Question about NetGear WGR614 Wireless Router
PASSWORD I JUST RESET MY ROUTER AND NEED TO MAKE MY PASSWORD AGAIN BUT CANNOT GET TO THE SITE TO DO IT WHEN I TYPE IN THE NUMBERS IN THE ADRESS BAR
  • NANI4246 Apr 07, 2008
    when i ping it says request timed out and i cannot reach the page using the ip address to lon on to my router i just reset it and neeed to setup a new password
  • 8,596 Answers
The universal pword is, believe it or not, 1234
Here is the website with exact instructions from NetGear itself - these instructions are for the v4 version of your router - make sure this is the correct version of the WGR614, or else this exact page will not work for you - if you have v7 instead, go to the v7 page, etc.
http://kbserver.netgear.com/kb_web_files/N100651.asp
Posted on Apr 07, 2008
I have lost the security code and have a new laptop, how do i set it up to work
Hi!
If you don't remeber the wireless security code, maybe you still remeber the user and password to access the web management interface of the router.
Then you have to connect the laptop to the router by using a network cable. Open a browser window, type in the IP adress of your router and check the wireless setup section. There you can find / modify the wifi security code.
If you don't know the router's IP adress, then open on your computer a ms-dos prompt and type the command
ipconfig /all
it will display your current IP adress, subnet mask and GATEWAY. The gateway adress is the router's IP adress that must be typed into the browser.
If you don't remember the user and password for accessing the router's web interface, please refer to the router's user manual in order to reset it to factory default configuration, and then proceed as for the first installation of the router.
Hope it helped,
Bogdan
Aug 30, 2011 | Belkin (F5D8231-4) Wireless Router...
My WRT54GL was given to me by my relative. She forgot her password. (my moms) The mechanism works. Just no password. How would I reset her unknown password? I'm sitting here tryin to set it up...
Hey there, I actually just finished typing a solution to someone else on how to reset your lost password so I'm just going to copypaste it since it's quite big ^^
Hey there, To fix this problem we're going to try and access the control panel of the router and changing the password again. Since you haven't specified the router's brand or type I can't say what the default password for your router is, however usually the password will be written somewhere on the router, along with the IP adress to access the control panel. If it isn't, check which brand and type the router is and go to this page to find out. If the IP adress of the control panel wasn't listed on your router, you'll have to find this out for yourself. Usually you can access it by going to http://192.168.0.1/. If this shows you a page or a popup to log in, go ahead and skip to the next alinea. If not, follow this guide to find out your router's IP.
If you have ever changed the password, you can restore your device to the factory settings to reset the password to the default one. This is usually done by pressing the small reset button on the router for about 20 seconds.
Now assuming that you got both your router IP and username/password and you can log in, then you only have to change the wifi password again, it should be fairly easy but once again I can't give a detailed guide on that since I don't know the router type.
I hope I was able to assist. If I was, please don't forget to rate this solution
Jul 28, 2011 | Computers & Internet
I cant access to my router
maybe you router reseted to factory default.. then you will have to set up everything again.
Connect your PC with a ethernet cable to the router
1. Go to the commnad line (MS-DOS) Programs ==> Accesories
2. Type "ipconfig"
3. Take note on the numbers in Default-Gateway (something like : 192.168.0.1)
4. Open a web-browser
5. In the address bar type the number that you took note before.
6. Type in username and password the factory default one (sometimes is "admin" and in the password field leave it blank)
7. Configure it again.
If you need more help. . please give me more info and I will be glad to help you..
Mar 08, 2011 | Belkin F5D8236-4 Router
I can not remember my wifi password. How do I reset to a new password?
Connect tot eh router with a cable and access the wireless setting through that. If you can't do that you would have to reset the router to default and then rebuild your network.
Dec 23, 2010 | Linksys Wireless-G Broadband Router
I want to put username/password in to my router to protect too coz someone are connecting w/ out my permission thank you.
be able to connect to the inter net on that computer click Start>run>type cmd>ok on the black screen type ipconfig >enter under wierless setings note down the numbers go to a web browser snd put the numbers in the adress bar enter
this will send you to the router settings login normaly blank password after this you can acses the security settings and enter a pass word any computer conecting to the network router will need and rember the pass code...
Jun 03, 2010 | Computers & Internet
WPA KEY???
if you forgot the password then you have to reset (hard reset) your router and set it up again.
Apr 03, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Problems with my linksys
check if there is a little red button on the back .... that says reset click it,.....if not then go to intenet explorer ... type the ip in the adress bar..... a username / password sign should come on ... for username leave it blank for the password right admin and it should take u to a internet sight ..... go to security settings and reset it ...u will figure it out from there truse me ! hope i helped -el
ps. the ip adress is 192.168.1.1
Dec 25, 2008 | D-Link DI-704P Router
New costomer connected to broadband but cannot connect the wireless
go to your computer broswer
1. type 192.168.254.254 in the adress bar - this should open your router properties. if it doesn't please post the make and model number of your router here so i can look it up.
2.you will need to put in passord , usually User:admin password:admin
3. look at the status screen and verify that the wireless on the router is enabled.
If it is not enabled, we will need to change a setting there to turn it on. again if you post the make and model numbers here i can look this info up in advance.
hope this helps.
Oct 07, 2008 | Computers & Internet
Password
What is the model number of the router that you have? By default the IP of the router is http://192.168.1.1,or http://192.168.0.1 depending on the model of your router.Just type that on your address bar. The username is admin password is password.To reset the router properly press and hold the reset button for 10 seconds and then unplug the power for 5 seconds and then turn it back on.after that access the address of the router and you will be able to configure it by then.
Apr 07, 2008 | NetGear WGT624 Wireless Router
ROUTER PASSWORD
Apr 07, 2008 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
135 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
