Question about Panasonic Lumix DMC-LS1 Digital Camera
Please turn off the camera and turn it on again.
After starting the camera, lense begin to auto zooming.then display the message below:
"Please turn off the camera and turn it on again"
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 29, 2010
SOURCE:
I HAVE A SONY DIGITAL CAMERA DSC T-20 AND HAVING AN ERROR MESSAGE E:61:10 PLEASE SEND ME HOW I CAN SOLVE THIS PROB LEM
Hello and Welcome
The symptoms of this error is
  • After pressing the power button in capture mode, the lens would extend and a slight humming from what appeared to be the auto focus motor could be heard for about 5 seconds. When the motor stopped humming, the camera would beep and display E:61:00 in the LCD Screen.
  • Camera would extend the lens but not be able to focus on anything past 8 inches or so.
  • Zoom in and zoom out would not work.
  • Playback mode and the Setup mode was not affected.
To solve this
Put the camera about a half inch from a hard surface.
Let the lense go out and hit the surface and retract a little bit. Let it go out all the way when it tries the next time.
If that doesnt fix it, try this:
Turn it on and let the lense go out fully
See where the lens comes out of the camera? The little round crack that surrounds it? Wiggle the lense a bit and blow in there a bit. (Be sure not to blow on the lense!)
Now turn it off/on again, and it should be fixed
See the following video, It may also help you
I hope it will be Helpful for you.
Thanks and keep Using FixYa
Mar 16, 2011 | Sony Cyber-shot DSC-T20 Digital Camera
How you can eliminate the sign on E:61:00 the camera sony DSC T-5 series Cybershot
Hello and Welcome
To solve this
Your Rating As Four Thumbs which are given below to this solution will appreciate me
Thanks and Keep using Fixya
Mar 11, 2011 | Sony Cyber-Shot DSC-T5 Digital Camera
E:61:00 on sony cybershot camera
To solve this
Mar 02, 2011 | Sony Cyber-Shot DSC-F828 Digital Camera
ROKINON AUTO ZOOM Macro--- HELP to enable macro
Some of the Rokinon (and other ) zoom lenses could only go into MACRO at certain focal lengths- the lens you have "zooms" from 80 to 200 focal length,but is that done by "sliding" a ring forward and back on the lens, or by twisting a different ring that the one that focuses?
May 16, 2010 | Rokinon 85mm f14 for Nikon
Message on screen "turn power off and on again" when switching the camera on
this problem appears when the zoom motor starts malfuntion the remeady of its is to replace the zoom motor (if comopnent level repir is availble in ur area) other wise u have to scan complete lense block assembly. u didnt mention model no.
Jul 25, 2009 | Cameras
Sony cyber shot dsc w55 7.2 mega pixels
turn on when lense extends take hold of the end of the lense and gently twist and pull the lense you may hear it click do not force the lense then turn on and off again this should solve the problem.
Aug 07, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Finepix A400
If the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs. Problem may caused by lens zooming gears stuck.
Apr 04, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Panasonic Lumix DMC-LS1 Digital Camera Logo
80 people viewed this question
Top Panasonic Cameras Experts
Ekse
skyblue007
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
