Question about Apple iPod nano
Ipod this thin i reset it and now it wont let me select the english for the rest of the setup why?
  • Anonymous Apr 11, 2008
    charged ipod - tried resetting - nothing happens.
Throw it away its a piece of ****
Posted on Apr 15, 2008
I need to reset my passcode on my iPod
If you are unable to obtain your password you will loose all your data and will need to do an initial setup by holding down the power and home button and then plug it into itunes to do the rest How to reset iPod Touch password if you ve forgotten or lost it Fix...
Jun 13, 2014 | Apple iPhone 5
I have a apple ipod A1199 my little brother got a hold of it now its in some forien language that i cant read how do i get the menue to read american again?
No problem, you'll just need to do a full reset to restore the language to English.
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. Try resetting the iPod while it is connected to power.
Feb 28, 2011 | Apple iPod Photo MP3 Player
Please i need to get my ipod started in english
If you have an iPod nano or Fifth Generation iPod (iPod with video):
  1. Scroll down to the last menu option but don't select it.
  2. Scroll up one menu item. This should be Settings.
  3. Press the Center (Select) button. This takes you to the Settings menu.
  4. Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
  5. Scroll up to the third menu item from the bottom one. This should be Language.
  6. Press the Center button to select Language.
  7. Select your preferred language from the list.
Aug 30, 2010 | Apple iPhone Smartphone
I need to change the lanuage from japanese to engish on a ipod and I know absolutely 0 japanese
If you have an older iPod with color display (including iPod photo)
  1. Scroll to the fourth menu item in the screen and press the Center (Select) button. This takes you to the Settings menu.
  2. Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
  3. Scroll up to the third menu item from the bottom one. This should be Language.
  4. Press the Center button to select Language.
  5. Select your preferred language from the list.
If your iPod has a monochrome display (black and white):
  1. Scroll to the third menu item in the screen and press the Center (Select) button. This takes you to the Settings menu.
If the instructions above don't enable you to change the language on your iPod, try using the "Reset All Settings" option at the bottom of the Settings menu. If the Reset All Settings option does not work, you can restore your iPod back to factory condition and reselect the display language.
Apr 29, 2010 | Audio Players & Recorders
My ipod wont play on my AVIC F910BT
I don't know if you fixed it already this iPod sound trouble, but I got ot also and found how to fix this trouble.
In fact there's a setup to do and mention in the User Manual (page 89 on the english one) the AV1 config should be selected as iPod
Using an iPod (iPod) Starting procedure
Connect your iPod.
No sound or video output if iPod is selected
as AV source, check the setting in “AV1
Input” on the “AV System Settings” menu.
Dec 25, 2009 | Pioneer GPS
How do u change the language back to english
If this does not work.
Reset your iPod—Depending on how much you've used your iPod since selecting the language, simply resetting your iPod may cause it to forget the current language setting, enabling you to select a new one. See "How to Reset iPod" for instructions.
  • Connected. Eject before disconnecting
  • Sync in Progress. Please wait...
  • Do not disconnect
Note: When you reset your iPod, all your music and data files are saved, though you may need to reset some customized settings.
Jul 03, 2009 | Apple iPod nano MP3 Player
Language change
Hi, Let me provide you the steps to change the lnaguage on your ipod mini...
OR
Feb 21, 2009 | Apple iPod MA446LL/A MP3 Player
How to get my language back to english
Select your language.
for more details just click the link below http://support.apple.com/kb/HT1824
rate the solution if it helps. thanks.
Jan 05, 2009 | Apple iPod nano
Wrong language on ipod
This is simple but good to know.
-----John
If that doesn't work go to: http://support.apple.com/kb/HT1824
Nov 24, 2008 | Apple iPod nano
IPOD NANO 5G W/VIDEO
Dec 26, 2007 | Apple iPod 4th Generation MP3 Player
Apple iPod nano Logo
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
