv 60pl9200d/37 wont turn on the power button flashes blue
Look in the manual. (Page 4)
Turn the TV on From main supply: Ensure that the main supply is turned on. A blue indicator light on the front of the TV lights up. When the TV is turned on by the main supply, the blue indicator light will blink for 45 seconds. This is the lamp's start-up period. When the light goes off, press the POWER button on the remote control or power switch. Press POWER to turn on the TV.
http://www.retrevo.com/support/Philips-60PL9200D-TVs-manual/id/633ag423/t/2/
Telephone number Philips Customer Care Center: 1-888-PHILIPS (744-5477)
Aug 14, 2011 | Philips 60PL9200D Projection Televisions
I have a philips tv model number is 60PL9200D/37. when i turn on my tv the blue power light flashes and the lights and fans cut on but not the actual screen. after a few seconds of blinking the lights and...
U hear alots of clinking too,when tv power on and the projection lamp tried to come on?Yes,tv have a problems with it board call the Ballast board also.This Ballast board only job is to help ignite the tv projection lamp.
Feb 03, 2011 | Philips 60PL9200D Projection Televisions
How to replace the bulb in PHilips tv model 60PL9200D/37 ?
my tv flashes 6 times slow,pause,5 times fast but it dont power on
Sep 23, 2010 | Philips 60PL9200D Projection Televisions
Philips 60pl9200D/37. Two Red lights on power button.
If the power button is displaying the bulb fault indicator AND overheat indicator lights at the same time, it indicates a faulty cooling fan. The television is smart enough to detect when either of the two cooling fans in the chassis have failed, or aren't spinning fast enough. To prevent overheating and damage, the set will not turn on if a fan is faulty. You'll need a replacement fan.
Jun 20, 2010 | Philips 60PL9200D Projection Televisions
Philips 60PL9200D/37 has no display with new light engine/power supplt/lamp assembly/ and SSB
Did you change the lamp yourself or was it serviced,and when it was changed was the ballist(s) messed with? It may be the ballast that caused the problem to begin with.
May 09, 2009 | Philips 60PL9200D Projection Televisions
Red Lights on the Power button blink and picture goes dark
60PL9200D/37 When I unplug it for a while and turn it back on, the picture starts to come on, but it turns dark. And the red lights on the left and right side of the power button blink. Sound but no picture.
Feb 02, 2009 | Philips 60PP9202 60" Rear Projection...
Projection Lamp for Philips 60PL9200D/37 TV
More than likely the problem is the CRT fluid and not the tube. Do a few google or fixya searches on CRT fluid and to get an idea of what it looks like when it gets cloudy.
Nov 12, 2008 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
177 people viewed this question
Top Televison & Video Experts
Ekse
