I have an LG 50PC5D plasma screen tv. The DVD player has audio but the tv lists the component as NO SIGNAL. It has been working fine for 2 months. I made no changes to any cables or anything. Please Help!
  • 8,596 Answers
DVD player is stuck in Progressive Scan mode - can happen quite easily. I will need to know the mnaufacturer and model of the dvd player to tell you how to reset it.
Posted on Apr 07, 2008
SOURCE:
Snowy white picture while on cable.
Maybe a tuner problem--considered hooking up whatever you use for signal to the rear av jacks? bypass the problem?
Apr 06, 2012 | LG 50PC5D Television
YPbPr and YCbCr signal
with component, if there is not a solid signal, it'll go blue. if the dvd is dirty, the player is dirty, or any other break in signal, it'll go blue. clean your dvd and/or player.
Feb 26, 2009 | LG RD-JT30 Multimedia Projector
Grainy picture on LG 50PC5D plasma
Did you try another HDMI cable?
Did you try another DVD player?
If the above try-outs does not work for you, then the fault is most likely with the HDMI input processor area. For this the set will require service.
Jerry G.
Feb 03, 2009 | LG 50PX4DR 50 in. Plasma TV
LG 50PC5D rigth screen colored lines 12''
LG 50PC5D-UL Plasma TV.... While playing XBox360 the screen just shrunk to the top 3" as though some one was holding a towel over the bottom portion of the screen. I have unplugged all inputs and the unit. I have let it cool down. Still it remains in this condition. I can't see the menu because it's in the portion of the screen that is "blacked out". What do I do?
Jan 18, 2009 | LG 50PC5DC 50 in. Plasma HDTV
Dvd wont work.
First, is the DVD player output (Video out, audio out) connected to the TV input? Have you used the Yellow cable from  DVD video out to the TV video in? Mixing the audio and video cables will result in no signal. Have you selected the proper input with your TV remote control. Most plasmas accept a variety of input signals; you must select the right one. I deal with a number of these issues. Usually the connections are made improperly or the correct input source is not selected with the TV remote. Put a DVD in the player and press play. Be sure you have made the proper connection from DVD player video/audio out into an auxiliary or video input on the TV. These could be labeled Line 1 or Line 2.  With the DVD playing, run through the input options on your remote control. The button might be marked source, video or input. The screen should display your choices i.e. video 1, video 2, etc. When you see your DVD program, you've got the right combination.
Dec 13, 2008 | Hitachi 42HDS69 42 in. Plasma Television
LG flat panel lost picture
try painting on screen to create a picture
Jul 20, 2008 | LG DU-42PX12XC 42 in. Plasma HDTV
Tv has no signal
sounds like the EDID data has been corrupted in your main board. it can be reprogrammed but most techs will just replace the board. either way someone will have to come out and look at it. it should have a 2 year parts and labor warr on it. call LG cust service and get someone out there.
May 15, 2008 | LG 42PX5D 42 in. Plasma HDTV
Zenith Z42P3 "Invalid Format" message from upconverter DVD
Ran into the same problem with this DVD player and my LG tv. Try this:
Open the DVD tray, with the DVD tray open press the HDMI select button until the proper resolution for your tv is illuminated, put the DVD back in, close the tray and try again. Simple fix -- worked beautifully for me.
Good luck
May 01, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
LG 50PC5D 50 Plasma Won't turn on
If you check underneath the t.v there may be a button that you need to push. then you can use the remote to turn it on. took about 2 hours before I found it.
mine is located on the bottom left, right underneath the screen.
Dec 26, 2007 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
Ekse
