The purge unit is located where the print head rest itself.. normally it's under the right side of the printer.
You will need to remove the cover in order to clean the purge unit, you have to be very careful as the purge unit might have small spring and if it's not fitted correctly, it will damage the purge unit.
Easiest way to clean it is switch on the printer, and open the front or top cover...let the print head move to replacement position then pull the power out and clean the purge unit. It's a messy thing as it will be fill with ink. U can clean it using tissue and moist cloth... apart from that, don't think you can clean much of it unless you are able to open the whole printer up then you will have a better view and space to clean it.
