Question about Dishwashers
Cant find power source
I can't find the power source. there isn't a cord anywhere. How do I hook it to electric?
  • TAZET62 Apr 08, 2008
    aborcass, thanks for responding. It is a maytag model number wu502 tazet62
  • Ron Coons
    Ron Coons May 11, 2010
    make and model num if possible
    President:
  • 2,651 Answers
I appologize for thje delay in this response, i am unaware of any such model number, there generally is a hook up ( haard wiring ) under the righyt bottmo acess panel, if not a call to the manufacture would perhaps assist you further
Posted on Apr 12, 2008
6ya staff
SOURCE:
Ive hooked everything up like it should be and no sound from tv, game, or anything but the radio and dvd. What do I do next...
I cant narrow this down too a specific problem but here are a couple i can list off the top of my head
A. The outlet, or powerstrip is offB. There's a blown fuse somewhereC. Power cord or some other cord isn't plugged inD. There's A Manufactering defect.
Feb 26, 2012 | LG Audio Players & Recorders
No power
If it is not getting any power at all, only one of three things: cord is fried/dead; could be the outlet, try something else in the same socket; or, the board in the printer is dead.
1. Press the POWER button to power on the printer The device has a <POWER> button.
Connect the power cord from the printer to the electrical source.
Press the <POWER> button.
Wait until the device has completed its cycling process before submitting a print request or completing installation.
2. Disconnect and Reconnect AC power adapter or power cord to the device and electrical source
  • Disconnect the AC Power Adapter or power cord from both the device and the electrical source.
  • Then reconnect it.
  • If you are still unable to obtain power to the device, try another power outlet.
  • If possible, try connecting power directly to a wall outlet (as opposed to using a surge protector or power strip...just as a troubleshooting measure).
3. Disconnect and reconnect the electrical cord to ensure a secure connection 4. The iP6000D may require repair
For toll-free technical support, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 8:00 a.m. - 12:00 midnight. EST, Saturday 10:00 a.m. - 8:00 p.m., excluding holidays).
5. Try a different electrical source / outlet
this will surely fix your problem..
Dec 06, 2007 | Canon Pixma iP6000D InkJet Photo Printer
Power source loose when you hook the power cord to the back of the pc it wobbles plus not the pc will go to the toshiba screen and click off
It sounds like the DC Power Jack in your laptop is loose and thus your laptop isn't receiving consistent power. Search for Laptop DC Jack repair in your area in a search engine and have them look at it. It generally costs around $100 or so to repair a power jack.
Sep 29, 2011 | Toshiba Satellite P105-S6197 Laptop
I have a SONY VIAO PCG-71211W and the power cord isn't working and I cannot find the right adaptor anywhere. Do you happen to know what cord I need to buy for it. Thanks.
These are easily repaired if you are any good with your hands? The break is usually near where it plugs into the laptop, The little plug that plugs into the laptop the wires break at the little plug, If you cant do this you will get one on ebay usually very cheap, Hope this helps,
Sep 19, 2011 | Computers & Internet
When i cleaned my dell demension i put everything back exactly how it was now when i turn on my computer none of my external devices mouse pc screen keyboard is not turning on i need help
I would first check and verify that the electrical outlet or power strip that they are plugged into is working. If a plug gets in a bind it could have blown a fuse on the power strip or the power strip might have a reset switch on it. Or the power strip might have failed. If you have a uninteruptable powersupply that you plug everything into you will need to confirm that it is working as well, test it and look for reset buttons or a fuse holder on it. Your electrical cords could have been pulled out from the wall outlet itself while cleaning sometimes even wall outlets if put in a bind from pressure will blow a fuse or the cord might pull out just enough that it is not making a good connection.
You might get a lamp with a bulb that you know works and plug it into the same electrical receptical that you have the dell computers power cord plugged into and then test the monitor power source the same way.
If the outlets or power strip are getting power and that is confirmed by testing them, and then you plug in the Monitor and Dell power cords into the sources that you have confirmed are getting power, and they do not come on we have a different problem.
If the monitor is hooked up wrong to the computer or not even hooked to the computer the light should come on on the front of the monitor incicating that it is getting power. If you plug it into a confirmed working electrical outlet the light should come on on the power button of the monitor. If it does not come on then somehting might hve possibly damaged all of the epuipment that was plugged in like a power spike on the electrical lines going into your home, this would be very rare but not impossible.
I am sorry for all of the senerios but you were not really clear on what you were using as power sources going to the equipment and I wanted to try and cover the most common possibilities in one email. Please let me know if this helps
Aug 02, 2010 | Dell Dimension E521 PC Desktop
In need of a power cord for my mintex 1600 dvd player
You usually don't need to call the company to replace the power cord. Go to Radio Shack or your hardware store and find one that will plug in. By calling the company and getting an OEM replacement you will be paying extra for the name on the package. I have bought a cheap small appliance just for the power cord. A bit of leg work will save you aggravation and money.
Feb 09, 2009 | Mintek DVD-1600 DVD Player
Trimmer Question
mains, battery or petrol A hedge trimmer can be powered in 3 ways: mains electricity, rechargeable battery or petrol. They all have their advantages and disadvantages, so decide which is best for you. Electrical hedge trimmers provide a clean lighter weight option with the convenience of immediate and continual use. However you may be restricted by cord length - not ideal if the hedge is a long way from your power source and having a cord can be obtrusive and dangerous. Rechargeable hedge trimmers give you the best of both worlds. They're clean to use and have no cord so they can be used anywhere, without the danger of accidentally cutting the cord. They are less powerful than petrol models and you do need to plan ahead though and make sure your batteries have been charged. 5-7 hours of charging will give you just 30 minutes use. A second battery will give you back up but if you're cutting for long periods of time, you may find this timescale too restrictive. Petrol hedge trimmers can again be used anywhere, there's no cord so they're safer. Just top them up with petrol and away you go, no charging necessary. These models do tend to be harder to use - they're heavier, noisier and smoky.
Aug 27, 2008 | Electrolux Gas Hedge Trimmer
Lost Power Cord cant find a new one
I lost my power cord for my Electric skillet and called Wal-Mart number on the back of the skillet and they said it would be able to be exchanged for a new skillet with a cord if purchased within 2 years even without a receipt or a box :-)
Aug 05, 2007 | Rival S16 Electric Skillet
Dishwashers Logo
60 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
