Question about Samsung BlackJack Smartphone
My phone got wet
HI I have a samsung sgh-i617 blackjack 2 and my phone was dropped in the snow and now it won't even register when I put the charger on. I took the phone apart and my little white sticker is red showing the phone got wet is there anyway I can fix this so it will work again? I have repaired phones in the past and I don't wish to send this one out to be fixed. any suggestions on what to do?
  • 3 Answers
I fixed a few "got wet" phones by doing the following:
> First, check phone's manual or search on internet to see if it has some type of fuse. If so, check this fuse for continuity. If fuse is OK, proceed to dry out phone using one of the methods below, or think of an arrangement that would be just as good.
> Take battery out, dry it with towel. Keep battery out of unit and away from heat.
> Using a gas oven that has a working pilot light (small single flame), you can dry out the rest of phone by placing a cookie sheet on oven's middle rack..place a small towel on cookie sheet...and put the phone (with the battery cover off) on towel.
> Making sure pilot light is on, leave phone in oven for at least 2 days (48 hours). This technique will dry out the phone without turning it into a lump of plastic.
> If need be, make sure no one turns the oven on during this time by taping the oven's temp knob so that it won't move easily. Also, having an explanation note taped to the main knob helps.
> What if I don't have a gas range? Use a food dehydrator with at least 6 trays, phone on top tray-well away from heating element. The dehydrator should be set at lowest temp. Still use 2 days as drying time.
> Do not use an electric oven unless it can be set for 120 degrees F and does not go much above that temp.
> Use of a thermometer with ANY drying method is recommended. Place thermometer right next to phone. If temp goes above 120 Deg F, adjust whatever you can to keep temp in check.
> If you have no other choice, an electric lamp with a 60 Watt light bulb will suffice.....just get a cardboard box to contain everything......and play with the arrangement for correct temp and most important, make sure light bulb is not near anything that might possibly catch fire.
> With any solution that uses heat to dry phone, make sure you check temperature several times during first day and a few times on the second day.
> If everything goes as it should, your phone will be dry...inside and out, ready to check!
> Replace battery and it's cover, hook up phone charger......and see what happens.
> If it still does not work, that would strongly indicate an internal short circuit....especially if phone was turned on when it got wet. Time either for a new phone, or have original phone fixed.
Posted on Apr 14, 2008
I need remote code to unlock Samsung Blackjack SGH-I617
do you want Network unlock code for your Samsung BlackJack II phone?If so, then you can get it from Unlock-Zone.com here you need to specify your country,Network name to which it is locked,IMEI number of your phone.
Jan 25, 2014 | Samsung Blackjack SGH-I607 Smartphone
My phon turns offf and whev i turn it on it shuts itself right off
Try doing a hard reset or reformat your phones memory card. Turn phone off and hold the directional pad UP while turning the phone back on. Follow directions on screen. Also try taking the battery and SIM card out for 20 min and then put it back into the phone. There are two patch's avalible to download to update your phone. Click on the link below to download the Blackjack II user manual and patchs:
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=01010100&prd_mdl_cd=&prd_mdl_name=SGH-I617
http://forums.wireless.att.com/cng/board/message?board.id=samsung&thread.id=61120
http://www.modaco.com/content/i617-i617-modaco-com/262115/hard-reset-the-blackjack-ii/
Mar 05, 2010 | Samsung Clear Pink Hard Case for ...
I want to download PC SUITE for SAMSUNG SGH-i617 Blackjack 2
you mentioned your mobile as SGH-i617 but you categorized as SCH-i607
click the link below for SCH-i617
click here
you are defaultly in manual tab,so jump to software tab
download your pc suite there
if your mobile is SCH-i607
then click link below
SCH-i607
Nov 22, 2009 | Samsung Blackjack SGH-I607 Smartphone
Samsung Blackjack II Earpiece Speaker, SGH-I617 Blackjack 2 Audio Receiver i NEED THIS PART AND THE PART # IS 3009-001310
the earpiece speaker of my samsung i617 is not working,i cant hear anything but if i put in loud speaker i can hear it.
how can i fix my earpiece speaker?
Aug 28, 2009 | Cell Phones
My Samsung Blackjack II won't charge.
Return to the carrier for warranty repair.
If you are out of warranty there are some options you can choose from
1. Get repaired
2. New phone
3. external charging source
The external battery charger runs about 20 dollars on ebay with an extra battery.
Check out the following link to find more about these options
Samsung BlackJack II Battery charging problems
Jul 02, 2009 | Samsung BlackJack II Smartphone
I need remote code to unlock Samsung Blackjack SGH-I607
I have the same issue, Can anyone help??? I need a remote code to unlock the mobile phone1.gif (cingular) i have the IMEI.
It's for a blackjack II (i617) and desperately want to unlock it. (my phone w/t-mobile srv. is broken) IMEI 357246014347536 Please help. rakelz1qt@hotmail.com
Feb 10, 2008 | Samsung Blackjack SGH-I607 Smartphone
Samsung BlackJack Smartphone Logo
182 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
